Preformance sound
Preimium sound
I have an emblem above the stero thet says premium sound what does this mean? I herd that it ment it had an amp built in. Is this true and is there any way to hook the amp up to a new cd player?
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
depending on the year, the performance sound came with a subwoofer hidden in the back hatch area just in front of the spare tire. There was also usually Subwoofer control on the dash to the left of the rear hatch defogger buttons. The option was around from somthing like 85 -88 or 89. I once saw 2 birds with the options and I did not grab any of the parts, I kick myself...
John
John
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Hmmmmph, never knew that. Was that available on Camaro's too??
Car: 87 trans am, 93 full size blazer
Engine: 5.0, 5.7
Transmission: A4
From what I remember, it wasnt even really that great as far as speakers go. I think the only change they did to the front speakers was a cloth grille instead of a plastic one. Dont know about the backs though.
The rear setup was a 4x6 and a little midrange that everyone is calling a sub--that's what mine had in it. Also the piece that the speakers sit in(rears)is a plastic housing of some kind--I guess that made the bass sound deeper--for those "booms".
This is from the 89 booklet on the standard sound
and the 88 booklet for the performance sound, which is also the last year offered...
The pic does not seem to show exactly where the speakers were located, but it indicates somewhere back in the wheel wells. The Amp location in the picture is not accurate since it was located in the dash, the reason for this is more than likely that the lines are to indicate a wiring diagram not the location of each of the parts.
hope this clears anything up, probably makes more questions than anything...
John
John
Guest
Posts: n/a
Sheesh...
The 'amp' is located behind the 'glove box' on the dash. Its a silver box as pictured above. The 'subs' are located in a large plastic enclosure that sits where a 6x9 usually sits on most other cars. In the plastic enclosure is also a 4x6 speaker. The 'sub' is a 4" speaker, thats why I call it a 'sub', its pretty much a joke IMO. I see in the pic above it says its 5 1/4", either my ruler is wrong or GM was being overly generous about what they put in there. The enclosure is ported and is probably the only reason it sounded even remotely good for an old factory stereo setup with such tiny speakers. The design of the setup itself never changed over the years it was available. IMO its not worth looking into getting if you dont have it, and mine has long since been replaced with some good 6x9's.
it is technically a "sub" but its designed for midranges, like in a component system. Thats what the performance sound is in these cars. a "component" set of a 4x6 and a midrange "sub". subs arent always 8, 10, or 12+ inches.
when i bought the car ther was a cd player hooker up. can i hook into the amp and the subs? I would really like to do this since the gain switch is so acessable. I think i found the amp behind the glove box.
Guest
Posts: n/a
You can, just have to wire it up right. It seems to me if you leave the factory wiring intact and hook up to the stock wiring the setup still works. I know I had it setup on my car with an aftermarket radio like that for a while until I came to my senses and took those speakers out and replaced them with better ones. IIRC it just takes the signal off of the speaker wires and amplifies that. I'd be surprised if that amp put out more than 20 watts.
I checked the potentiometer on the slider and there is a slight problem...
The Pot will work fine, but it only adjusts for one channel. thats why I have not done anything with it yet... If you have a bridged amp then it migth not matter...
It is possible to use it I just have not taken the time to figure it out so it works well and the way I want it to...
John
John
