Door chime doesn't work
Old Aug 29, 2006 | 09:30 AM
Jason E's Avatar
2011 Norwood Gathering
ThirdGen Firebird Rep
Car: 99 WS6 / 00 SS / 11 CTS-V / 13 300
Engine: LS1 / LS1 / LSA / 5.7 Hemi
Transmission: 4L60E / T-56 / 6L80E / W5A80
Axle/Gears: 3.23 / 3.42 Auburn / 3.23 / 2.62
The headlight warning/door chime in my RS doesn't work. I assume its under the dash somewhere? I don't see a fuse for it. I assume I should buy a new one, if I can even get one?
Hope someone has some experience with this...thanks to anyone who can help!
Old Aug 29, 2006 | 10:23 AM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
I took mine out, I hate those things.
Old Aug 29, 2006 | 11:56 AM
Jason E's Avatar
Well, since you took it out, I imagine you know where it is? How hard is it to replace?
Old Aug 29, 2006 | 12:09 PM
krisb410's Avatar
IIRC, it is a rectangle black box under the turn signal flasher. It is located to the left of the steering column under the dash. It just pulls out like the flasher unit. Why do you want that annoying thing anyways?
Old Aug 29, 2006 | 01:29 PM
Jason E's Avatar
Because, I'm doing a full restoration on the car, its the only thing I can think of that doesn't work, I'm **** retentive about my cars...
And I leave my lights on sometimes I'll take a look under there tonight...its either broken, missing or disconnected from the sounds of it.
Old Aug 30, 2006 | 12:05 AM
navy02ws6's Avatar
Engine: LS1, LB9, L03
Yeah, I've been wondering about this one too...my thirdgen seems to be missing it entirely. Annoying, sure, but I like having an all-GM car. In fact, most of the money I've spent so far has been correcting stuff that the previous owner replaced with incorrect or non-GM stuff. No more tiny purple ***** foglights for me!
Old Aug 30, 2006 | 12:40 AM
Camaroguy18's Avatar
Car: 1986 Camaro SC (Supercool)
Engine: one composed of various metals
these cars had door chimes????
...news to me
Old Sep 4, 2006 | 08:52 AM
1982TA's Avatar
Car: 1982 Trans Am
Engine: SBC 400
Transmission: 700-R4
Axle/Gears: 9 Bolt 2.77
There are two different kinds, one makes a buzzing sound, the other is a chiming sound. I believe the later models after '84 had chime. They are both interchangeable. I added one to my car because it didn't have one either. For some reason it doesn't buzz for the seatbelts though...if does make noise if you leave the key in the ignition and open the door, or keep the lights on. Check the junkyards. I got two from there.
Old Sep 8, 2006 | 09:14 PM
84L69TA's Avatar
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
I dont understand why someone wouldnt want all that stuff to function properly.
Old Sep 9, 2006 | 05:07 AM
patricktroyz28's Avatar
Car: 1991 Z-28
Transmission: 4L60
In my 91, you take off the lickplate under the steering coloum, and it is a 7 prong black box to the far right
Old Sep 13, 2006 | 04:35 AM
1991Camaroz28's Avatar
Car: 91 Z28
Transmission: TH700-R4
if you worry about leaving your headlight's on then install a relay that kills them after a set time and have them come on with the ignition. simple as that. no dead battery and no annoying buzz. 4th gen's got the chime and the headlight switch that didn't break so damn easy.
Old Feb 3, 2013 | 08:11 AM
RobTransAm's Avatar
Car: 1983 Trans Am
Engine: 350 naturally asporated
Axle/Gears: stock axels 373 richmond
Re: Door chime doesn't work
I like the old school sound of the buzzer, but my problem is is that I have two and they both randomly decided to not work anymore. I checked the fuze box and nothing was blown. So now what do I look for?! I can imagine one burning out but the other one I have is good, but doesn't work in the car either so now it's a problem with the connection?
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Wade787b
Sep 29, 2015 01:15 PM
BlackTopKing
Aug 19, 2015 12:13 PM
