Front Seat Belts for 1982 Firebird
Old Oct 21, 2006 | 09:58 AM
BruceEmbry's Avatar
Car: 82 Ponitac Firebird
Transmission: 4L60e/TCI TCU
Hi all,
I need to replace my driver side seat-belt. It is worn and could proberly be consider unsafe. I know that 1983 up Firebirds has dual retractors on the front seatbelts. My 82 has retractors only at the top. I would rather get the same type of seatbelts. I would also like to get new belts.
I have gone to GMParts Direct and they are calling out the same part numbers for all years. Does anyone know of the part numbers that I need to get the correct belt/retractors assemblys?
Thanks for your help!
Old Oct 23, 2006 | 04:58 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
you're very lucky because of the fact that 4th gen front seatbelts would be a direct bolt-in replacement for you. They went back to the retractor on top and solid mount on bottom design. I got ahold of a set of 82 door sill trim pieces myself to match the 4th gen seatbelts I got.
Old Oct 23, 2006 | 05:07 PM
82firebird's Avatar
Car: 1982 Firebird
Engine: sbc 307
Transmission: 200
I'm also using a set of 4th gen belts in my 82. Couldn't be happier, they work and look like they are only a few years old rather than 24 years old.
Old Oct 23, 2006 | 05:38 PM
BruceEmbry's Avatar
Thanks guys!
This is great news. I going to order new parts.
What year should I order?
Old Oct 24, 2006 | 05:42 AM
1982TA's Avatar
Car: 1982 Trans Am
Engine: SBC 400
Transmission: 700-R4
Axle/Gears: 9 Bolt 2.77
interesting...didn't know that the 4th gen seatbelts would be a direct bolt in for the '82's....I've been trying to get a set of tan seatbelts for my '82 TA and have not had much luck and when I do find some, the plastic is all worn or cracked. Would this be for all 4th gens, or just certain years. Also, what about the rear seatbelts? Would they be a direct bolt in as well?
Old Oct 25, 2006 | 12:18 PM
1982TA's Avatar
Car: 1982 Trans Am
Engine: SBC 400
just wondering about the rear seats...did the 4th gens have the rear lap belts or did they switch them to the shoulder belt style like the fronts? I need some rear seatbelts and I want just lap belts for my '82, since the shoulder style most likely wont fit.
Old Oct 25, 2006 | 07:31 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
all year 4th gen front belts will be a direct bolt-in. they will bolt into later 3rd gens too, but there will be a large gap in the plastic door sill trim. As for rear belts, i converted my 84 TA to rear 4th gen shoulder belts, but it was a PITA. They are far from a bolt-in. You'll want to get rear lap belts from a 3rd gen between 82 and 88, they went to rear shoulder belts in 89.
Old Oct 25, 2006 | 07:59 PM
1982TA's Avatar
Car: 1982 Trans Am
Engine: SBC 400
great...people want too much money for seatbelts, weather tan or black. I can get a set of 4th gen tan for $20 front and back...much cheaper than a set from a 3rd gen but I wont have any use for the rears, and the colors from 3rd to 4th gen probably wont match either. I was thinking about black also, I know someone who can get me a black set too from a 4th gen, but finding third gen, and just the rear is a different story.
Old Oct 25, 2006 | 08:11 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
i think i still have a black set of rear lap belts that i had in before converting to rear shoulder belts. I think they were in pretty good condition, but I don't remember exactly how good. I can try to hunt them down and send you some pics if you're interested. I think I also have the original tan belts from the car, the fronts are in rough shape but there rears might be good
BruceEmbry's Avatar
Buying use seat belts are not a good ideal. Most cars you find in salvage yards has been involved in accidents. Used seat belts, retractors that have been involved in accidents have undergone a strain which could reduce there effectiveness in the next accident. I guess its your life.
Old Oct 25, 2006 | 08:18 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
i have to disagree with all of your points. the majority of cars I have seen in junkyards aren't there because they were wrecked in an accident. Also, I don't believe that seatbelts are a one-time-use item where they are automatically damaged if they were in a car that was hit. I don't think you are any less safe with seatbelts that appear undamaged from a junkyard car than you would be with the original seatbelts from a car made in 1982.
Old Oct 25, 2006 | 08:29 PM
BruceEmbry's Avatar
I did not say my originals were still safe. I have been trying to replace them for years.
But like I said, its your life. As for me, I would not purchase any use safety belts.
1992 Trans Am
May 10, 2023 07:19 PM
Navy8125
Aug 22, 2015 07:13 PM
firebirdchick28
Mid-West Region
Aug 16, 2015 02:52 PM
TRANSAM82-92
Interior Parts Wanted
Aug 15, 2015 01:26 PM
scottmoyer
Aug 9, 2015 10:18 PM
