Hey all, I'm looking to fill in a couple blanks here...
Old May 24, 2018 | 10:39 AM
NewTo3rdGens's Avatar
These are the RPO codes I found on my sticker. I've decoded most of them but there's a few I can't seem to find any info on when I Google them. Hoping someone here can help fill in the blanks! Also is it just a T/A with the WS6 option added, or is it a formula? I realize this is probably one of those tired ol' questions but I'm more familiar with first gens than I am the 3rd gens so I appreciate the patience!
Old May 24, 2018 | 01:10 PM
x55Cam's Avatar
Car: 1989 IROC Camaro
Engine: 5.7L
Re: Hey all, I'm looking to fill in a couple blanks here...
Here are some:
WW2 Aero Package #2 Silver
W62 Aero Package
Z49 Mandatory Canadian Base Equipment Modifications
191 Interior Trim, Black
199 Safety Belts, Black
81Q Molding Color Bright Red
U25 Lamp, Luggage Compartment
D35 Mirror, Outside Rear View
GU4 Axle, Rear 3.08 Ratio
J50 brake Sytem, Vacuum Power
Old May 24, 2018 | 03:00 PM
PurelyPMD's Avatar
Car: 1987 IROC Original Owner
Engine: LB9
Transmission: M39 MM5
Axle/Gears: G80 G92 J65
1987?
Old May 24, 2018 | 03:36 PM
x55Cam's Avatar
Engine: 5.7L
Originally Posted by PurelyPMD
1987?
Year would certainly help. The codes I looked up were for an '89
Old May 24, 2018 | 04:26 PM
My bad guys it's an 88.
Old May 24, 2018 | 06:56 PM
PurelyPMD's Avatar
Engine: LB9
I'm surprised it has the M39 T-5 instead of the MK6 one - I thought all of the LB9/5spds got the MK6 in 88 & up unless it was a convertible.
Old May 24, 2018 | 10:59 PM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
Usually MK6 =3.45/3.42 gears and M39 = 3.08 gears.
Old May 25, 2018 | 02:41 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
The 2.74 first gear rumor died HARD.
It's time to put this one to rest as well.
Old May 25, 2018 | 05:45 AM
PurelyPMD's Avatar
Engine: LB9
Thanks Charlie.
Put what to rest?
Old May 25, 2018 | 10:54 AM
It's filling in, so I take it that it's just a T/A opposed to the formula trim?
Old May 25, 2018 | 11:06 AM
JT's Avatar
JT
Community Administrator
Yes, it's a Trans Am and not a Formula. Formulas will have RPO W66. They will also have a completely different VIN prefix of 1G2FS.
Old May 25, 2018 | 11:19 AM
x55Cam's Avatar
Engine: 5.7L
C95 - Dome and Reading Lamp
Edit: these have to be verified ,
6ZX : SPRING, COMPUTER SELECTED, FRONT, LEFT HAND
7ZX : SPRING, COMPUTER SELECTED, FRONT, RIGHT HAND
D5V : GEAR, SPEEDO DRIVEN
BV3 : ORNAMENTATION, INTR, I/P, BLACK
BY4 : ORNAMENTATION, INTR, INST PANEL, NAME PLATE
UF6 : LAMP, INTR, CONSOLE, COURTESY
YT1 : BUILD UP DR & QTR
Old Jun 1, 2018 | 01:24 AM
shiftman's Avatar
Hi "NewTo3rdGens",
Could you take a photo of the Service Parts Identification (SPID) label from your Trans Am and then post it here?
I believe that it is adhered to the inside of the center console. (between the front seats)
Thank you.
Old Jun 1, 2018 | 09:39 AM
Originally Posted by shiftman
Hi "NewTo3rdGens",
Thank you.
Old Jun 1, 2018 | 09:48 AM
chazman's Avatar
Axle/Gears: BW 3.45
Thanks Charlie.
Put what to rest?
It was rumored for years that the MK6 had a 2.75 1st gear rather than the 2.95 1st gear ratio it actually has.
These rumors were started because GM's own literature stated it and every magazine copied and pasted it. I believe that it was a misprint repeated over and over. Even today, you can go to the GM Heritage site and look up '89 Camaro specs and see it written there in GM docs.
Old Jun 1, 2018 | 02:38 PM
PurelyPMD's Avatar
Engine: LB9
Nobody had said anything about 1st gear. But now that I know, I'd be more than happy to tuck it in & turn out the lights.
Old Jun 1, 2018 | 02:59 PM
chazman's Avatar
Axle/Gears: BW 3.45
cjames9001
Aug 5, 2010 09:05 AM
thegooseman
Southern California Area
23
Jan 12, 2009 11:00 AM
85_TA_WS6
Feb 26, 2005 07:19 AM
86TpiTransAm
Jan 3, 2002 11:37 AM
