Dash Bulbs Soldered Into Sockets?
Old Oct 14, 2006 | 11:21 AM
sancho's Avatar
Car: '89 Chevrolet Camaro IROC-Z
Transmission: TH-700R4
Axle/Gears: B&W 2.77 Posi
I've got some bulbs out on my dash cluster and would like to replace them. I pulled the cluster and then twisted out the bulb holders. The bulbs looked exactly like I thought they would (the kind of bulb that seems very common in GM interior lighting), but for whatever stupid reason, they were soldered into the sockets. I thought this might have been a hack job by the previous owner, but the sockets actually say "replace entire assembly".
Problem is, nobody (by which I mean Autozone and O'Reilly) sells the blubs and sockets as an entire assembly. The blubs have the same numbering as the bare bulbs that everybody else sells (i.e. 194, 192, etc.), they're just soldered to the sockets. I was able to track down some generic sockets for the numbered bulbs, but doing it that way was going to end up costing me more than $50.00USD.
Anybody run across this before? Is there a better/cheaper way to do this?
Thanks.
Old Oct 14, 2006 | 11:30 AM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
They're not supposed to be soldered in, I have a bunch of those and the bulb pops right out.
Old Oct 14, 2006 | 12:17 PM
sancho's Avatar
Yeah that's what I thought--In fact, what really prodded me to change the bulbs was the fact that I needed to pull the cluster to fix my trip odometer. Another guy here has a great how-to on doing that, and he also covers changing the blubs. In his pictures, the blubs just popped right out of the sockets--so I know there are other people here with "normal" sockets.
These particular sockets/bulbs, however, came from the factory soldered. It's one of the dumbest things I've ever seen on a car, because the sockets were clearly made to be reused and the bulbs are identical to the replaceable bulbs you buy of the counter. Some genius just decided that things would be better if the two were permanently joined together.
Old Oct 14, 2006 | 12:20 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Strange, I have never seen those before. I have about 20 and the bulbs just push out.
Old Oct 14, 2006 | 12:51 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
See those now and then, I thought they were a brighter bulb deal. I hit a local junkyard and pulled 20 out of a couple cars, later S10s have them for sure. Guy charged me a quarter each, pretty cheap I'd think. Looks like a standard socket will interchange though, and use the push in bulb.
Old Oct 14, 2006 | 04:41 PM
Vaneat-91RS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: A/T
They are known as a "pc" bulb(as in pc-194, pc-168, etc.), and yes they are designed that way. You local dealer either has them in stock or should be able to get them easily for you. I'm kinda surprised that NAPA or other aftermarket stores don't have them. They are actually pretty common among GM vehicles. They are a bit spendier, however. Aftermarcket probably $3-5, dealer $7-10.
Old Oct 14, 2006 | 11:57 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Good write up here with wattages and candlepower, the smaller bulbs are at the bottom of the page.
THE HERD: Light Bulb Replacements
Old Oct 15, 2006 | 10:29 AM
Rockyd's Avatar
Car: 89Z28 Vert
Engine: 350/tbi
Axle/Gears: 3.27 Posi
hey i had those in my car as well i just bought the cups the little black tabs form a the dealer for areound 5 bucks for all the ones i needed and just baouight the bulbs at autozone reall stupid the way the did that but thats your best be and not to much $$$
Old Oct 22, 2006 | 11:39 AM
RCAR7395's Avatar
From: South Bend Indiana iphone CALL OR TXT 574-607-2389
Car: 2003 GMC 2500HD Sierra Pickup
Engine: 6.0 Vortech
Transmission: 4x4
Yep they are soldered in and you can buy replacements, the bulbs and the bulb holders come together at Advance Auto or order them. Kind of expensive.
Old Oct 22, 2006 | 05:58 PM
Merlin1969's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI
Transmission: Automatic
Dash Lights
I got replacement sockets at O'Reilly for a few bucks. The sockets accept the common bulbs, 192 and 194. I was able to get a brighter Halogen bulb from Radio Shack to fit with no problem.
Melrin1969
90 Camaro RS - 305TBI
Old Oct 22, 2006 | 08:39 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Sice half of mine were burned out, I just bought 15 for my 89's gauges (everything but the idiot lights across the bottom). PC-194 from my local NAPA at just under $3 apiece, including the socket. I depleted their stock to near zero
Old Oct 23, 2006 | 03:39 AM
Stealthy-One's Avatar
Car: 89 RS
Engine: 2.8
Transmission: 700r4 auto
Axle/Gears: huh?? guessing stock.
ijust replaced the pc-194's with normal sockets and my choice of bulb. that way if I ever have to replace them again I only have to get standard bulbs.
86IROC112
Nov 7, 2015 06:50 AM
lewandom
Oct 1, 2015 08:15 AM
rusty vango
Sep 29, 2015 02:44 PM
Eric-86sc
Sep 28, 2015 11:37 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
