highbeam question
Old Oct 11, 2006 | 10:36 PM
RSL03's Avatar
Car: 91 RS
Engine: 305 TBI
Axle/Gears: stock
highbeam question
Hey guys. just bought a 91 camaro RS. and for the life of me i cant find out how to get the highbeams on. ill pull the switch all the way out and its just the regular beams.and the first pull is the running lights and dash. any help will be greatly appreciated.
Old Oct 11, 2006 | 11:37 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
Welcome to the boards & congrats on the thirdgen
lightly pull back on the turn signal lever
Old Oct 12, 2006 | 08:42 AM
RSL03's Avatar
Car: 91 RS
Engine: 305 TBI
Axle/Gears: stock
this board rules. thanks alot man you guys are awsome.
(actually just went and tried that and no highbeams. ill pull the lever back and nuthin happens it just pulls back.)
Old Oct 12, 2006 | 09:35 AM
GTAfanatic's Avatar
Car: 1988 GTA Black notchback
Engine: 1991 L98 355 TWIN Superchagred
Transmission: 700r4 shift kit 2500 stall
Axle/Gears: www.cardomain.com/id/gtafanatic
Most likely the prob is the rod that runs down the left side of the column it sometimes fall out of the wight push button Highbeem switch (that is loacted on the left side of column neer the brake just follow rod down and you will find it) If you are not hearing a clicking sound then the switch is not working some times you will have to work the rod to get it back in but there should be a place the rod will sit in. Lets us know if this helps.
PS. welcome to the bord
Old Oct 12, 2006 | 09:38 AM
RSL03's Avatar
Car: 91 RS
Engine: 305 TBI
Axle/Gears: stock
ok going out to try this right now. i also have a problem with the blinker. ill push it down to signal left and it doesnt blink. i will be replacing the relay tommorow hoping it will help.
(just checked for that rod cant see it. anyone have a pic of this?) thanks
Old Oct 12, 2006 | 10:03 AM
jtmiller92's Avatar
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
You can adjsut the high beam switch, if the rod is till in it as suggested above then you may just need to adjust the switch which will slide up or down. if that doesnt work you will have to pick up a new one.
Old Oct 12, 2006 | 10:13 AM
RSL03's Avatar
Car: 91 RS
Engine: 305 TBI
Axle/Gears: stock
im still lookin for this darn rod lol. is it easy to find/fix? im on a super budget here, hoping i dont have to take it in. thanks guys.
Old Oct 12, 2006 | 10:35 AM
jtmiller92's Avatar
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
Do you have all the plastic panels removed under the colunm? Now lay your seat back and put your head under the column. Look toward the bracket on the column. There is a bracket that has two 13mm bolts holding the entire column in place. Just beside it on the driver side of the column is a white switch with a rod going into it. Move the turn signal lever forward and back and you should see it move. The metal rod is right there. If the rod moves the plunger on the white switch then you may be able to just adjust the switch.(two 7 or 8mm screws) then slide the switch toward the steering wheel to tighten it. Tighten the screws back up. If this doesnt fix it then you will need a new switch. Its easy to replace, i wouldnt waste money on a shop to do it for you.
Old Oct 12, 2006 | 11:06 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
I've seen loose tilt columns also cause similar problems with intermittent or incomplete engagement of high beams switch and turn signals. In both cases, tightening the column made everything click and switch like new.
Now was the bad engagement of the switches/signals caused by the loose column or did I fix some other loose/misaligned issue as I put the column back together after tightening, idk. I tore into both columns to fix all the problems, tightened the tilt mechanisms then put everything back in place and found the switch/signal issues resolved.
Old Oct 12, 2006 | 11:30 AM
RSL03's Avatar
Car: 91 RS
Engine: 305 TBI
Axle/Gears: stock
actually my column is kinda loose and its a tilt. so i should try tightening it first? thanks guys your awsome.
Old Oct 12, 2006 | 11:51 AM
naf's Avatar
naf
That was kind of my point, if you have to tighten it you'll have everything out anyway and if tightening it doesn't fix the switch issue you'll be able to resolve it as you put everything back together.
You can rent the steering wheel puller and lockplate remover from autozone or the equivalent. There's a tech article on this site that can walk you through it. Take your time and keep track of the parts as you go. A digital camera can help too as you disassemble.
Old Oct 12, 2006 | 12:03 PM
RSL03's Avatar
Car: 91 RS
Engine: 305 TBI
Axle/Gears: stock
thanks man. gonna be busy today but tommorow im gonna head to autozone and pick that up. thanks again guys
Old Oct 12, 2006 | 08:01 PM
GTAfanatic's Avatar
if you are going to fix the colom you are going to need some tork bits the star looking things just fig i tell ya, if you dont have them get them
Old Oct 14, 2006 | 12:00 PM
RSL03's Avatar
Car: 91 RS
Engine: 305 TBI
Axle/Gears: stock
problem fixed guys. was a little tough gettin up in there but works awsome now. also replaced flasher relay so now i have blinkers that work! lol thanks again guys.
Old Oct 15, 2006 | 02:14 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
If you replaced that high beam switch with one from Autozone, plan on replacing it again soon - they last about 2 months (for me anyways). Next time, get one from Napa or Carquest - my Carquest switch has lasted over 2 years now.
Never get electric items from Autozone/Advance - especially ones you don't want to have to replace often (like fuel pumps).
Old Oct 15, 2006 | 05:45 PM
RSL03's Avatar
Car: 91 RS
Engine: 305 TBI
Axle/Gears: stock
actually i didnt have to replace the switch i just adjusted it. so hopefully it lasts a while.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
