Where to find Crossfire air cleaner Retaining knobs
Old Jan 21, 2010 | 03:55 PM
pacecarjeff's Avatar
Car: 1982 Indy Pace Car
Engine: Missfire injection
Transmission: auto
Where to find Crossfire air cleaner Retaining *****
Where can I find the 2 Crossfire air cleaner retaining *****?
Right now I have wing nuts holding the aircleaner on.
Want to find the correct retaining nuts.
GM part number is 14067309
Old Jan 21, 2010 | 05:45 PM
daveb123's Avatar
Car: 82 Z28
Transmission: BW T-10
Re: Where to find Crossfire air cleaner Retaining *****
I have access to the national GM locator- Zero hits!
Old Jan 21, 2010 | 06:34 PM
Transmission: auto
Yes - I tried that first.
Love my OEC.
Old Jan 21, 2010 | 07:07 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
Check with 1ATony, 1ADan or one of our other site vendors like Hawks Thirdgen.
Old Jan 22, 2010 | 10:16 AM
Transmission: auto
These are going to be tough.
I walked past so may of these at the yards over the years.
Who would have thunk I would need them now?
Old Jan 22, 2010 | 10:20 AM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
They're the same nuts as on the LG4 air cleaner. If you find a source for them, let me know, I wouldn't mind getting some spares.
I search for them pretty frequently on ebay, tough to find...
Nice car, BTW!
Old Jan 22, 2010 | 10:25 AM
Transmission: auto
Here is a picture:
Attached Thumbnails Where to find Crossfire air cleaner Retaining knobs-82-crossfire.jpg
Old Jan 22, 2010 | 11:02 AM
Drew's Avatar
Got a close up pic of the actual part?
Old Jan 22, 2010 | 11:13 AM
Transmission: auto
click on the picture - then click on the image - then click a 3rd time.
IT GETS REAL BIG
Old Jan 22, 2010 | 01:09 PM
Drew's Avatar
Now I honestly haven't seen a CFI setup in a few years, and I haven't paid attention to the *****, but if you look at the one in the pic above, it looks pretty close to the one in the artists rendition. The one in my pic came from the hardware store. They have bins full of various ***** and whatnot.
Old Jan 22, 2010 | 01:47 PM
Transmission: auto
Thanks - I appreciate the advise.
Would prefer to keep my GM car all GM.
Will find the real ones eventually.
I am a real stickler for authenticity - only exact will do.
Yours looks nice - But I can tell from here, that it is not the one I am looking for.
Old Jan 24, 2010 | 01:22 AM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
i have seen two styles of those-early '82 and mid-'82/83
the early air cleaners just had a hole where the *****
went through,on the later aircleaners that area is raised
to prevent water draining in.
'84 vette might have the early style *****,while i think
i have seen the later style ***** also used on some of
the later(say '85 up) carb air cleaner lids with the raised
center hole.
Old Jan 25, 2010 | 11:59 PM
82CrossFire Z28's Avatar
Car: 82 Camaro Z28, 88 IROC-Z
Engine: 5.0L TBI., 5.7TPI
Transmission: Auto TH200C, 700R4
Axle/Gears: 3.23 posi, ones that rotate!
Drew
I am attaching 4 photos in the next two messages. Note that the washer is missing from the right one in photo DSC00804. These two are original, though they may have been replaced during a recall to deal with the water problem. I don't remember exactly what they replaced, but I think is was these *****.
Attached Thumbnails Where to find Crossfire air cleaner Retaining knobs-dsc00803.jpg   Where to find Crossfire air cleaner Retaining knobs-dsc00804.jpg
Old Jan 26, 2010 | 12:02 AM
Here are the last two photos. Note that the shaft on the ***** is about 1-1/8" in length from the top of the washer.
Attached Thumbnails Where to find Crossfire air cleaner Retaining knobs-dsc00805.jpg   Where to find Crossfire air cleaner Retaining knobs-dsc00806.jpg
Old Jan 26, 2010 | 01:01 AM
Drew's Avatar
I never would have guessed they'd be that tall. Any number of other GM applications may have the same style ****, but they probably won't have that shank. Good used is probably the best option available.
Old Jan 26, 2010 | 09:57 AM
Transmission: auto
Thanks for the pictures. Great help.
I would not have thought they looked like that.
would you sell a set?
Old Jan 26, 2010 | 10:04 AM
bestracing's Avatar
Car: 86 T/A - 70 Z28/RS
Engine: Broke - 350
Transmission: 700R4 - M22
Axle/Gears: G80, 2.73 - ZQ9 G80 4.10
I know on my 86 LG4 the **** porting looks the same but I'm not sure what it looks like on the under side. It's in a storage box along with other stock pieces I had removed. Haven't gotten rid of one piece except for cracked rubber vacuum lines
Old Jan 26, 2010 | 11:16 AM
Transmission: auto
when i went to the yard the other day.
There were about 10 3rd gens there.
All were either 6cyls, or engine removed.
Sounds like these are more common then I thought, and I need to just be patient, and a set will turn up.
Old Jan 26, 2010 | 11:29 AM
1982TA's Avatar
Car: 1982 Trans Am
Engine: SBC 400
Transmission: 700-R4
Axle/Gears: 9 Bolt 2.77
I could be wrong, but did they make 2 variations of these? I know the camaro air cleaner lid had raised areas where the nut would bolt on, making a longer nut necessary. The threaded shank didn't even go through the holes. The Firebird versions had a recessed area and the shank part came up through the hole quite a bit. I only have one set from a Camaro...I also have both air cleaner lids. The Firebird lid is more of a PITA to get the nuts secured vs. the camaro because of the indentation. I could be wrong....just something I've noticed with the 2 different lid designs.
Old Jan 26, 2010 | 09:13 PM
Transmission: auto
found one on ebay.
The pictures really helped - did not realize the shaft was that tall.
http://cgi.ebay.com/ws/eBayISAPI.dll...m=140326131552
I am going to look real carefully at the Cadillacs the next time I pull.
found these also -Reproductions ---> http://cgi.ebay.com/ebaymotors/85-86...mZ300390371127
Old Feb 5, 2010 | 06:33 PM
Transmission: auto
This is the one got on ebay.
It only screws down about 1/2" to the line in the picture.
It is to fat to go down any further
Does not seem right?
Attached Thumbnails Where to find Crossfire air cleaner Retaining knobs-img_6375.jpg
Old Feb 5, 2010 | 06:52 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
that looks like the later,2nd design of crossfire lid *****
for use on the later lids with the raised holes.
that is the style i have on my '83 crossfire air cleaner.
Old Feb 5, 2010 | 08:12 PM
Transmission: auto
that is what I figured.
82 only design is what I need.
Oh well - back to square one...
Hey anyone got a set of these ***** for the........
Old Feb 5, 2010 | 09:39 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
'82 vettes or '84 vettes might use the early style ****.
Old Feb 9, 2010 | 01:02 PM
Transmission: auto
looks like 82 had a 1 year only design - the **** is taller with a very short shaft.
Like these...
Attached Thumbnails Where to find Crossfire air cleaner Retaining knobs-img_1615.jpg
Old Jul 17, 2010 | 12:48 AM
Transmission: auto
WELL - After 6 months of looking, i finally found a correct pair of these darn things.
I was stumbling through the swap meet at the 2010 Bloomington Gold Corvette show a few weeks back...
Low and behold - there was a pair of the exact ones i needed - laying on a table.
Seems the early 1982 Corvettes and 1982 Camaros used the same *****.
A one year ONLY item, that was substituted late in the model year because of a drainage issue.
Man was I happy!
Vintageracer
Jan 10, 2020 05:33 PM
86IROC112
Sep 7, 2015 01:37 PM
BurlyChev
Aug 22, 2015 01:52 PM
wruiz
Aug 13, 2015 09:07 PM
92purpz28
Aug 11, 2015 02:30 PM
