True 1989 IROC-Z? NO Z28 RPO?
Car: 1989 IROC-Z
Engine: 6.0 Turbo LS (LQ4)
Transmission: 4L80E (Manual Valvebody)
Hey guys, having a bit of an existential crisis right now;
My 1989 Camaro (hopefully IROC-Z) seems to be a bit of a odd basket of RPO codes. I am from Canada, so I know there was some weird dealership orders going on for these cars up here past the border, but this just seems odd. I have another 1989 IROC-Z, with the true Z28 RPO code that verifies its authenticity, but this one lacks that code as well. I saw a thread from another member made all the way back in 2006 that showed a dealership specific 1989 IROC-Z that lacked the rpo's for it due to it being a special order, maybe this is the same case? The 8th VIN spot is an E, which for this model year could designate an RS, or an IROC-Z. All of the badges when I purchased it were there, saying IROC-Z. It also has the Wonderbar, and a 9 bolt rear end, just like my other one. Here are my RPO's, if anyone wants to try and help me out here.
AM9, AR9. AU3, A01, A31, A90, B18, B34, B35, B48, B84, CC1, CD4, C49. C60, DC4, DX3, D27, D35. D42. D6D, D80, E5Z, E7Z, E9Z, FE1, GU2, IP2, J50, K34, K60, L03, MD8, MX0, NB2, NK3, N33, N90, QPH, R6C, TR9, TT4, UA1, UB3, UQ1, UX1, U25, U26, U29, U79, VAN, VG8, VK3, V73, WW8, W62, YA7, YF5, 1AY, 1SD, 1SZ, 16P, 6XU, 7XU, 72I, 722, 729, 81Q, 81U, 8UY, 9UY
Thanks, Ryan
Thanks, Ryan
Car: 1988 IROC Z Convertible
Engine: 305 TPI (LB9)
Transmission: 700 R4
Axle/Gears: G80 GU2
Re: True 1989 IROC-Z? NO Z28 RPO?
Does is have the decals? Because it looks to have stripe and decal delete DX3.. I believe RS Camaros all had DX3.
Axle/Gears: G80 GU2
AM9 Split rear seats
AR9 Front bucket seats
AU3 Power Locks
A01 Tinted Glass
A31 Power Windows
A90 Power Hatch release
B18 Deluxe interior
B34 front mats
B35 rear mats
B48 Luggage compartment trim
B84 Body side moldings
CC1 T-tops
CD4 intermittent wipers
C49 rear defrost
C60 A/C
DC4 mirror with reading lamps
DX3 decal and stripe delete
D27 locking rear storage
D35 external mirrors
D42 cargo cover
D6D speedometer driven gear
D80 spoiler
E5Z speedometer adapter delete
E7Z VSS delete
E9Z speedometer key delete
FE1 soft ride suspension
GU2 2.73 axle
IP2 leather seats reclining
J50 vacuum power brakes
K34 cruise control
K60 100 amp alternator
L03 305ci engine 170hp
MD8 700 R4 Automatic
MX0 Auto with overdrive
NB2 California Emissions
NK3 simulated leather steering wheel
N33 tilt steering wheel
N90 15” aluminum wheels
QPH 245 50R 16 tires (non Z rated)
R6C sales control code
TR9 auxiliary lighting
TT4 halogen headlamps
UA1 Heavy duty battery
UB3 instrument cluster (batt, oil, temp, tach)
UQ1 stereo installation
UX1 radio cassette, clock, s/s eq
U25 luggage lamp
U26 engine lamp
U29 courtesy lamps
U79 front speakers
VAN Van Nuys assembly plant
VG8 buyer label notice
VK3 license plate bracket front
V73 VIN plate
WW8 aero package #8 bright red
W62 aero package
YA7 California emission test
YF5 emission equip
1AY dealer ordered car
1SD option package 4
1SZ discount option package
16P wheel color (white)
6XU spring left
7XU spring right
72I interior dark carmine
722 Leather dark carmine
729 seat belt dark carmine
81Q bright red molding
81U exterior bright red
8UY rear left spring
9UY rear right spring
AU3 Power Locks
A01 Tinted Glass
A31 Power Windows
B18 Deluxe interior
B34 front mats
B35 rear mats
CC1 T-tops
C49 rear defrost
C60 A/C
D42 cargo cover
D80 spoiler
E7Z VSS delete
GU2 2.73 axle
K34 cruise control
U25 luggage lamp
U26 engine lamp
U29 courtesy lamps
U79 front speakers
V73 VIN plate
W62 aero package
YF5 emission equip
6XU spring left
7XU spring right
Engine: 5L TPI
Transmission: WCT5
All 89 Z's were TPI weren't they? Smells like you have an RS, but apparently at least one with an LS haha. Where abouts in Canada are you from?
Axle/Gears: G80 GU2
I’m leaning towards a fully loaded RS..
I’m assuming someone might have swapped the interior badge to say Z28/IROC-Z, swapped the RS steering wheel, and swapped the rocker/bumper emblems.
If it has the decals that would be a giveaway because this is a decal delete car.
I also assume most people ordering IROCs with the decal delete would want the car to be a sleeper, so they’d get the TPI 350 or G92 LB9 5-speed TPI and order the stripe delete to have a “sleeper”.
It wouldn’t make sense to me to order the 170hp motor and the stripe delete and be completely indistinguishable from an RS externally or under the hood.
Axle/Gears: G80 GU2
Transmission: World Class T-5
Axle/Gears: BW 3.45
Engine: 5L TPI
Transmission: WCT5
It would be strange to fully load a Z but lack with the power dept. It's tough to tell on my screen, but if the car in question is the one in his profile pic, those headlight buckets look colour matched
It's an RS. The "Base" Iroc in 88-89 was barely an Iroc, but it still would have had the FE2 suspension. FE1 was pretty much reserved for base model cars, with F41 being in the middle.
GU2 is also a 10 bolt 2.73 ratio.
The only gotcha to watch for is that the VIN on the SPID matches the VIN of the car, since console armrests are often changed you can get a SPID from another car pretty easily.
Car: 1989 IROC-Z
I'm from Vancouver Island, farthest west you can go. The sad part about this whole thing is my parts car was a loaded L98 car that had been beefed with a high-flo intake, Edelbrock RPM Performer heads, and a ***** Thumpr Cam. Both the cars have 3" headed into a hushthrush, and then out of dual 3.5" chrome tips. I can live with it being an RS, but as far as we're all concerned my badges are authentic... lol. Thanks guys.
Car: 1989 IROC-Z
I will make a post on this thread with all of the weird stuff on this car when I am back from school. I am 17 and nearly work full time, I haven't had much time to investigate this. I am doing a 67 Nova 2Dr Post and I just finished my LS swap on the "IROC", but this is very strange. The story behind the car is too, but we'll talk about that later.
Car: 1988 IROC-Z
Transmission: T56 swap ongoing
Axle/Gears: 2.77 9-bolt Posi
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Axle/Gears: G80 GU2
springer4
Nov 5, 2012 09:46 PM
