Battery Question
Car: 92 & 91 Z28 1LEs, 87 IROC-Z, 90 ZR1
Engine: L98, LT5
Transmission: 700R4, 6-speed
Axle/Gears: 3.45, 3.42, 3.73, 3.27
Battery Question
Hey Everyone,
The battery in my 1LE is getting weak. It's the 2nd battery the car has had, and the previous owner actually had the decal from the original battery removed and placed on this one many years ago. I recently bought a repro label, but the new Delco batteries have the two removable caps, not the flat style type. Does anyone know if thee is a battery type that has the same physical type top as the originals?
Thanks!
Erik
Thanks!
Erik
Car: 1989 TTA
Engine: 3.8L Turbo V6 - VIN 7
Transmission: 200R4
Re: Battery Question
East Penn makes the same style flat top batteries (75 series) but without the "green eye" on them.
http://www.dekabatteries.com/
Napa, Sears and others get their batteries from there with their own labels on them.
Bye the way do you have a better high resolution photo of the decal on yours we can keep as a reference for those of us that had that same 601 battery from the factory.
Car: 1989 TTA
Transmission: 200R4
Engine: L98, LT5
Wow, that looks great! Thanks for putting up the pics and the info, I really appreciate it! Yes, i'll snap some better pics of the label and send them over to you. I asked my friend who does high end decals if he could make some based on it, he said he thought so.
Engine: L98, LT5
Out of curiosity, what did you use to remove the old labels? Heat gun or just peel them off at ambient temperature? Thanks!
Warm them slightly with a heat gun. The glue will release enough to come off without much effort. Just make sure you keep the heat gun moving and use it on a low setting or you will melt the label.
Car: 1989 TTA
Transmission: 200R4
On the new battery I bought (pictured above); the labels just pulled off with no effort at all.
Send me some good pictures of yours when you got it off, or put it in your scanner if possible.
Car: '87 IROC-Z
Engine: TPI 5.7
I don't even remember how the green eye works. When it was green it was supposed to be charged, right? I seem to recall back in the '90s seeing the green eye looking OK but the battery could still be dead.
Car: 1989 TTA
Transmission: 200R4
Green is good ... black would mean recharge ... grey/white means dead ... however not a very reliable system.
Here's a period video to watch:
Note the factory correct decals on the battery !
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Car: 1989 TTA
Transmission: 200R4
Car: 1989 TTA
Transmission: 200R4
Engine: 5.0 EFI
ev305tpi(Erik),gave me the heads up on this Ebay Ad
http://www.ebay.com/itm/delco-battery-decal-Restoration-Chevy-Buick-Gm-Pontiac-/191042431662?pt=Vintage_Car_Truck_Parts_Accessories&hash=item2c7b042aae&vxp=mtrI just finished getting them on.This is a Napa Legend 75 Battery
You wouldn't happen to have a spar dot would you?
Car: 1989 TTA
Transmission: 200R4
Delco Battery Decal Restoration Chevy Buick GM Pontiac | eBay
Oh and looks like you installed them upside down.
Engine: 5.0 EFI
I've only had this bat.since last summer,so I guess it's OK.
Do you have a dot to spare?
Car: 1989 TTA
Transmission: 200R4
Did your friend make repros of your label, if so let me know and maybe we can swap some :-)
Send me a PM
Street Lethal
Apr 30, 2019 12:14 PM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
db057
Aug 11, 2015 10:11 PM
