Temperature Control Cable
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
I'm new to the Camaro scene, and when I bought my Camaro (87 IROC) the guy who sold it to me told me that the temp door was broken, and I had to move it manually to switch from AC to Heater. I got down there, and noted the cable that apparently goes to nothing, and the broken off nub from where the lever used to be. I can move the nub, but it's REALLY hard to do. I was wondering if anyone knew of anywhere where I could buy a new nub and cable kit, so I don't have to keep doing this. Also, the Chilton showed that there was a "sound insulation panel" underneath the passenger side of the dash, which isn't there now, probably due to the owner having to change the temp door setting manually. Is there anywhere I can get another of these panels?
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
hush panel
common
your local chevy dealer can probably get you the parts youre looking for other than the hush panel, in which is dirt common for a/c equipped models
good luck
common
good luck
wigmobile
Feb 26, 2025 02:56 PM
