vin code confirmation
Old May 28, 2021 | 02:17 PM
windy's Avatar
Hi Guys, Im looking at a car with the possibility of importing to England. Ive checkd Chiltons manual, but there are a couple of diigits they dont mention.
1G2FS23E3NL******
so far I can find its a USA made GM, Pontiac, Firebird , made in Van Nuys
but the restraint digit isnt there.
body type 23, not in the book
engine code E not in my copy, closest is an F
N presume 1992 but car is advertised as a 94
can someone check please.
Old May 28, 2021 | 04:28 PM
JT's Avatar
JT
Community Administrator
Re: Build Sheet
1G2FS23E3NL******
The VIN is pretty clear. Whatever source you're using is pretty bad or you're making a mistake.
1 = USA built. A 1994 would have been built in Canada and would have a digit 2 instead of 1.
G = General Motors
2 = Pontiac
FS = Firebird (base or Formula)
2 = 2 Door Hatchback
3 = Manual Seat Belts
E = 305 TBI
3 = Check digit
N = 1992
Old May 29, 2021 | 01:55 AM
windy's Avatar
Re: vin code confirmation
just realised the Chiltons book Im using is 1982-1990 so probably changed layout after. misleading myself as looking at many cars, it is a 92 but has a sunroof not t tops just wondered if the roof was aftermarket or covered under the vin
Old May 29, 2021 | 06:20 AM
ktthecarguy's Avatar
On Probation
Car: 88 Camaro vert/86 SC
Engine: 355 tbi/2.8 V6
Transmission: 700R4/T5
Axle/Gears: 2.72 posi/3.42 open
Hi there,
GM never offered a sunroof on Firebirds or Camaros, so it is definitely aftermarket. With a 305 TBI engine, it could be a base model Firebird with the optional V8, or an entry-level Formula; they came with the E code engine as standard, and you could upgrade to the code F LB9 V8 (5.0l TPI engine) or the code 8 L98 (5.7l TPI engine). The SPID tag would be useful, did they give you that info?
Old May 29, 2021 | 08:36 AM
windy's Avatar
thanks for the replies. Im having second thoughts, it looks a nice clean car.
https://www.autotrader.com/cars-for-...ckType=listing
but cant remember where I saw it but a vin check showed up two accidents.
https://www.vindecoderz.com/EN/check...FS23E3NL208164
Sandy Sodini
Apr 18, 2021 09:43 AM
EatFordShtDodge
Feb 11, 2004 08:54 PM
maverick544
Jun 24, 2003 10:41 PM
davecamaro
Nov 20, 2002 10:48 PM
my$hercar
Jan 8, 2002 10:03 AM
