Build sheet location??
Old Apr 1, 2018 | 03:40 PM
dagwood's Avatar
Top Answer: 1
Car: 1986 Camaro Drag Car
Engine: 383 on Ethanol
Transmission: Automatic
I was just curious where the build sheet would be located in my 82 Z28??? I've had the rear seats out and it wasn't under there. Also, my car doesn't have the RPO sticker in the center console.....don't know what the hell happened to it. There's zero trace of it ever even being there. I looked in the little rear compartment, too, and nothing...
Old Apr 1, 2018 | 04:15 PM
gt4373's Avatar
Transmission: 5-Speed Manual
Re: Build sheet location??
It May Not Even Have One ,They Weren't Required To Be Left In The Car. Most Were Thrown In The Trash On The Assembly Line.
Old Apr 1, 2018 | 04:52 PM
Drew's Avatar
The SPID didn't start until 84. 82-83 never had them. There's a good chance there's a build sheet between the springs and the seat foam of the passenger's front seat. Usually they're more than a little shredded. Other popular places are between the carpet and floor pans, often perma-bonded to the floor. Most of the ones I've found are illegible. I've pulled entire interiors out of multiple thirdgens, most don't have one at all. I wouldn't even bother tearing a car apart to try to find a build sheet, most of the time you'll just damage the car and find nothing.
There should be a tin tag riveted to the radiator support that will have major options and colors stamped in it. 82-85ish.
My 83's build sheet, removed in 1996.
Old Apr 1, 2018 | 05:08 PM
dagwood's Avatar
Top Answer: 1
Hmmmm good to know! THANK YOU VERY MUCH!!
Old Apr 1, 2018 | 05:12 PM
dagwood's Avatar
Top Answer: 1
Here's the radiator support tag. Not sure what all info is on here..
Old Apr 1, 2018 | 05:26 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
my '82 had the build sheet under the carpet under the driver's seat-it was in good condition,3/82 VanNuys car.
Old Apr 1, 2018 | 05:42 PM
dagwood's Avatar
Top Answer: 1
Mine is also a Van Nuys car. I'll take a look! Thanks!
Old Apr 1, 2018 | 08:34 PM
Drew's Avatar
C = 1982
09B = 2nd Week of September
1FP87 = Chevy, Camaro, 2DR
L = Van Nuys, CA Assembly Plant
211934 = Body Number
79B = Interior Trim - Dark Claret Standard Cloth
16L = Lower Color Silver Metallic
16U = Upper Color Silver Metallic
W = Paint Type - Water
AR9 = Relining Seats
The rest isn't on the sheet I have handy at the moment.
Here's another I found in a parts car... You can kinda see why I don't bother looking for them. LOL
Old Apr 1, 2018 | 08:42 PM
dagwood's Avatar
Top Answer: 1
Thanks man!
Yeah it doesn't look like those build sheets hold up at all lol
Old Apr 1, 2018 | 09:34 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
2nd week of September-that is a very late build '82-I think regular '82 production started in November '81.
Old Apr 1, 2018 | 09:41 PM
dagwood's Avatar
Top Answer: 1
Yeah I guess it is! I've seen a lot of 82s with blue engines, too.....mine is black and 100% original. Do you guys know what the story is with the blue engines compared to black ones?
Old Apr 2, 2018 | 12:56 AM
z28cop's Avatar
Car: 1985 IROC-Z
Engine: L69
Axle/Gears: 373 Limited Slip
Black engines started into production late in the 82 model year. My 82 was one of the last built Sept. 82..they ran a long model year, it was built with the black engine.
Old Apr 2, 2018 | 07:02 AM
PurelyPMD's Avatar
Car: 1987 IROC Original Owner
Engine: LB9
Transmission: M39 MM5
Axle/Gears: G80 G92 J65
The one in my 87 IROC was in the foot well area of the back seat, drivers side under the carpeting - Norwood car.
Old Apr 2, 2018 | 07:28 AM
daveb123's Avatar
Car: 82 Z28
Transmission: BW T-10
The build sheet on my '82 was in the webbing of the driver's seat lower cushion. 5/82 Van Nuys car. I've never seen an '82 with a black engine, but 09C would definitely be one of the latest ones!
Old Apr 2, 2018 | 08:38 AM
88IROCvertZ's Avatar
Car: 1988 IROC Z Convertible
Engine: 305 TPI (LB9)
Transmission: 700 R4
Axle/Gears: G80 GU2
Mine was in the webbing under the driver seat as well for the 88.. It was missing the corners which I couldn’t find but the info is all there.. was really tight up in there and wasn’t folded or anything.. tough to get it out without ripping it.
Old Apr 2, 2018 | 12:14 PM
JT's Avatar
JT
Community Administrator
What you show is not the master build sheet but a trim sheet. The master build sheet would have a listing of all RPO codes on the bottom along with billing/shipping dealership information.
Like Drew's example posted above:
Information wise, there's a big difference between the two.
Old Apr 2, 2018 | 12:29 PM
Drew's Avatar
Yeah, some of the build sheets trapped in the seats contain a lot more info than others. Early cars more than later cars. The other reason I don't bother looking for them, is that there isn't much on the build sheet I don't already know. The receiving dealership, which would generally be on the invoice, the gear ratio, broadcast codes for this or that part... IDK, they're just not terribly informative.
Old Apr 2, 2018 | 12:30 PM
Axle/Gears: G80 GU2
I did a search for what the sheet I found was and saw this image for a 1989 IROC.. I assumed since the RPO codes were in the console that maybe they changed the build sheet 88-90.. my mistake..
This is what I saw in a google Image search:
Old Apr 2, 2018 | 12:32 PM
Axle/Gears: G80 GU2
I’ll have to check my other seats.. if it’s anywhere I don’t have to rip the interior apart that’s as far as I’ll go looking
Old Apr 2, 2018 | 12:59 PM
JT's Avatar
JT
This is a better example of a buildsheet. It's the buildsheet from Scott's 1987 IROC-Z. This is the buildsheet that most people inquire about because it contains all RPO codes as well as dealership information. That information will not be on the other trim sheets that are sometimes found within the car.
The cars have different buildsheets per car and, as many have said, they were frequently thrown out before the car was sold. I refer to the above as a "master" buildsheet because it has the amount of information that it has. The others, like your example, have sometimes been referred to as trim sheets.
Old Apr 2, 2018 | 03:14 PM
Axle/Gears: G80 GU2
Thanks for the info! It’s a bummer that early third gens didn’t have the RPOs in console.. I never knew that either.. Never owned one earlier than 85
Old Apr 4, 2018 | 08:26 PM
Motown's Avatar
Car: 1985 IROC-Z
Engine: LB9
Transmission: MD8
Found mine last fall. Under a split in the carpet, under the drivers seat. Virtually perfect.
Built May 1st 1985, Norwood.
Old Apr 4, 2018 | 09:53 PM
daveb123's Avatar
Car: 82 Z28
Here's the build sheet from my 82, Van Nuys 5/4/82
Old Apr 30, 2018 | 03:18 AM
ohio28's Avatar
Car: 1985 Chevrolet Camaro IROC Z
Engine: LB9 305 Rebulit Original to the car
Axle/Gears: 3.42 RPO GU6
I was needing some help identifying the build date on my 1985 IROC? I had some Corbeau seats installed last summer before Camaro Fest in Bowling Green, KY. The mounts were too high so I had a shop lower the seat by a good 2" about 2 weeks ago. To my surprise, this build sheet was lying in the passenger seat! I just seen it this weekend. My Dad and Mom purchased this car for me in February of 1985, so family owned since then. In my name now, and my Dad's at original purchase. I was super thrilled to see this. I think it is is pretty pristine shape for a 33 year old piece of paper.
If anyone has knowledge of the codes, or how to read this, I would appreciate!
Old Apr 30, 2018 | 07:22 AM
daveb123's Avatar
Car: 82 Z28
Wow, that looks great! The build date is the lower line in the upper left box, so 12/11/84 in your case. I've always wondered how accurate it is as far as when the car came off the line, but it's a awesome part of your car's history!
Old May 1, 2019 | 10:23 PM
67restoproj's Avatar
Car: Players Challenge 1LE-R7U
Engine: LB9
Transmission: 5spd
1988 Iroc Players Series Camaro
Old May 1, 2019 | 10:39 PM
JT's Avatar
JT
That is a trim sheet and not the master build sheet. The master build sheet will list all RPO codes near the bottom along with the dealership who ordered the vehicle. In addition to the top containing a lot of other codes for production.
Jason E
Aug 20, 2009 06:12 PM
Steve86TA
Nov 24, 2006 08:02 AM
1bad86
Jul 2, 2006 02:59 AM
1BadGTA
Apr 1, 2003 03:32 PM
kizz
Feb 27, 2003 12:06 PM
