1990 iroc z vin number
Engine: LS1, LB9, L03
Re: 1990 iroc z vin number
No way to tell if it was an IROC, but the last VIN of any 1990 Camaro was 134986.
Actually, JT can run it through the Compnine decoder and see if it's listed. If so, it may have the RPO codes listed.
Just looked it up and the last VIN is 1G1FP23EXLL134986, and that's a 1990 RS with the 305 V8. Not in good shape.
Not sure where we got the idea that the 134986 was the last car because David M states that the last car was a white V6 RS. I was playing with VIN numbers and found this, 1G1FP33E6LL134988, an RS convertible, 1G1FP2380LL134991, an L98 IROC-Z, 1G1FP23E8LL134999, is a V6 RS.
What do you need to know?
This is the SPID contents for the VIN. Not much else is available, publicly. Also, don't take the descriptions as 100% authentic. Only the 3 digit/character codes are the important points.
UB3 CLUSTER,INSTRUMENT(OIL,COOLANT TEMPERATURE,VOLTMETER,TACHOMETER,TRIP ODOMETER)(USED WITH DELUXE SPORT PKG W32) GA(UB3)
UM6 RADIO,AM/FM STEREO,CASSETTE,ETR,INCLUDES CLOCK STEREO CASSETTE(UM6)
UQ1 RADIO,PROVISIONS FOR STEREO STEREO RDO PR0VISIONS(UQ1)
UX6 SPEAKER SYSTEM,FRONT DUAL DASH MOUNTED SPKR SYS(UX6)
VAN Unknown
V73 VEHICLE STATEMENT - US/CANADA US/CANADA VEHICLE STATEMENT(V73)
WW8 AERO PACKAGE(BRIGHT RED)(USED WITH AERO PACKAGE W62) AERO PKG(WW8)
W62 AERO PACKAGE AERO PKG(W62)
Z28 SPECIAL PERFORMANCE PACKAGE,IROC-Z(MERCHANDISING OPTION) IROC-Z PKG(Z28)
1AZ ORDER MODIFICATION - ORDERS SOLD
1SD PACKAGE-OPTION 04 (1SD)
15P WHEEL COLOR,MEDIUM SLATE GRAY (15P)
6ZW Unknown
7ZW Unknown
8NL Unknown
81Q MOLDING COLOR - BRIGHT RED (81Q)
81U EXTERIOR COLOR,PRIMARY,BRIGHT RED (81U)
82C TRIM COMBINATION,CLOTH,MEDIUM DARK GRAY (82C)
82I INTERIOR TRIM,MEDIUM DARK GRAY (82I)
829 SEAT BELT COLOR - MED DK GRAY (829)
86A ACCENT STRIPE,TWO-TONE,LIGHT SILVER/BLACK (86A)
9NL Unknown
AC3 ADJUSTER,SEAT,6-WAY POWER,BUCKET,DRIVER 6-WAY PWR D/SEAT ADJR(AC3)
AG9 ADJUSTER,SEAT,6-WAY POWER 6-WAY PWR ST ADJR(AG9)
AJ3 RESTRAINT SYSTEM,FRONT SEAT INFLATABLE DRIVER SI INFL RST SYS(AJ3)
AM9 SEAT,REAR,FOLDING SPLIT BACK FLDG SPLIT BK R/SEAT(AM9)
AR9 SEAT,FRONT BUCKET,DRIVER,PASSENGER,MANUAL RECLINING(EUROPEAN STYLE) MAN RECL FRT BKT ST,DELUXE(AR9)
AU3 LOCK,SIDE DOOR,ELECTRIC ELEC S/D LK(AU3)
A31 WINDOW,ELECTRIC OPERATED,SIDE(USED WITH SE Z7M) ELEC SI WDO(A31)
B18 ORNAMENTATION,INTERIOR(DELUXE)(USED WITH TROFEO SPORT COUPE WL3) DELUXE INTR(B18)
B34 COVERING,FLOOR MATS,FRONT,CARPETED INSERT(COLOR COORDINATED) FRT CPT INS FLR MATS(B34)
B35 COVERING,FLOOR MATS,REAR,CARPETED INSERT(COLOR COORDINATED) RR CPT INS FLR MATS(B35)
B84 ORNAMENTATION,EXTERIOR,BODY SIDE MOLDING(USED WITH APPEARANCE PACKAGE Z12) BODY SI MLDG(B84)
C60 AIR CONDITIONER,FRONT,MANUAL CONTROLS A/C MAN CONT(C60)
DG7 MIRROR,OUTSIDE,RH AND LH REMOTE CONTROL,ELECTRIC(PAINTED)(USED WITH SE Z7M,STE Z7N,LE Z7K) O/S ELEC R/CON PAINTED MIR(DG7)
D34 MIRROR,INSIDE,SUNSHADE S/S MIR(D34)
D7C Unknown
D8E SENSOR (D8E)
D88 STRIPE,SPORT SPORT STRPE(D88)
E5Z ADAPTER - SPEEDO - DELETE
E9Z KEY - SPEEDO - DELETE
FE2 SUSPENSION SYSTEM,RIDE AND HANDLING(USED WITH PERFORMANCE PACKAGE WS6) RIDE & HANDLING SUSP(FE2)
GU2 AXLE,REAR,2.73 RATIO 2.73R(GU2)
G80 AXLE,REAR,POSITRACTION,LIMITED SLIP POSITRACTION L/SLIP R/AXL(G80)
IPC TRIM,INTERIOR DESIGN (IPC)
J41 BRAKE SYSTEM,POWER,FRONT DISC,REAR DRUM(CAST IRON) CAST IRON FRT DISC/RR DRUM BRK SYS(J41)
K34 CRUISE CONTROL,AUTOMATIC,ELECTRONIC(USED WITH SE Z7M) CRCONT(K34)
K68 GENERATOR,105 AMPERE(USED WITH SE Z7M) 105 AMP GEN(K68)
LB9 ENGINE,5.0L(5.0F),V8 EFI CAR ONLY 5.0F(LB9)
MD8 TRANSMISSION,AUTOMATIC 4-SPEED(THM700R4/4L60) 4-SPD A/TRANS(MD8)
MX0 TRANSMISSION,AUTOMATIC,OVERDRIVE(MERCHANDISING OPTION)(MD8) A/TRANS PROVISIONS(MX0)
NA5 EMISSION SYSTEM,FEDERAL REQUIREMENTS(USED WITH CALIF SEVILLE YP1) FEDERAL EMIS(NA5)
NP5 STEERING WHEEL,SPORT,3-SPOKE,LEATHER WRAPPED(USED WITH PERFORMANCE PACKAGE Y56,SPORT PACKAGE WN2) LEATHER WRAPPED STRG WHL(NP5)
N96 WHEEL,16X8(CAST ALUMINUM)(USED WITH SE Z7M) AL WHL(N96)
QLC TIRE,ALL P245/50ZR16/N BL R/PE ST TL HWY TIRE(QLC)
T93 LAMP,TAIL AND STOP(SPECIAL)(DELETES CHROME EDGING)(USED WITH INTERNATIONAL WJ9) SPECIAL TAIL & S/LP(T93)
T96 LAMP,FRONT FOG(LAMPS ARE HANG-ON WHEN USED WITH STE, LAMPS ARE PART OF HEADLAMP WHEN USED WITH LE OR SE) FRT FOG LP(T96)
VAN Unknown
6ZW Unknown
7ZW Unknown
8NL Unknown
9NL Unknown
D7C Unknown
D8E SENSOR (D8E)
Can anyone find out about iroc z work a vin number
1G1FP33F2LL129330
1G1FP33F2LL129330
IROCZDAVE (88-L98)
Mar 20, 2016 07:06 PM
