Should I Buy?
Old Nov 21, 2023 | 11:24 AM
Marcolanz00's Avatar
Should I Buy?
Apologies if this is the wrong thread, but this Camaro came up and is being offered to me for $2000. I am leaning toward yes. It is a running, 305 converted to carb. external aftermarket fuel pump. headers, with short exh pipes. comes with new carpet. Has digital dash. I hate that it doesn't have Ttops. It needs rims and tires, body work (but that can wait). I guess I am asking for advice on what to do. With the price of these cars going up a lot, I really don't want to pass on it. Does this deal seem too good to pass up?
Old Nov 21, 2023 | 12:04 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Re: Should I Buy?
There's a lot of custom work that you are going to have to decipher. It looks like a good price, and looks like a solid project car...budget & skillset permitting.
Old Nov 21, 2023 | 12:09 PM
Re: Should I Buy?
Thanks for the input. I am looking to enjoy it, and do some work on it with my son, and eventually give the car to him. I worry because it is a hard top, that I ned to be careful how much I invest. I can get rims and tires on thirdgen for a few hundred. Paint and body work is going to cost me 3-4K....thats a problem. Suspension, exhaust...because its a hard top is keeping me from saying yes already.
Old Nov 21, 2023 | 12:40 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Re: Should I Buy?
Looks like a good deal. And I hate T-tops...
Old Nov 21, 2023 | 12:54 PM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Re: Should I Buy?
Nothing there you cant fix. .A used hood, maybe some used Z28 wheels just a few things and youre on your way. 2K is fair for a running car with no rust. Drive it and build it along the way
Old Nov 21, 2023 | 01:12 PM
Re: Should I Buy?
I would think a hardtop would be a positive, not a detractor. That way you know you won't have leaks. It is a good price though.
Old Nov 21, 2023 | 01:32 PM
Firechicken82's Avatar
Car: 82 TA
Transmission: Magnum f
Axle/Gears: Ford 9 w 4.11
Re: Should I Buy?
I second the hard top comment. Having grown up w these cars, between leaks and flexing I'd go hard top all the way (I always have) The rust associated w t top leaks is miserable. It's hard enough to keep these cars from rusting as it is. It also hard enough to keep them from flexing. The roof is a significant structural component.
this car looks pretty rust free. It also has some stuff done to it. I can't tell the deal w the suspension. It looks like the tires are really small and that makes it look lifted. But it's hard to tell. In general the price is right. That said it's an old used car. I'd expect anything and everything w it. My 82 has had everything replaced/upgraded less the steering box. And that's next!
Old Nov 21, 2023 | 01:41 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Should I Buy?
The wheels and tires. Oof. It's not every day you see undersized R888R's on the worst vette wheel of all time. $2k is a solid price.
Old Nov 21, 2023 | 01:42 PM
Re: Should I Buy?
I really appreciate the feedback. The two Camaros I had were both T-tops and I loved taking them off in the summer. I understand the "pros" of the hardtop, and agree. Those wheels have to go. Here is another image showing the rear. sway bar and springs are upgraded. I may have to measure them to see if they are "lowering" springs.
Old Nov 21, 2023 | 01:44 PM
Re: Should I Buy?
I know.....I wasnt too sure what the mindset was going that direction!
Old Nov 21, 2023 | 01:46 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Re: Should I Buy?
It has the stock panhard rod so see if one rear wheel sticks out farther than the other side. That's a tell tale that a car was lowered. That sway bar was likely a rattle can rebuild as it doesn't look aftermarket. From the limited view it appears the dash pad is intact without any cracks. If so, that's worth hundreds of the $2k value alone.
Old Nov 21, 2023 | 03:41 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: Should I Buy?
Maybe an OK deal but few things are a bigger red flag than a carb conversion on a 305. Just screams I am too dumb to work on the car correctly so I hacked in a new carb
Old Nov 21, 2023 | 06:35 PM
Re: Should I Buy?
Originally Posted by midias
...few things are a bigger red flag than a carb conversion on a 305. Just screams I am too dumb to work on the car correctly so I hacked in a new carb
That's what would concern me. The engine, dash, wheels, etc. just give me the vibe that proper repairs weren't done correctly. I may be wrong, but that amount of "custom" scares me.
Old Nov 25, 2023 | 02:50 PM
Slammin's Avatar
Re: Should I Buy?
@Macolanz00 Your profile doesn't say where you reside. If the car needs to be smogged, that carb will cause you problems.
Old Nov 25, 2023 | 07:36 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Re: Should I Buy?
I'm thinking two grand for a solid third gen that's 90% complete is a deal. But you'll need to find a scrap/junk/upullit/recycle yard with a couple hulks for parts to complete. Good project.
Old Nov 25, 2023 | 07:55 PM
rhyno91's Avatar
Car: 1988 Pontiac Formula Firebird
Engine: None
Transmission: None
Re: Should I Buy?
When I was looking for a third gen project car, I specifically looked for hard tops due to the leaks and chassis flex associated with T-tops.
Old Nov 26, 2023 | 09:07 AM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
Re: Should I Buy?
Based on the pics provided, and if the car has a clear title, it's worth the $2K asking price. Would make a good basis for a project car.
Old Dec 1, 2023 | 06:53 AM
Re: Should I Buy?
I ended up passing on the car. Reasons listed here:
1) No T-tops. I understand he hardtop argument, but I am a T-top guy.
2) It needed rims and tires. That's a fairly large upfront cost, on top of other costs.
3) It needed exhaust. It had headers into a 3" down pipe. I leave for work sometimes at 4am. My neighbors would hate me. Again, another large upfront cost.
4) A few members here mentioned the amount of "custom" work done. I took this advice.
5) I have work that needs to be completed in my home, and I really don't have too much time or funds to invest right now.
Thank You All for the advice.
Old Dec 1, 2023 | 07:14 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Re: Should I Buy?
You made the decision that many of us should have made 25 years ago.
Old Dec 3, 2023 | 08:30 AM
rhyno91's Avatar
Engine: None
Transmission: None
Re: Should I Buy?
You made the right choice. If you decide to get one, you should have the extra money on hand and should get exactly what you want. The price of rarer third gens in good condition might be going up, but in my area I see rollers for a grand or less all the time. The market fluctuates and deals come and go, so don't spend extra money you don't really have to spend just because a deal pops up. There will be other ones.
Old Dec 4, 2023 | 07:35 AM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Re: Should I Buy?
True enough!
Old Jan 9, 2024 | 02:36 PM
Re: Should I Buy?
Well, I am VERY happy I did not purchase this vehicle. The gentleman I spoke to was nice enough, and the price came down quick because there was a need to sell. I had spoken to the man not too long ago and asked if he had sold it and he said he did. NOW it is listed AGAIN, same pictures, different person. Seems like a scam.
Old Jan 16, 2024 | 06:43 AM
Re: Should I Buy?
I am glad I didn't make this purchase. The car is now on "offer up", with the same pictures, but different person selling, but the ad says "my husband is now ill and can not work on his car that he had for a while".......scam?
Old Jan 16, 2024 | 03:59 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Re: Should I Buy?
"For a while" could be several days or so. Probably realized he got in over his head and realized finding parts to rebuild would be a nightmare.
Old Jan 16, 2024 | 09:34 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Re: Should I Buy?
Sounds like a flipper. Probably no scam just making some quick easy money. Be interesting to see if it sells. With that write up it might at that.
gt4373
Feb 28, 2022 03:00 PM
gt4373
May 11, 2018 11:08 PM
82camaroWI
Fabrication
Dec 7, 2008 12:35 AM
novadk13
22
May 13, 2004 06:29 PM
Demon Z28
Pacific Northwest Region
Jun 26, 2001 04:01 PM
