SLP PROM
Old Jan 23, 2025 | 11:13 AM
jkris53406's Avatar
Car: 87 Formula, 91 Trans Am
Engine: 355 tpi, 305tpi
Transmission: 700r4, 700r4
SLP PROM
I just picked up an ECM with an SLP prom.
It is labelled SLP A 1109.
Does anyone have any info on these?
TIA
Old Jan 23, 2025 | 12:57 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: SLP PROM
I scanned and posted some SLP catalogs, see if you can find them and a number matches any of the part numbers
Old Jan 24, 2025 | 01:47 PM
Mark_ZZ3's Avatar
Car: 1989 Camaro-1LE
Engine: TPI(s)
Transmission: 5 speed (MM5, MK6)
Axle/Gears: 3.45, 3.73
Re: SLP PROM
TIA
I was able to take one and read it ... compared with stock and other brands on the market. IMO, the SLP had the most number of changes in it. While fuel and spare were adjusted, other small changes were made. I can't recall the details .. would have to check later. My guess here is that SLP have access to GM's actually configuration files vs. everyone's else's table maps.
Mark.
Old Jan 24, 2025 | 05:20 PM
TTOP350's Avatar
Re: SLP PROM
This is an early catalog. What number ECM is it in?
Old Jan 24, 2025 | 05:39 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: SLP PROM
With gm performance parts and Slp having different part numbers for the same tune. You might have to read the bin and look
at prom if to identify usage.
Old Jan 27, 2025 | 10:03 AM
jkris53406's Avatar
Re: SLP PROM
It was in a 92 Trans Am, unfortunately. I looked at the other catalog stuff and it seemed like it was all for MAF cars.
Old Jan 27, 2025 | 01:14 PM
Engine: Lb9
Transmission: M20
Re: SLP PROM
Is there a knock filter behind the prom ?
Old Jan 27, 2025 | 02:36 PM
jkris53406's Avatar
Re: SLP PROM
Old Jan 27, 2025 | 02:52 PM
Engine: Lb9
Transmission: M20
Re: SLP PROM
Old Jan 29, 2025 | 08:51 AM
Engine: Lb9
Transmission: M20
Re: SLP PROM
If it does have a knock filter look at the white board. If the second digit is R a 350 tune. P it’s for a 305. But the only way to get more info is to do a chip read.
Old Jan 29, 2025 | 10:47 AM
jkris53406's Avatar
Re: SLP PROM
I haven't gotten to the shop to look, but it came from 91 350 car. Just wondering if anyone had what the tune might be. The car had the SLP dealer upfit sticker on the rad support with nothing punched. Engine/ trans/ exhaust were gone but was a VIN 8 car.
Old Jan 29, 2025 | 11:04 AM
Engine: Lb9
Transmission: M20
Re: SLP PROM
The closest tune I have is the 41020, I don’t know the difference
steven72192
Sep 2, 2013 11:33 AM
89fastlookinRS
Aug 24, 2002 08:46 PM
catmath 1911
Mar 16, 2002 09:15 PM
chevyboy07 91
Nov 6, 2001 10:31 PM
ADMZ24
Aftermarket Product Review
Oct 26, 2001 08:26 AM
