VSS Buffer Box
Old Nov 10, 2009 | 01:40 AM
ShMaCk2004's Avatar
Car: 1987 Camaro IROC-Z
Transmission: LS1 T56
Axle/Gears: Richmond 3.73
VSS Buffer Box
I need a vss buffer box and the pigtails connected to it. when you cut the wires leave as must wire on there as possible please.
Old Nov 10, 2009 | 07:38 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: VSS Buffer Box
PM sent !
Old Nov 26, 2009 | 12:32 PM
srshll's Avatar
Re: VSS Buffer Box
What is a vss buffer box
Old Nov 29, 2009 | 04:18 AM
squierrel12000's Avatar
Car: 1991 camaro rs
Re: VSS Buffer Box
i need a vss buffer for my 1991 camaro rs 305. does anyone know where i can get one?
Old Jan 3, 2011 | 12:27 PM
thunder69n's Avatar
Car: 87 Firebird Auto V6 2.8l
Re: VSS Buffer Box
is this a VSS Buffer box?
http://www.youtube.com/watch?v=RTHYtr8YVrE
whatever im looking at in video has a part number 25074710 and 37BH written on it. circuit board inside
couple sites seen online
http://www.enginepartsrus.com/8487-c...runakhiuribtl3
http://www.dragtimes.com/parts/ACDel...488421094.html
does it mess with cruise control and speedometer? my cruise control certaintly dont work, but the lever for it is cracked to so may be wiring up there. my speedometer freaks out all the time. Replaced VSS, so know thats good
Old Jan 3, 2011 | 12:33 PM
IROC-Z28_CAMARO's Avatar
Car: 1988 IROC-Z, 95 Z-28
Engine: 357, 350 LT1
Transmission: Built 700-R4, 6-Speed
Axle/Gears: 2.73 Peg Leg, 3.42 Posi
Re: VSS Buffer Box
I have one from a 87 and 89.
lmk
Josh
Old Jan 3, 2011 | 08:45 PM
John in RI's Avatar
Re: VSS Buffer Box
Nope - That's the Cruise Control module.
The VSS buffer is just a circuit board placed inside a small YELLOW plastic case. Keep looking - your looking in the right area !!!
P.S. The VSS Buffer accepts the signal from the tranny mounted speed sending unit and splits it into 2 signals. One of them is split again & those 2 leads feed the speedometer and the ECM (2000 PPM). The other signal is multiplied by 2 & sent to the Cruise Control system. (4000 PPM)
Old Jan 3, 2011 | 10:21 PM
thunder69n's Avatar
Re: VSS Buffer Box
sweet thanx. seen the yellow box in a junk yard i think. was in simmilar placed looked like. but had two connectors of wires going to it instead of one
Found were my buffer box is, and ECM. I Gotta figure out how to test or get ahold of one of these. Looks like buffer boxes harder to find online.
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Ed1LE
Sep 30, 2018 09:14 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
tattmann
Sep 27, 2015 05:20 PM
