Digital dash!
Old Jun 26, 2006 | 01:07 PM
Badass_recaro's Avatar
Car: 1982 Recaro T/A
Engine: 305 w/Carter carb.
Transmission: TH-350
Axle/Gears: stock
Digital dash!
Is it even possible to mount a digital dash in my car?
I have a normal 82 recaro trans am and i really want a digi dash!
But I hear that it's impossible to mount it into a car that has analogue dash..
Old Jun 26, 2006 | 01:17 PM
WILL85IROC's Avatar
Car: 85 IROC-Z Z-28, BLUE & SILVER
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
try Dakota Digital - digital instrumentation and accessories automotive and motorcycle enthusiasts. theres another company buy i forgot the website...
Old Jun 26, 2006 | 01:22 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
you will need to convert to a digital VSS instead of a mechanical speedo. you will need a COMPLETE cabin wire harnes out of a Digital Dash equiped car (i assume they are different) and you will of course need the actual digital dash and all trim. the non guage cluster portion of the dashes should be the same. i do not know i you will need the ECM from a digital dash car or not (which would pretymuch mean converting to TPI) i certainly hope not, because i one day hope to convert to a holley ECM...
Old Jun 26, 2006 | 01:33 PM
Axle/Gears: stock
Holy smokes! It's that big of a job?
Originally Posted by WILL85IROC
They don't have digital things for trans ams!
Last edited by Badass_recaro; Jun 26, 2006 at 01:37 PM. Reason: Automerged Doublepost
Old Jun 26, 2006 | 03:55 PM
sogabe's Avatar
Car: 91 Camaro RS(RealSlow)
Engine: 3.1L
Axle/Gears: unknown/mostlikelycrappy
search ebay with 'trans am cluster'
i did find one for a camaro,
everything's digital and its like 399bux but it looks pretty nice
and i bet itll make it more luxurious.
only if i had money and the knowledge to install it though..
Old Jun 26, 2006 | 05:37 PM
Axle/Gears: stock
Yeah. I saw it to!
But I think the clusters that WILL85IROC linked to looks veeeery good!
Does anyone here know of some other companies that sell stuff like this?
It would really help!
Old Jun 26, 2006 | 06:55 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
hmmm don't know if they still make it but..........
Interior Products
The knight rider parts are at the top but the stock gauge replacements are more towards the bottom It's a digital dash that bolts into the stock one just like that!!.......so it says...............but....the price.....ouch lol
Old Jun 26, 2006 | 07:02 PM
sogabe's Avatar
Engine: 3.1L
thats some neat stuff on dakota website,
AS I KNEW the 90-92 model is not in there though.. sigh
oh well i couldnt afford it anyways
Old Jun 26, 2006 | 10:06 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Just because it's not on their site doesn't mean they can't make it, you need to send in a ready to install cluster, including bezel, and they will convert it to digital. No harness required, you tap off from the original in the car and run those wires to the new cluster's cpu. The kit comes with all the senders and cable/digital converter for VSS (didn't need mine since I had electronic speedo).
Here's my '92
Old Jun 26, 2006 | 11:43 PM
sogabe's Avatar
Engine: 3.1L
wow cool... how much did they charge u?
Old Jun 27, 2006 | 12:08 AM
Al Hasse's Avatar
I've had mine for about two years now, so price has gone up. I paid about $900 for the conversion, now lists for $975 for the 6 gauge cluster. Price is higer than for the ready made panel because they are not stocked and have to be fabricated.
Custom Mounted Instruments - Uses Original Bezels
Old Jun 27, 2006 | 04:29 AM
sogabe's Avatar
Engine: 3.1L
that sure looks nice..
but considering the price I will have to take priority in
my other stuff, like my engine(high mile)
looks nice though
Old Jun 27, 2006 | 03:18 PM
Al Hasse's Avatar
looks nice though
Mine went out about 4000 miles ago, then replacement block was bad, had to warranty that, now just finishing breakin on this one. Had 199000 when motor went south, now at 203000 and hope to see alot more.
Old Jun 27, 2006 | 05:33 PM
Xophertony's Avatar
Axle/Gears: n/a
just so everyone knows, those photos don't do justice, al's car is way nicer looking in person. that cluster is HOT!!
btw i am prety sure i was wrong about the ECM, been looking in my factory manual, makes no mention of a different ECM.... so my bad.
Old Jun 28, 2006 | 08:41 AM
Axle/Gears: stock
But will the camaro cluster fit a trans am?
Old Jun 28, 2006 | 09:40 AM
Al Hasse's Avatar
Probobly not. If you want Dakota Digital, send that Trans Am cluster to Dakota Digital for them to convert it to digital.
Originally Posted by Al Hasse
Just because it's not on their site doesn't mean they can't make it, you need to send in a ready to install cluster, including bezel, and they will convert it to digital. No harness required, you tap off from the original in the car and run those wires to the new cluster's cpu. The kit comes with all the senders and cable/digital converter for VSS.
Old Jun 28, 2006 | 01:06 PM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
i found the other one: Covan's Classic
Old Jun 28, 2006 | 01:35 PM
Axle/Gears: stock
Thanks! Keep'em coming!
Old Jun 28, 2006 | 02:11 PM
Al Hasse's Avatar
The other one you might be looking for is Nordskog
Nordskog Performance Products
Here is their universal "build-to-fit" panel
Old Jun 30, 2006 | 11:46 AM
Axle/Gears: stock
Wow! those were good looking!!! any other similar places I can get digital gauges?
Old Jun 30, 2006 | 12:53 PM
nimrod_sixty9's Avatar
Car: '91 RS Camaro
Engine: 5.0 TBI
Transmission: Manual
Axle/Gears: 3.08
What about the factory one from the Berlenetta? Didnt it come with a Digi dash option. I think I remember seeing it in a U-Pull-It for like $10! And it looked like it would fit my 92' camaro. Id imagine there are some for FBs too, if you could ever find one, it would be hella cheaper (and neat since its a factory product!)!
Old Jun 30, 2006 | 01:03 PM
Axle/Gears: stock
Yeah.I understand that!
I've already made up my mind NOT to go for a digi dash from a trans am.
Instead It will be clusters (digital) from various suppliers.
Old Jun 30, 2006 | 01:06 PM
Xophertony's Avatar
Axle/Gears: n/a
yes, berlinetas came with a digital dash option. to put it in a regular camaro all you nead to do is swap the passanger cabin wire harness (the whole thing) and the dash itself. since you have to pull the ash anyyway to do the wires this is no biggie. a buddy of mine did the oposite of this (converted berllinetta to RS).
yes, Pontiacs came with a digital dash option as well, only it is much more tastefull then the berli one. GTAs had it as an option 87-89. however only 5 or so were done in 89. if you special ordered from the factory you could get a regular TA with a digital dash as well. a memeber of cascade crew ordered a TA in 1988 with a digital dash. it had all the GTA options except Y84 (gta option package). to do this swap i would think it would be the same thing. pull the dash, swap the passanger cabin wire harness, and put the new dash in.
unlike the camaros, the GTA digital dash and associated trim WILL fit in the regular dash shell. you don't need to swap the WHOLE dash. justy most of it. with the berlinettas the digital stuff has it's own dash assembly, and the entire dash needs to be swapped (somone correct me if this is inacurate, i am prety sure i am right)
i have attached pictures of the GTAs digital dash:
Old Jul 3, 2006 | 11:36 AM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Wow, that dash is funky looking... Much different then the berlinetta dash.
Old Jul 3, 2006 | 12:07 PM
Axle/Gears: stock
Do you guys think there will be problems with making the digital gauges work in a 1982 T/A?
I'm talking primarely about gauges from northskog and egauges.com
Old Jul 3, 2006 | 10:54 PM
Al Hasse's Avatar
If I read the downloadable install sheets right, the Nordskog gauges install very similar to the Dakota Digitals thay I have. You need to splice into the stock wire harness behind the gauges, then run a wire for each signal to the microprocessor. Gauge signals are supplied by the microprocessor. Not hard once you figure out which wires are needed to splice into.
Old Aug 24, 2006 | 06:24 PM
lostangel's Avatar
Car: 86 Z28
Engine: 305TPI stock
Transmission: TH700R stock
on the dakota digital display do you know if it blanks out completely to black? I'm still trying to figure out what i want to do interior wise. I think the gauges would be cool if they would disappear when the car if off.
Old Aug 25, 2006 | 12:54 AM
Al Hasse's Avatar
Yes they do black out completely when off. The only thing to see is the etching on the gauge faces.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
sheachopper
Jul 31, 2019 11:27 AM
Fanatic1074
Oct 2, 2015 03:47 PM
lewandom
Oct 1, 2015 08:15 AM
Eric-86sc
Sep 28, 2015 11:37 AM
