Gauge Cluster Lights
Old Oct 5, 2006 | 05:37 PM
duke91's Avatar
Hi guys, I took apart the dash of my '91 camaro to replace the instrument panel lights and have now created 2 problems.
1. Broke the head light switch/****, had to order another one (used)
2. Tried to replace the lights, but the new bulbs did not work, I think I might have damaged the metal connection on the twist base.
So, I have to get the lights with the bases attached, but as of now, the car does not should off the initial beep when you start it...it just keeps beeping. The speedo, battery, oil gauge all work, just no lights and the beeping.
My questions:
1. Am I in trouble? Should I just scrap this project and give it to a mechanic?
2. If the answer to #1 is no, then what should I do? How do I attach the light switch back on? Is the repair manual any help? Not sure if I should buy it.
Thanks,
BTW: My car is in mint condition and I really don't want to mess it up, I hope I haven't already.
Old Oct 5, 2006 | 06:19 PM
Psycho_91Camaro's Avatar
Car: 1991 Camaro RS
Engine: THE LT1 SWAP SHALL BEGIN!!!!
Transmission: 700 R4
Axle/Gears: LSD! =(
I hate working on gauge clusters, it was a pain getting my 145mph gauge cluster to work properly on my 1991 RS I had to remove the odometer and it's frame, the 2 small torx bolts, I HAD TO USE A DRILL!!! to get them out, since I did not have the proper size, so I just bolted it on with some other screw... Also BEWARE and prepare fora pain in the *** if you remove the TEMP or FUEL needle, you will never get it precise again after removing it!!!! My fuel gauge needle is probably 1/2 off it's original reading... sucks anus!!
Old Oct 5, 2006 | 06:24 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
I went to the parts store and bought new bases for the bulbs. And then I used 5 bulb LEDs that are made to fit 194 sockets.
If you had the manual you wouldn't have broken your headlight switch, so I recommend getting one of some sort. I got a factory service manual, it's excellent, much better than the Haynes.
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
tnrednneck
Aug 13, 2015 08:57 AM
ChevyZ71
Aug 13, 2015 07:30 AM
