Help - need info/pix on cargo cover mounting
Old Oct 29, 2006 | 11:27 AM
pgtr's Avatar
Car: 84 Firebird: F41, Pwr, Instr Pkg
Engine: LC1 (V6 2.8L, 280k mi)
Transmission: MD8 (700R4)
Axle/Gears: GU5 (3.23)
I am looking for pix of the mount clips, where they install, how... for the retractable cargo shade as well as a pic of it's 'hook' point under the hatch.
thanks!
Old Nov 3, 2006 | 01:34 PM
pgtr's Avatar
Hello,
I'm trying to retrofit this on my '84. All I have to go on are the generic 'sketches' in the owner's manual. If someone has a couple of decent images of the trunk area with one installed showing both the mounts for the cover behind the seat and the 'hook' arragement under the hatch itself to help me from flying blind as I start to cut/drill/fabricate...
appreciate it very much
Old Nov 3, 2006 | 02:22 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Here you go, there should be a few here that can help. BTW, I have the mounts, the rear panel, and a vinyl replacement if you need any of them.
https://www.thirdgen.org/forums/sear...1&pp=50&page=2
Old Nov 4, 2006 | 01:01 PM
pgtr's Avatar
Thanks! I see now where the holes are so I can modify my plastic trim under the hatch. Is there a metal plate behind those holes or does it just depend on the strength of the plastic?
What would also help is an image showing the precise location/configuration of the cover mounts on either side...
Anybody?
Thanks again Iron Duke
Old Nov 4, 2006 | 02:58 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
there is a metal plate back there that forms with the plastic. you will need to fabricate that as well.
Old Nov 4, 2006 | 03:48 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Anybody?
If you remove the plastics there is an outline on the back that will tell you exactally where to cut.
Old Dec 9, 2006 | 09:37 AM
Bill/T/D/Y's Avatar
Car: 90 R/S camaro 3.1L stock,
Are ya talkin about the old roll up like a shade at the house cover?I just picked up the cover myself at the bone yard.Will be doin the mods soon as i get the rest the parts from the carcass.Will try ta do the pic thingy and step by step.T do know that the rides with out the option originaly do not have the metal brackets under the interior panels to mount the holders for the rollup cover.Ya will have to find and remove em or fab some yerself.I cut mine out of the dead car.Can try ta measure them and take pics.
I have most of what i need here just paln to go back for the interior panel parts so i won't screw up mine by trying to cut out the holes myself.Also leaves me with spares just incase.
Old Dec 9, 2006 | 10:04 AM
Bill/T/D/Y's Avatar
this is what i have to put in my 90.
Attached Thumbnails Help - need info/pix on cargo cover mounting-dads-new-cam003.jpg   Help - need info/pix on cargo cover mounting-dads-new-cam004.jpg   Help - need info/pix on cargo cover mounting-dads-new-cam015.jpg
Bill/T/D/Y's Avatar
last pic is of the brkts from under the panels.
Old Dec 16, 2006 | 07:05 AM
Bill/T/D/Y's Avatar
I know this is an old thred but am doing this mod to my 90 right now.Just picked up the interior panels yesterday at bone yard.Plan to take pix of process and try to take accurate measurements of all brkt locations for anyone else that wants ta do it.
Old Mar 25, 2007 | 06:48 PM
DubyaSsixTA's Avatar
Re: Help - need info/pix on cargo cover mounting
thanks!
Old Mar 29, 2007 | 08:11 PM
GEOFF1983Z28's Avatar
I have many parts for this set up ,including a nice civer and misc hardware and trunk trim w/notches for hook up
Let me know.......PM Me
Hotrodboba400
Dec 10, 2019 07:07 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
