Sunshade
Old Sep 30, 2019 | 04:22 PM
AF Chief's Avatar
Sunshade
Trying to get some info on this set of rear window louvers. Can't find it in any of my books or any reference to it online. p/n 12340070 and all metal. Any help greatly appreciated.
p/n
Old Sep 30, 2019 | 05:10 PM
dagwood's Avatar
Top Answer: 1
Car: 1986 Camaro Drag Car
Engine: 383 on Ethanol
Transmission: Automatic
Re: Sunshade
Send a pm to socalkidd
He has those louvers on both of his Camaros
Old Sep 30, 2019 | 05:13 PM
Drew's Avatar
Re: Sunshade
Factory louvers. That part number isn't in the 11/92 Firebird P&I catalog. I'd expect that's because it's an earlier or later part number. GM liked to change part numbers for minor changes. From the instruction sheet, looks like they don't have provisions for a high mount third brake light, so they're not for 86 or 91-92.
Old Sep 30, 2019 | 05:23 PM
dagwood's Avatar
Top Answer: 1
Re: Sunshade
Wanna sell them?
Old Sep 30, 2019 | 05:28 PM
Drew's Avatar
Re: Sunshade
I had to dig a bit deeper in the book...
Old Sep 30, 2019 | 06:06 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
Re: Sunshade
Those are definitely factory window louvers. What did you want to know about them? Here's what they look like on the car.
Old Sep 30, 2019 | 06:30 PM
kentuckyKITT's Avatar
Car: 2 T-Tops
Engine: 327/305
Transmission: TH350/700R4
Axle/Gears: 3:42/2:73
Re: Sunshade
I've never seen a set "all metal" not even Cragar. I have a set of factory ones and the side caps are plastic with only the center section being aluminum. Did they exist with the side caps aluminum also? That part is curved, so I've often wondered. I put a set of OEM on my 89 Firebird and love them!
Old Sep 30, 2019 | 06:43 PM
Xavier99's Avatar
Car: 1985 Camaro Berlinetta (78,000Mi)
Engine: 305 with the E4ME Quadrajet
Re: Sunshade
This is my first comment on this forums so I hope this works I'm looking for louvers for my '85 camaro berlinetta, I'm wondering where the best place to start looking for some would be?
Old Sep 30, 2019 | 06:44 PM
Xavier99's Avatar
Re: Sunshade
They look amazing!
Old Sep 30, 2019 | 07:01 PM
scottmoyer's Avatar
Re: Sunshade
You can see the Cragar sits higher on the window than the factory set, but I think they were the closest to factory of all brands. All factory sets are aluminum center slats with ABS curved sides.
Old Sep 30, 2019 | 07:17 PM
AF Chief's Avatar
Re: Sunshade
Great!! Thank you,
Old Sep 30, 2019 | 07:23 PM
AF Chief's Avatar
Re: Sunshade
Sweet! But, they look like 1 piece louvers or is it just the camera angle (or my eyes....)
Old Sep 30, 2019 | 08:12 PM
scottmoyer's Avatar
Re: Sunshade
Once put together, they have a 1 piece look. The slats get glued to the ABS sides during installation, so they pretty much become 1 piece.
Old Sep 30, 2019 | 10:23 PM
Drew's Avatar
Re: Sunshade
The joints are visible from the right angles.
Having had three sets of louvers, the GM pieces are pretty easily the most thought out. I had an ABS set that were rattly garbage, and an older set that came off on the highway when the plastic hinges broke. The only louvers currently offered are of the ABS variety and look horrid.
Old Oct 1, 2019 | 07:47 PM
scottmoyer's Avatar
Re: Sunshade
Drew, are those the set you bought from me? Any issues putting them back together?
Old Oct 1, 2019 | 09:16 PM
ray jr's Avatar
Re: Sunshade
i see these for sale all the time when im searching for irocs .. the only ones i like are the ones on scotts car .. the cragars sit to high for my liking ..
Old Oct 1, 2019 | 10:37 PM
Drew's Avatar
Re: Sunshade
Yep, same ones. No issues really. Fresh coat of paint and they're good to go.
Wasn't too long ago I finally got around to tossing shipping boxes and happened to notice the key for the louvers taped to the packing. Almost missed it.
Old Oct 3, 2019 | 07:02 AM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Re: Sunshade
Has anyone seen or had a set of GM t-top sunshades?
Any info. out there?
These came in my 84.
Most lettering is worn off the sticker/plate on each except for the L&R letters.
Setting on the open roof before putting tops on.
Note the suction cup:
The sticker with the L&R print.
Note the suction cup ****.:
The GM ad I found on line:
Old Oct 3, 2019 | 08:11 AM
flippermtc's Avatar
Car: 88 IROC T-Top
Engine: 5.7
Re: Sunshade
I have the plastic GM sunshades. Nice pieces but the adhesive dosent hold & they rattle terribly. I ended up having a upholstery shop cover them with headliner material. Came out great & so quiet...
Old Oct 3, 2019 | 09:17 PM
scottmoyer's Avatar
Re: Sunshade
You may want to start a new thread with the ttop sunshades. This thread is about the rear window sunshade, or louvers as they are also known as.
Old Oct 4, 2019 | 05:34 PM
AF Chief's Avatar
Re: Sunshade
Yes,those are the same. Mine are still in the box so didn't realize the end caps were plastic. Bought these many years back when I still had my '88, since sold. There's a guy in our local car club wants to buy them, any idea what they're worth? I don't recall what I paid but do remember they weren't cheap.
Old Oct 4, 2019 | 05:42 PM
Car: 2 T-Tops
Engine: 327/305
Re: Sunshade
Were you referring to mine? Mine aren't Cragar....
Old Oct 4, 2019 | 06:08 PM
scottmoyer's Avatar
Re: Sunshade
I was not referring to your louvers. I was stating that it's clearly visible to see the height difference in the Cragar louvers. I think they were designed to fit cars with and without the rear wiper. Here's the Cragar louvers.
Old Oct 5, 2019 | 08:48 AM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Re: Sunshade
REMEMBER THE HEADING OF THIS THREAD SEZ "SUNSHADE" RIGHT scott?
FUNNY it DON"T mention rear louvers only thread correct?
SHEESH! Pick, pick, pick!
Its NOT like they are NOT related to blocking the sun from a third gen!
I suppose IF I started a NEW thread you would of been sniveling about "doing a search" right?
Old Oct 5, 2019 | 11:51 AM
Drew's Avatar
Re: Sunshade
"Not cheap" is accurate. My Iroc had the louvers from the factory, they're listed with the rest of the RPO codes, but the original louvers were long gone when I got the car in 1998. I finally got the set that's on there now a couple years ago from Scott. To say they're hard to come by is an understatement.
For an NOS set you can pretty much pick your price and eventually someone will pay it. Look at what relatively common NOS parts go for on Ebay, for some reference. If one of the usual suspects had a NOS set for sale, I'd expect the price would be astronomical. Wouldn't shock me to see a asking price cracking 4 digits.
Old Oct 19, 2019 | 08:05 PM
AF Chief's Avatar
Re: Sunshade
Thanks Drew. Good info.
dm3k
Oct 1, 2023 01:28 AM
fuchs
Exterior Parts Wanted
Sep 12, 2020 05:08 PM
Damoncaravanman
Oct 24, 2017 02:56 PM
tarouty
Jun 17, 2013 03:23 PM
wadeh
May 27, 2009 06:09 PM
