Crazy looking door panel?
Old Aug 16, 2006 | 03:25 PM
nemoose5's Avatar
Car: 1991 RS
Ok so I decide to take apart my door panel and redo the interior with vinyl instead of the custom burlap that was put on by the previous owner in Florida. As I start to take it off I hear cracks all over the place. I notice that they used a piece of paneling wood as a template or door panel backing, then covered it in foam to give it shape, then placed burlap over it.
Do all of our cars have a wood door panel backing like that or did I just get unlucky? I expected it to be plastic so I could just strip off the material and then lay down the vinyl.
I am also thinking of making a door panel out of fiberglass, any ideas on what I should do? And lastly, there are alot of junkyards around here and pretty much only have IROC's. I have an RS and am wondering if an IROC door panel would fit on my RS?
Old Aug 16, 2006 | 03:31 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
well look at that, it looks like someone made some custom door panels for the car.... they look neat
Old Aug 16, 2006 | 07:38 PM
Bull's Avatar
Car: 1995 Formula; 1976 Trans Am
Engine: LT1; None
Transmission: T56; None
Stock, the doorpanels have a stiff cardboard-like backing structure. Not the best choice since it can be bent fairly easily upon removal, and if moisture gets to it it's toast.
Old Aug 16, 2006 | 07:50 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
All 82-92 Camaro door panels are interchangeable, the only difference is some have the holes for manual window cranks. There are several styles, colors, etc but all will snap right in.
Old Aug 16, 2006 | 08:05 PM
fadetoblack's Avatar
Car: 1990 Formula
Engine: 383 Stroker
Of course, I don't know the whole story and I can't see the panel all that great in the picture. However, from what I can see in the picture, IMO, the custom burlap panel looks GREAT! I understand that you said you wanted it vinyl. Is that the ONLY reason? It looks like you may have destroyed a ton of hard work and an awesome looking custom door panel.
Old Aug 17, 2006 | 09:16 AM
nemoose5's Avatar
Car: 1991 RS
I know that from a distance the door panel looks great, but that is a picture of the one on the passenger side which is the only part left in what you could say "good" consition. The interior was done over about 8 years ago I think and the driver side door was a MESS!. It was fading and was worn out and there were strands all over the place. I gotta tell ya, it looked awesome when I got the car but its made of burlap and it doesnt hold up to time really well. I hated to do it but the interior had seen enough and its time for something new. Even the dash pad they did a good job on but the sun has taken a besting on it. The colors they used on the interior in general were grey and baby blue, but now they look like a sort of black and darkish blue.
Old Aug 17, 2006 | 11:22 PM
Car: 1990 Formula
Engine: 383 Stroker
Check this place out! They should have whatever you want to replace them with. Plus, the guy is a member of this board.
IRace Motorsports - Door Panels
Old Aug 18, 2006 | 12:54 AM
{TKM}Tom's Avatar
Car: 84 Trans AM
Engine: 305 HO
Transmission: one that dont work so well
im sorry but that door panel did not look to great i say buy a factory one from a scrap yard and make it look the way you want and the colors here is what i did with mine for 12 dollars lol
Old Aug 18, 2006 | 07:30 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
The stock door panels are cardboard. But I think the panels vary from year to year. The holes for the armrest may be different, so double check them before you buy.
Old Aug 19, 2006 | 08:32 PM
nemoose5's Avatar
Car: 1991 RS
Did you use those duplicolor spray paints or did you put down new material on your door panels, theyt look great!
Old Aug 19, 2006 | 08:43 PM
{TKM}Tom's Avatar
Car: 84 Trans AM
Engine: 305 HO
it was all done by duplicolor spray paints the red is actualy darker then what it shows in picture the sun reflection messed with the pic
and thank you
Hotrodboba400
Dec 10, 2019 07:07 PM
tglennon11
Sep 23, 2015 05:30 PM
NiG
Sep 7, 2015 11:25 PM
84 TA NV
Sep 6, 2015 08:02 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
