How rare or common is my Camaro?
Old Aug 2, 2016 | 02:58 PM
cheves's Avatar
Car: N/A
Engine: N/A
Transmission: N/A
I was just wondering...
Is a 1989 Iroc 5.7 TPI with TTops.
And how can I get a history check/carfax for free?
VIN: 1G1FP2188KL182529
AC3: ADJUSTER, FRT, ST, POWER, 6 WAY, BKT, DRIVER
AG9: ADJUSTER, SEAT POWER, 6 WAY
AM9: SEAT, RR, SPLIT, BACK, FLDG
AR9: SEAT, FRT BKT, EUROPEAN STYLE, PASS A DRIVER RECL
AU3: LOCK CONTROL, SIDE DR, ELEC
A01: WINDOW, TINTED, ALL SHADED, W/S
A31: WINDOW, POWER OPERATED, SIDE
A90: LOCK CONTROL, RR COMPT LID, REM CONT ELEC RELEASE
B18: ORNAMENTATION, INTR, DELUX
B2L: PERFORMANCEPACKAGE&ENGINEPACKAGEV85.7LPFI
B34: COVERING, FRT FLOOR MATS CARPETED INSERT
B35: COVERING, REAR, FLOOR MATS CARPETED INSERT
B84: ORNAMENTATION, EXTR MLDG, BODY SIDE
CC1: ROOF HATCH, REMOVABLE PANELS, GLASS
CD4: WIPER SYSTEM WINDSHIELD, PULSE
C49: DEFOGGER, RR WINDOW, ELECTRIC
C60: HVAC SYSTEM, AIR CONDITIONER FRT MAN CONTROLS
DC4: MIRROR I/S, RN, TILT DUAL READING LAMPS
DG7: MIRROR O/S, LH & RH, REM CONT, ELEC, PAINTED
D34: MIRROR, VISOR VANITY
D42: SHADE, RR COMPT SECURITY
D6E: GEAR, SPEEDO DRIVEN
D80: SPOILER, RR END PNL
D88: DECAL, STRIPE, SPORT
E5Z: SPEEDOMETER ADAPTER (DELETE)
E7Z: VEH SPD - DELETE
E9Z: SPEEDOMETER KEY (DELETE)
FE2: SUSPENSION SYSTEM, RIDE HANDLING
GH3: AXLE REAR, 2.77 RATIO
G80: AXLE POSITRACTION, LIMITED SLIP
IPC: TRIM-INTERIOR DESIGN
J65: BRAKE SYSTEM, PWR, FRT & RR DISC
K34: CRUISE CONTROL, AUTOMATIC, ELECTRONIC
K68: GENERATOR, 105 AMP
L98: 5.7 LITER V8 TPI ENGINE
MD8: TRANSMISSION, AUTO 4 SPD, THM 700 R4
MXO: MERCHANDISED, TRANS, AUTO PROVISIONS, O/D
NA5: EMISSION SYSTEM, FEDERAL, TIER O
NP5: LEATHER WRAPPED, STEERING WHEELAND SHIFT ****
N33: STEERING COLUMN, TILT TYPE
N64: WHEEL & TIRE,SPARE, SPACE SAVER, ALUMINUM
N96: WHEEL, 16 X 8, CAST ALUMINUM
QLC: TIRE ALL, P245/50ZR16/N BL R/PE ST TL HW4
TR9: LAMP, GROUP
TT4: HEADLAMPS, HALOGEN, 4
T93: LAMP, TAIL & STOP, SPECIAL
T96: FOG LAMPS - FRONT
UB3: CLUSTER, INST, OIL, COOL TEMP, VOLTS, TRIP ODOM, TACH
UQ1: RADIO PROVISIONS, FOR STEREO
UX1: RADIO, AM/FM STEREO, CASSETTE, EQUALIZER
U25: LAMP, INTR, RR COMPT, COURTESY
U26: LAMP, INTR, ENG COMPT, COURTESY
U29: LAMP, INTR I/P, COURTESY
U75: ANTENNA, POWER, RADIO
U79: SPEAKER SYSTEM, 4, DUAL FRT COAX, DUAL EXT RGE PKG
VAN: ASSEMBLY PLANT, VAN NUYS. CA
V73: ANTENNA, FIXED
WW4: APPEARANCE PACKAGE, AERO#4
W62: ORNAMENTATION, AERO PACKAGE
Z28: MERCHANDISED PKG, SPECIAL PERFORMANCE
1AY: STOCK ORDERS PROCESSING OPTION (DEALER ORDERED CAR)
1SD: OPTION PACKAGE 04
1SZ: OPTION PACKAGE
15P: WHEEL COLOR SILVER METALLIC (91)
19Q: MOLDING COLOR (BLACK)
41U: PRIMARY COLOR, EXTERIOR, BLACK
6ZW: SPRING, COMPUTER SELECTED, FRONT, LEFT HAND
7ZW: SPRING, COMPUTER SELECTED, FRONT RIGHT HAND
8NL: SPRING, COMPUTER SELECTED, REAR, RIGHT HAND
81A: STRIPE COLOR, ACCENT, TWO TONE, RED/BLACK(91)
82C: TRIM COMBINATION, CLOTH, MED DK GRAY (C)(91)
821: INTERIOR TRIM, MED DK GRAY (91)
829: SEAT BELT COLOR, MED DK GRAY (91)
9N1: RR, INCREASED HEIGHT POSITION (SEO)
Old Aug 2, 2016 | 03:29 PM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
Re: How rare or common is my Camaro?
Not very rare.
Old Aug 2, 2016 | 03:31 PM
cheves's Avatar
Car: N/A
Engine: N/A
Transmission: N/A
Originally Posted by chazman
Not very rare.
That's what I thought.
Old Aug 2, 2016 | 03:43 PM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
This is from the top of the forum; https://www.thirdgen.org/1989-chevy-camaro/ As for a free car fax, really? Who gives anything away for free. BTW. looks like a very nice well kept car. How many miles on it. est.?
Old Aug 2, 2016 | 05:03 PM
cheves's Avatar
Car: N/A
Engine: N/A
Transmission: N/A
I know, I used to have a friend that had unlimited access but I lost contact.
It has It has 65,000 on the odometer but I don't know if is 65 or 165.
Thats why I want the carfax
Old Aug 2, 2016 | 09:20 PM
red rock's Avatar
Car: 1987 iroc
Well it might be worth while to you to pay and get one. If you do, let me know if the miles are close or not. I did a carfax on my Camaro, but I am still not sure if the miles are correct because if the car doesn't go to a certified car dealer for repairs, the miles never get logged. So long story short, if my car wasn't logged for 5-6 years, and the speedometer was turned back, I don't know what it has on it.
Old Aug 2, 2016 | 09:35 PM
Thornburg's Avatar
Car: 1985 Camaro Z28 IROC
Engine: 5.0L TPI H.O. 215HP STOCK
Axle/Gears: GU6=3.42
Did anybody else notice there is not a B4Z code listed?
Old Aug 2, 2016 | 09:44 PM
JT's Avatar
JT
Community Administrator
It is a 1989.
Give these a look over:
https://www.thirdgen.org/forums/faq-...-car-iroc.html
and
https://www.thirdgen.org/forums/hist...ml#post2599820
Old Aug 2, 2016 | 09:46 PM
chazman's Avatar
Axle/Gears: BW 3.45
B4Z ended after '87. From '88 to '90 an IROC-Z had a Z28 code.
Old Aug 2, 2016 | 09:47 PM
cheves's Avatar
Car: N/A
Engine: N/A
Transmission: N/A
Good info!
I almost **** my pants thinking it wasnt a true iroc
Old Aug 3, 2016 | 07:14 AM
mrestrictrplate's Avatar
Car: 87 Iroc 5.7,67 SS Camaro,90 Formula
Engine: 355 AFR Superram LPE 219
Transmission: 700r4 3000 stall 4spd 5 spd
I'm not sure on the year but the carfax and other companies only go back a certain amount of years for mileage and accident reporting. You can try a service dept at a chevy dealer to see reported miles years ago if they serviced at the dealer. I'm a finance mgr at a dealer and ran a carfax on one of my 87's and it only went back to 2000 I think.
Old Aug 3, 2016 | 08:38 AM
cheves's Avatar
Car: N/A
Engine: N/A
Transmission: N/A
I have a MYCARFAX account ans this is what is showing...
06/21/2016 185,872 California Passed emissions inspection
06/20/2016 185,782 California Failed emissions inspection
06/19/2016 185,722 California Failed emissions inspection
06/19/2016 169,550 W AC Drain & Refill Engine Oil
06/18/2016 185,652 California Failed emissions inspection
06/18/2016 167,945 Primo Tire Rotate Tires
02/06/2015 65,113 Handy J Oil and filter changed
01/19/2015 62,126 California Passed emissions inspection
10/15/2011 61,417 California Passed emissions inspection
01/11/2011 59,370 California Passed emissions inspection
06/08/2002 59,175 California Passed emissions inspection MILEAGE INCONSISTENCY
10/01/1999 153,855 California Passed emissions inspection MILEAGE INCONSISTENCY
09/27/1997 35,422 California Passed emissions inspection
10/17/1994 102,260 California Passed emissions inspection POTENTIAL ODOMETER ROLLOVER
1989 0 Original Manufacturer
And the car is showing 69,700, the guys at the smog inspection messed up and typed 185,xxx
Old Aug 3, 2016 | 09:06 AM
GASPEDDLER's Avatar
Mistakes are made on older cars all the time, it's just assumed that no 30 year old car could possibly have less than 100k on it regardless of condition. I had my oil changed at a neighborhood quik lube last year and he entered 114k instead of 14k. I caught it while paying and was told the owner would have to change the entry in their system and he was not in. It took several calls that day but eventually I was able to pick up a corrected receipt for my records. I only hope that their data does not make it into the "database" but if it does I have my receipt copies to back up my mileage. By the way my carfax goes back to June '89 the month my car was first sold and registered. Post some pics of your engine bay and interior, this will help the membership to establish your mileage to some degree.
Old Aug 3, 2016 | 09:38 AM
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
I would guess the only time that vehicle mileage would make it into a govt. database would be for things like mileage recorded at the time of state inspections, title transfers, yearly state registrations... and possibly through insurance companies. I know in my state I'm required to enter the mileage each year for registration. I can't imagine an oil change shop would be required to log that information anywhere official other than for their own records.
I wonder if you can find out the title, inspection and registration history as it pertains to yearly mileage recorded for your car through a local state DMV center? That's where I'd start if I was curious about actual mileage.
Old Aug 3, 2016 | 11:15 AM
cheves's Avatar
Car: N/A
Engine: N/A
Transmission: N/A
Here in Cali everybody reports to Carfax.
I got a Vehicle*History*Report from the DMV and it has no major information that can help me.
Print
CALIFORNIA*DEPARTMENT*OF*MOTOR*VEHICLES ***CUSTOMER*RECEIPT*COPY*** REGISTRATION INFORMATION*REQUEST 08/03/201
R62R04001304A3JGW783
DATE: 08/03/16 TIME: 06:29
INSURANCE INFORMATION ON FILE
REG VALID FROM: 09/26/15 TO 09/26/16
LIC#:XXXXX YRMD:89 MAKE:CHEV BTM :CP VIN :1G1FP2188KL182529
R/O :MY NAME
RCID:07/12/16 OCID:07/12/16 LOCD:3
TYPE:11 POWR:G VEH :17 BODY:0 CLAS:AC *‐YR:16
REC STATUS:
07/14/2016 ADDRESS CHG RENEWAL NOTICE
07/14/16 SMOG DUE 09/26/17
10/17/94 PREV LIC S525619
CLEARANCE INFORMATION RECORDS:
OFFICE WORK DATE TECH/ID SEQ # VALUE FICHE DATE TTC
610 10/19/11 C9 6021 00000.00 10/22/11 F00
610 10/17/12 J7 0001 00111.00 10/19/12 H05
610 10/17/12 J7 5001 00068.00 10/19/12 H05
610 02/05/15 L7 0011 00323.00 02/07/15 H00
610 05/07/14 06 0019 00141.00 PRIOR SUSPENSE
662 06/16/16 09 0021 00203.00 06/16/16 RIP
662 06/03/16 14 0025 00203.00 PRIOR SUSPENSE
662 06/17/16 14 0009 00203.00 06/17/16 SIP
662 06/16/16 09 0021 00203.00 PRIOR SUSPENSE
183 07/12/16 05 0011 00203.00 07/14/16 F00
662 06/17/16 14 0009 00203.00 PRIOR SUSPENSE
183 07/12/16 05 6011 00000.00 07/14/16 F00
02/08/1996‐ODOMETER: 115,509 MILES ACTUAL MILEAGE
Old Aug 3, 2016 | 11:32 AM
GASPEDDLER's Avatar
Yup, my carfax shows service visits to the Chevy dealer as well local oil change centers.
Old Aug 3, 2016 | 03:38 PM
cheves's Avatar
Car: N/A
Engine: N/A
Transmission: N/A
X2
Old Aug 3, 2016 | 08:54 PM
Thornburg's Avatar
My apologies I'm still learning about 3rd Gen's and here I am learning something new, so thanks for the correction and the links....
So how about some interior pics, and engine bay��
camaronut88z28
Sep 27, 2016 01:24 PM
dcarstens
Sep 20, 2016 03:39 PM
cheves
Aug 30, 2016 06:16 PM
dragonasylum
Carburetors
Jul 26, 2016 04:23 PM
mrestrictrplate
Interior Parts Wanted
Jul 22, 2016 12:32 PM
