Another One. 161 miles '90 IROC-Z 'vert.
Old Dec 20, 2015 | 09:30 PM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
http://www.ebay.com/itm/Chevrolet-Ca...m=131681361855
Old Dec 21, 2015 | 05:57 AM
PurelyPMD's Avatar
Car: 1987 IROC Original Owner
Engine: LB9
Transmission: M39 MM5
Axle/Gears: G80 G92 J65
Re: Another One. 161 miles '90 IROC-Z 'vert.
They just keep showing up! Nice car!
Not a stripe delete car however and no explanation for the missing decals.
That's local to me, I may have to check it out.
Old Dec 21, 2015 | 07:22 AM
two-if-by-sea's Avatar
Car: 89 RS Vert, 89 Formula, 89 Bird
Engine: L03, TBI 350, none
Transmission: 700R4, 700R4, none
Axle/Gears: 3.42, 3.45, none
Look closely, the emblem is in the correct spot on the rear of the door. I had a friend in high school with a hardtop, same color combination. Love it.
Old Dec 21, 2015 | 09:10 AM
chazman's Avatar
Axle/Gears: BW 3.45
It's there, just hard to see.
Old Dec 21, 2015 | 11:00 AM
puma1552's Avatar
hood gap is not good at all
Old Dec 21, 2015 | 03:18 PM
PurelyPMD's Avatar
Engine: LB9
DAMN that is hard to see!
I sent him a message, haven't heard anything back yet.
If he steps back into this world, I wouldn't mind owning it.
Old Dec 21, 2015 | 08:51 PM
ev305tpi's Avatar
Car: 92 & 91 Z28 1LEs, 87 IROC-Z, 90 ZR1
Engine: L98, LT5
Transmission: 700R4, 6-speed
Axle/Gears: 3.45, 3.42, 3.73, 3.27
Lol a friend of mine and I were just talking about this! Glad i'm not the only one looking haha...
Probably my biggest pet peeve about many thirdgen Camaros is the gap being off on so many... I can't believe how many of them you could drive a truck through and it bugs me lol... you are right, for some reason its a bit too big on this car. Should look like this:
Old Dec 21, 2015 | 08:52 PM
ev305tpi's Avatar
Engine: L98, LT5
Very pretty car otherwise, gorgeous color combination!!!
Old Dec 21, 2015 | 10:06 PM
chazman's Avatar
Axle/Gears: BW 3.45
Easy to fix, though.
Old Dec 21, 2015 | 11:56 PM
KMK454's Avatar
Car: 1991 Camaro B4C
How's it done? Mine seems to do it a little bit; I've noticed some factory low mile survivors with and without the gap.
Also note the steering wheel cover is peeling up on the top sides...
Old Dec 22, 2015 | 12:17 AM
chazman's Avatar
Axle/Gears: BW 3.45
Make sure the rubber bumpers at the corners are adjusted correctly by twisting them to raise or lower. If worse comes to worse, adjust the bolts on the latch.
Old Dec 22, 2015 | 05:39 AM
PurelyPMD's Avatar
Engine: LB9
I guess I didn't make the cut...
Thank you for your inquiry. Unfortunately the answer is no. This is because the car is kept in a highly secure, climate controlled facility with the rest of my collection and I do not allow others into the facility. Until I know that a potential buyer is serious I can't get involved with showings. There is tremendous interest in this car but unfortunately a lot of dreamers wasting my time. Regards, Joe.
Old Dec 22, 2015 | 10:35 AM
vinny R's Avatar
Car: 1991 Z28
Axle/Gears: 3:42 Auburn
I guess not. And from that response back, you ain't the only one!
Old Dec 22, 2015 | 05:37 PM
ev305tpi's Avatar
Engine: L98, LT5
What?? Jeesh!!! Good luck to him selling the car with that attitude... That's insane....
Old Dec 23, 2015 | 09:49 AM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
The hood gap on this car is a little large for a low mile car, but adjusting the bump stops won't fix the issue here. The hood appears to sit correctly in relation to the fenders. There are other adjustments needed to get this one tighter.
Old Dec 23, 2015 | 10:44 AM
LiquidBlue's Avatar
Car: 90 Formula / T-tops
Transmission: MD8
shocking that 4 owners would only put on 161 miles
Old Dec 23, 2015 | 10:53 PM
KMK454's Avatar
It almost looks like it needs the frame holding up the nose piece adjusted... The plastic bits on the exterior do seem to warp over time.
FRMULA88
Sep 24, 2013 08:05 AM
tpi_master
Feb 18, 2002 08:54 AM
