a cool way to mount your radar detector...
Old Aug 20, 2006 | 10:48 PM
Firebat's Avatar
ran across this. I know its on a C5 vette, but some rearview mirrors on thirdgen f-bodys are like the one in this link.
http://www.retrorelics.net/jim/c5_ra...rror_mount.htm
Old Aug 20, 2006 | 10:59 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
thats not bad. mine is mounted the same way, except it is on the top of the mirror, and the radar detector is hard wired with the wires hidden by the head liner. and the fused switch is on my shifter plate panel. so when you want it on, just flip the switch.
Old Aug 20, 2006 | 11:19 PM
r0nin89's Avatar
Car: 1987 Chevy Stepside
Engine: 350 TBI w/ a Cam
Transmission: 3 Speed Stick w/ granny low
Thats neat but I definatly wanna get my detector out of the site of the 5-0 when they pull me over they are extremely illegal here and most cops will pull an "Obstruction of vission if you have one". By the way can you suggest a reasonably priced detector?
Old Aug 20, 2006 | 11:46 PM
Firebat's Avatar
I have not bought one yet, but my friends have. You get what you pay for. They all had the most expensive one offered at walmart.
I would rather have it mounted on top of the mirror too, more out of sight from smokey.
Old Aug 21, 2006 | 12:17 AM
Jade Grey's Avatar
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
Cool idea. Something similar could definitely be done with the mirror with the maplight in my GTA.
I have been thinking about getting a Beltronics RX65. They have good reviews and prices should be good since they are being replaced now by the RX75.
Old Aug 22, 2006 | 12:34 AM
xlwhellraiser's Avatar
Car: 1992 Trans/am convertible
Axle/Gears: 2.73 drum WS6
I have a better idea. I've been dinking around with this idea for a while, but wasn't able to find a detector thats right for the idea.
Basically I was thinking of incorporating the detector in the dash.
Mainly taking the detector apart. having the sensor and everything upfront in the bumper opening or such, with the read out in the dash. I think that would be the sweetest set up. The problem is that the display is soldered to the detector/motherboard itself. I've been looking for a detector that has the display connected with wires. From there, I'll just elongate the wires, have the motherboard always on, hook up a rocker switch and use it to turn on, hard wired, detector on with a flip of a switch.
Its complex, but once I draw it out, you'll know what am talking about. From there I want to have 2 detectors one in the front and one in the back with two different read outs. That way I know where the signal is coming from. If I happen to get stoped, I'd turn the detectors off with the switch.
Old Aug 22, 2006 | 01:28 AM
Firebat's Avatar
with a very fine tip soldering iron, you could de-solder the display and use very small wires(like 26-30 gauge, if you need wires that small) and then just extend those wires to whatever length.
The sensor should be in the middle of the car though, i think, about where the rear view mirror is to get the full 360 degree detection.
Old Aug 22, 2006 | 11:26 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
These guys already have a remote mout detector and display K40
Radar detectors are not illegal in NJ
Old Aug 22, 2006 | 02:00 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
This is the easiest way, and quickest to remove when parking, that I have come up with. It is one of those nonslip "sticky" pads for cell phones that are sold everywhere. I then wired it up to the fuse panel on a hot with key, junction on the fuse panel. This way, if I leave the detector on the dash, it's off, but when I start the car it comes one. And to hide it. I just unplug it and throw it in my pocket, under the seat, in the glovebox, ect. Can't get any easier, and it stays put.
Attached Thumbnails a cool way to mount your radar detector...-aug22_001.jpg   a cool way to mount your radar detector...-aug22_002.jpg
Old Aug 22, 2006 | 03:38 PM
Denial's Avatar
Car: 84' z28
Engine: Built 350 SB 4 Bolt, Bored .30 Over
I dont really care for the way that guy has it in is corvette... not only that, but around here its illegal to have things hanging from your rearview, im pretty sure that would qualify...
Old Aug 22, 2006 | 07:26 PM
Jtufts's Avatar
Car: 1989 camaro rs
Engine: 305 TBI
Transmission: 700r
yep , i dont go speeding yet =) (engine cant handle it atm somethings up with it) but i do have one from walmart and i know a few cops who let me test it and it worked out great
Old Nov 17, 2006 | 02:51 PM
redteamgo2000's Avatar
valentine one radar
if you guys want a radar detector that will save your a** then buy a valentine one. my friend has one in his turbo eclipse, and they tell you how many radars there are and where they are located around the car. it has a display that has 4 arrows and it tells front back side to side and how many boggies there are. they even go one better and tell you that if you ever get a ticket, no matter the price they will pay it. definetly worth a look.
www.valentine1.com
Old Nov 18, 2006 | 04:36 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
www.valentine1.com
Boogies are in your nose Bogeys on the other hand are enemy targets
Old Nov 22, 2006 | 06:57 PM
II Fast's Avatar
Thats actually a great "How-To" article.
Old Nov 28, 2006 | 06:46 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
My Camaro has the detector in the middle on top of the dash with the wires running under the dash and my Jetta has it right above the rearview mirror. I like the Jetta better but both are hard wired so when the car comes on so does my radar detector...I'm lazy!
Old Nov 28, 2006 | 09:56 PM
systalis's Avatar
Car: 92 RS
Engine: Built 355
Transmission: Built 700r4
Axle/Gears: 3.73's w/ stock axles
I have to go... I just spit coke all over my laptop.
Old Nov 28, 2006 | 10:24 PM
92RS(real slow)'s Avatar
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
me too lmao boggies
Old Nov 28, 2006 | 10:49 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Do not sue me for new laptops
Old Nov 29, 2006 | 12:58 PM
systalis's Avatar
Car: 92 RS
Engine: Built 355
And it keeps getting funnier the more I read it.
Old Nov 29, 2006 | 02:13 PM
STEEL's Avatar
Car: 1991 Camaro RS
Engine: LO3
Can some one please explain to me how a Radar detector helps you? By the time the cop has his radar pionted at you, your screwed anyway!
Old Nov 29, 2006 | 03:06 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Well most of the time there usually driving around with thier radar on so it's not hard to pic them out, great for on the highway.
Old Nov 29, 2006 | 03:14 PM
STEEL's Avatar
Car: 1991 Camaro RS
Engine: LO3
If your driving at 60, and the cop is driving at 60, then you and the cop are getting 1 mile closer ever 30 seconds, and you want to slow down before he can see you, so do these things have like... 1-2 mile range?
Old Nov 29, 2006 | 04:05 PM
krisb410's Avatar
They may not be 100% preventive, but mine has saved me on quite a few occasions. And considering the cost of a ticket and insurance is more than the cost of the radar dectector, I figure it has saved me over a grand in court cost and insurance.
Old Nov 29, 2006 | 07:14 PM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
Transmission: 5 Speed Manual
Axle/Gears: 3.42 Peg Leg
Good radar detectors like the X50, V1, and RX65 do. They can actually pick up radar @ 2.5-3 miles, and around corners, and over hills...
Old Jan 7, 2007 | 10:32 PM
Jetmeck's Avatar
Car: '89 GTA 9,000 MILES
Axle/Gears: 3.27 9 bolt
Is that the Beltronics x65 you are referring to ?
Is it laser also ? Anybody care to chime in ? What's the best rader/laser detector out there ? Thx
Old Jan 10, 2007 | 08:31 PM
BanjaminGTA's Avatar
Car: 1989 Trans Am GTA
Transmission: 700R4 with shift kit
can i see a pic of this? i got a radar detector for xmas, and i am currently re-covering my headliner, so now is definitly the time to act on it.
thanks
Old Jan 10, 2007 | 09:41 PM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Its very tricky to mount my radar detector for the reason, I can't have it flush to the dashboard because I have a 3.5in scoop on the hood and I can't mount it too high because the laser sensor is on top of the detector...I actually mounted it higher on the windshield and hardwired it to the map/dome lights. My T/A upper console came with the full set up, dome light, map light, flashlight, and counters. Also there is a small pouch hanging between the port for the flashlight and map light. When around the cops I just remove it from the windshield and put it in the pouch. But my main accomplishment is I also wired the the crappy .5watt speaker to a beefier 2+watt outer speakers (by Creative, normally used for electronics like ipods, cd players and laptops) Because I kept getting pulled over and I would never hear the radar detector going off because of the music and the t-tops being off...
Bubbajones_ya
Jul 6, 2024 08:32 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
