88 formula 5.7
Old Jan 1, 2019 | 11:57 AM
Bobby Suth's Avatar
Car: 1990 firebird,1989 Iroc z,1986 fire
Engine: 3.1lt,5.7tpi,3.1mpfi
Transmission: auto,auto
Axle/Gears: 273?277
88 formula 5.7
Can't find numbers for how many 5.7 formulas were made. If there were 12000 total GTA ta and formula 5.7 built and 6800 of them were GTA hard tops. That only leaves about 6000 formula ta and t top gta's left. Most of them I would think to be ta and GTA t top. So 1 or 2k formula should be it. I gotta g92 car with 103k factory Maui blue. I'm working to semi restore. Vin is a 5.7. it's ws6 with 3.27 be disk rear. Hard top low option. Factory engine and harness gone. Seats carpet console all gone. No rpo codes. I will need slots help
Old Jan 1, 2019 | 12:04 PM
Drew's Avatar
Re: 88 formula 5.7
That would be an option combination, W66 + L98 or W66 + B2L. GM never kept track of combinations. That leaves you options like Compnine or other such services that crosscheck an archive of invoice data. Put simply, you're getting a calculated "best guess", if anything. You could make up a random number and it'd have as much truth as a number from the next guy.
Old Jan 1, 2019 | 12:26 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
Re: 88 formula 5.7
The quantity made isn't a problem. Rpo codes for a car similar would be great. Manual windows hatch pull down.. Thanks drew for the input.
Old Jan 1, 2019 | 04:11 PM
BizJetTech's Avatar
Re: 88 formula 5.7
FYI - According to Robert Casey's book "Pontiac Firebird Colors, Codes and Quantities" 2613 L98 Formula's were made and
2846 total (both L98 & LB9) silver-blue Formulas were built. The book also states G92 was available ONLY on the Trans Am
with the LB9 engine and 5 speed trans in 1988 and only 31 units were built
Old Jan 1, 2019 | 04:15 PM
BizJetTech's Avatar
Re: 88 formula 5.7
Here is my 1988 Formula 350 SPID tag - my car has manual windows and mirrors but does have A/C and cruise control
Old Jan 1, 2019 | 07:36 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
Re: 88 formula 5.7
The 9 bolt be with disk brakes has a factory tag that says 3.27 on it. I've not taken the cover off to count or looked at the production stamp. But it's not been changed out. All the bolts and lines haven't been messed with. It's definitely a factory installed. The car only has 103000 miles on it. Any chance they skipped one by?
Old Jan 1, 2019 | 07:38 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
Re: 88 formula 5.7
my car has same. My car also had trans am style rim's on it. Not the 20 slots with the rivets. I don't get why someone would put a aggressive rear end in it if it already had a posi in it then take complete interior out. Then put a 80 model 305 carbureted engines in place of the factory 5.7
Old Jan 1, 2019 | 08:12 PM
BizJetTech's Avatar
Re: 88 formula 5.7
Sorry, but your car can't have G92 if it's an 88 Formula, it's as simple as that.....3.27 (GW6) was included on all 88 Formula 350's to the best of my knowledge.
Old Jan 1, 2019 | 08:14 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
Re: 88 formula 5.7
How reliable is the author of the book? I'd like to get one if it's a good source. Thanks for the info. I'm not trying to be a butt head. It's sad what some people do to these cars.
Old Jan 1, 2019 | 08:17 PM
BizJetTech's Avatar
Re: 88 formula 5.7
IMO, the book is highly accurate and the author is a member here.
I recommend picking one up, you can get it on Amazon. I reference mine a lot - good luck
Old Jan 1, 2019 | 09:34 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
Re: 88 formula 5.7
My bad!😅 I thought g92 was rpo for 3.27 gears. Gw6 is the rpo for 3.27. what's a g92?
Old Jan 2, 2019 | 09:16 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Re: 88 formula 5.7
Actually GM DID keep track of the number of Formulas that had the 350, and the number of Trans Ams with the 350, and the number of GTA's with the 350 in 1988... I have the actual Log from GM
Old Jan 2, 2019 | 10:17 AM
Drew's Avatar
Re: 88 formula 5.7
Old Jan 2, 2019 | 10:27 AM
okfoz's Avatar
Re: 88 formula 5.7
lol
Some years, you are absolutely correct, they no longer exist or they never did...
I have generic logs for 82-85 and 87... But detailed logs for 86, 88-90...
Old Jan 2, 2019 | 02:00 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
Re: 88 formula 5.7
What's your log say?
Old Jan 2, 2019 | 02:54 PM
okfoz's Avatar
Re: 88 formula 5.7
For 86, and 88-90 it is a complete Printout of all of the RPOs for the complete Firebird line, and it is broken out by Model, Firebird, S/E, Trans Am for 86, and Firebird, Formula, Trans Am and GTA for 88-90
It also gives better more accurate descriptions of the RPOs and what they mean...
It is in old Dot Matrix... lol
John
Old Jan 2, 2019 | 03:20 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
Re: 88 formula 5.7
Most of my rpo codes would be the same as what is on the slid post. My car is blue over silver. What's the rpo?
Old Jan 2, 2019 | 03:46 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
Re: 88 formula 5.7
Car has been repainted at some point. You can see the factory blue in the engine compartment. I've got front clip off. Going to get the doors and hatch off to.
Old Jan 3, 2019 | 09:04 AM
okfoz's Avatar
Re: 88 formula 5.7
23U is the Silver Blue Metallic (Maui Blue for Camaro) and I think 13L is the Lower stripe color.
John
Old Jan 7, 2019 | 07:31 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
Re: 88 formula 5.7
I tried books a million. They can't get it. I don't do Amazon and eBay type stuff either. Any way to get a book from someone on third gen?
Old Jan 8, 2019 | 07:34 AM
okfoz's Avatar
Re: 88 formula 5.7
Amazon Amazon
Old Jan 8, 2019 | 06:17 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
Re: 88 formula 5.7
Amazon. I have no credit cards. I will check into it
Old Jan 8, 2019 | 06:57 PM
BizJetTech's Avatar
Re: 88 formula 5.7
How about using PayPal ??
Old Jan 8, 2019 | 09:34 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
Re: 88 formula 5.7
I'm a basket case. I've never used PayPal. I've heard some about it.
Old Jan 9, 2019 | 08:36 AM
okfoz's Avatar
Re: 88 formula 5.7
PayPal is safer than using a Credit Card according to my Credit Union.
tpi-hearse
Exterior Parts for Sale
104
Jun 18, 2008 11:39 AM
CamaroFreak406
Jul 16, 2003 07:31 AM
V6camaroman
Jan 1, 2003 09:25 PM
89FormulaL98
Mar 3, 2001 03:56 PM
