Swapping Speedo's
Old Aug 28, 2006 | 09:28 PM
89 Camaro RS V8's Avatar
Car: 1984 Z28
Engine: 350 Carb
Transmission: 5 speed manual
Swapping Speedo's
I have an 87 camaro with an 85 mph speedo in it if i get a 115 or 140 what would i have to do to make sure it works properly or is it just basically plug and play?
Old Aug 28, 2006 | 09:49 PM
j dezzy's Avatar
Car: 87 TA
it's just plug and play.
but there is a company that you can send your current speedo to and they'll reprint it to 140 and recalibrate it.
Speedometer Repair Tachometer Clock and Gauge Restoration for Musclecars and Vintage Automobiles
Old Aug 28, 2006 | 09:57 PM
ybelikeu's Avatar
Car: 1984 Z-28
Engine: 305 H.O.
I swapped my 85 speedo for a 145 unit and it was an easy swap. I had to remove the 145 speedo from the cluster and put it into my cluster beacause some of the gauges did not work. My car is a 84 model and the donor was a 87 iroc. both speedo's where made the same and both where cable driven so it was no problem at all. Definatly a nice upgrade.
Old Aug 28, 2006 | 10:16 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
HMMM, very interesting, when I did my swap I was 5mph to fast on the speedo.
Old Aug 29, 2006 | 05:48 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Plug and Play. I advise swapping only the speedo head. Check the following link for more info:
https://www.thirdgen.org/forums/faq-...-fix-pics.html
JamesC
Old Aug 29, 2006 | 01:10 PM
j dezzy's Avatar
Car: 87 TA
I was 5 mph over too.
Old Sep 6, 2006 | 01:54 AM
homerunchamp's Avatar
Car: 2007 Dodge Charger R/T
Engine: 5.7L HEMI
Anyone know what year the camaros when from cable driven speedo to electric? I am planning a swap of my 91 5 speed into a 88 Iroc and wondered if I will be able to plug in the speedo the same as it was in my 91 or will I need to change things to accomadate a cable driven speedo. Or for that matter if I could swap in my gauges from my 91 easily? Thanks in advance guys!
Old Sep 6, 2006 | 05:32 AM
JamesC's Avatar
The last year for cable-driven speedos was 89. The swap from a 91 to an 88 wouldn't be accomplished easily. The guage cluster itself is different.
JamesC
Jorlain
Aug 24, 2022 05:11 PM
Eric2ndGen
Nov 5, 2015 01:51 PM
stickychinsac
Aug 31, 2015 06:06 AM
IROCZDAVE (88-L98)
Aug 24, 2015 06:54 AM
beachrodder
Aug 7, 2015 04:27 PM
