Can't get rid of a squeak!
Car: 1989 Trans Am GTA
Axle/Gears: 9 Bolt 3.70
My '89 GTA has a squeak that I can't get rid of. I know it's in the trunk area on the passenger side, but I can't find exactly where it's coming from. I tried tightening the plastic screws on the all the removable panels in the trunk because it sounded like they were rubbing together, but despite my attempts, the squeak is still there. Any ideas or suggestions on how to find and get rid of it would be extremley helpful.
Car: 1988 GTA
Axle/Gears: 3.70
sell the car.
not trying to be too much of a smart *** but my 88 squeaks my 96 squeaks too and pretty much every f-body ever made squeaks
but seriously... new springs shocks SFC's etc help reduce squeaks.
Car: 1992 Camaro RS
Engine: 305 TBI
I had a squeek after changing my shocks, got worse over a few weeks, after checking everything on the inside and out i found out it was the shocks, tightened the nuts on the inside on both shocks and the squeek went away. its worth a try and only takes a few minutes
Car: Forrest 91 t/a
Engine: 5.0 tpi w/underdrive/accel,full 3"
Axle/Gears: 3.73 pos
as "onemanarmy stated, not trying to be a smart ***, but"
These cars squeak all over. If you fix that squeak there will be another and another and another. Good luck
From what I've "heard" SFC help allot with the rigidity of theses cars, which helps elements the factors that contribute to squeaks.
One thing I "know" works to eliminate squeaks, is a great stereo.
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
On Camaro's, (at least on my vert, probably the same on yours) this is where the spare tire is. Could it be something in there? Maybe loosen and retighten the spare wheel, jack, etc.
PS; try owning a vert! I could spend years looking for all my squeeks and rattles!
Car: 1991 GTA
Engine: SuperRam 350
Might be the hatch. Does it fit nicely? I didn't think so. These hatchs tend to do this. You have to replace the hinges or redrill one of the hinges mounting hole a little higher. Try pushing down on the hatch's corner where it meets the corner of the taillamps. Could be the source of the squeaks.
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
Try dropping your back seat and see if it goes away. If so, it's the latch on the seat causing it. At least thats what it is on mine.
Car: 91 Camaro RS(RealSlow)
Engine: 3.1L
Axle/Gears: unknown/mostlikelycrappy
the metal thing that secures that tire was loose on mine and was clunking all over until i finally figured that out lol
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
As above - spare or hatch. Remove and reinstall spare tire and parts. Mine squeaked and it was the rubber tire against the metal body - I stuck an old t-shirt around my tire and remounted it - stops the squeak and I always have a rag in the car when changing a tire.
On the hatch - try opening the hatch, and adjusting outwards the little ruber bumpers - they screw in/out - maybe a turn on each will tighten the close and stop a squeak.
the_hamturdler
Sep 22, 2015 02:59 AM
Those new shocks......
