Help my "new" Seats out of a "smokers" Firebird STINK like cigarette smoke
Old Nov 2, 2006 | 10:18 AM
Arctic White 91 RS's Avatar
Car: 91 RS/ 99 T/A/ 72 Vette/ 02 Z28
Engine: LSx/ Dart400
Transmission: M6/ M6/ TH400/ 4L60E
Axle/Gears: 4.10's / 3.08/ 2.73
Help my "new" Seats out of a "smokers" Firebird STINK like cigarette smoke.
I would appreciate suggestion on how to get the stink out of the seats before I bolt them into the RS. Other can vacuuming them real good, I'm not sure how to clean them/get the smoke smell out of the cloth.
Thank you in advance.
Old Nov 2, 2006 | 10:28 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I've heard that a product called Febreze is quite good. I have a friend who sells used cars, and he uses it regularly.
Auto: Specially designed for use on the fabric surfaces of your car interiors
JamesC
Old Nov 2, 2006 | 10:43 AM
92vert's Avatar
Car: 1992 Firebird Convertible
Engine: 305 TBI V8
Find a carpet cleaner or fire restoration company that has an Ozone machine. Will eliminate smoke smell every time.
Old Nov 2, 2006 | 11:35 AM
MaineIrocer86's Avatar
Car: 1986 Z28
good luck, i bought a truck off a smoker and even after having it cleaned i sometimes still get strong wiffs of it from time to time......
Old Nov 2, 2006 | 12:07 PM
jkicak's Avatar
Car: 87 Formula 350
i agree with the last post.... GOOD LUCK! i didn't end up getting used seats off ebay because there is just no way to tell for sure if they smoked or not....
about 10 years ago i inherited my father's 1992 lumina euro 3.4 because he fell and became disabled with emphzima due to his heavy smoking... the car became my winter rat and i spent one day a month (in good weather) for the next 5-6 years i had the car cleaning it and spraying EVERYTHING down with many products but the smell made it's way back every time. the only way to really get rid of the smell is to replace everything from the carpet to the headliner and inbetween (even the ac/heater ducting)
Old Nov 2, 2006 | 01:15 PM
jstoltz's Avatar
Car: 1987 Iroc-z Convertible
friend of mine (also owns a used car business)has an enzyme eater another version of the ozone machine. it works great everytime. that is the cause of the smell is th emicroscopic enzymes left behind this kills the enzymes instead of trying to cover it up. not cheap though.
Old Nov 2, 2006 | 01:39 PM
Stevo's Avatar
Car: Pair of 92 Z28s
exactly what was said above ^
You can spray all you want overtop of it...but there is still DIRT on the seats...years of smoke just has fallen into the cloth. I cleaned a grey carpeted center console from a camaro that had been smoked in its whole life and id scrub it and scrub it and you just watch the yellow dirt/mud color water come out...I was constantly spraying it with a hose...it was nasty.
I have a steam cleaner at my work and ive had great success with that and about 3 different cleaners i use with the hot water.
Old Nov 2, 2006 | 11:46 PM
Rick King's Avatar
Car: 1987 TA
Engine: 350 stock/twecked
here is what I use when redoing apartments it kills smoke and pet smell, quite pricy, but it works.
here is the link
https://www.zeroodorstore.com/
I also believe in steem cleaning as that is what sems to work on the antique furanture that has 120 year old fabric on it
later and
GB
rick
Old Nov 2, 2006 | 11:53 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
hmm, good ideas here. I think if you can remove the seat covers (hog rings, good luck), and hose 'em off, throw 'em in the wash, etc, that might help.
I've never had a REALLY bad case, but the few smokers cars i've worked on, i've been able to get perfect with this:
-remove seats, put them out in the sun. (you're in carolina, you still get that now right?)
-spray all upholstery with febreze, I don't like the auto version, it's got the new car smell in it. I like the original, or unscented I think.
-mix some simple green with water, I think 10:1. Put it in a spray bottle, spray and scrub with a nylon bristle brush. Tire brushes work ok for this, if the bristles are stiff enough. Spray, scrub, vacuum with a wet shopvac. Repeat. Again and again and again. The simple green has a clean sort of "stink" to it.
-Then soak it with febreeze and let it sit in the outside air, catching fresh air, nice breeze that sorta thing. Go back and spray it with more febreeze (from every angle! underside too!)
Spend a day doing this, and leave 'em outside for another day or so, they should smell a little funny, but not like smoke. After a week of use they'll just smell normal.
Old Nov 3, 2006 | 05:42 AM
JamesC's Avatar
I noticed yesterday afternoon that Motor Trend Magazine recommends Febreze--not that that in itself is the untimate recommendation.
JamesC
Old Nov 3, 2006 | 07:23 AM
I appreciate the tips and suggestions. I'll start on this tonight and post up the results later. Thanks again.
Old Mar 20, 2009 | 09:52 AM
Aarons92Maro's Avatar
Car: 1992 Camaro RS & 1994 Mazda 626
Engine: 305 TBI V8 / 2.0 4-cyl.
Transmission: 700R4 / I have no idea
Axle/Gears: Stock 2.73 / I don't know
Re: Help my "new" Seats out of a "smokers" Firebird STINK like cigarette smoke
Here's my suggestion. Take up smoking. Then you will have a more uniform smell in your car, not just the seats. You'll get used to it.
Old Mar 20, 2009 | 11:15 AM
88TransAmFreak's Avatar
Car: 1971 Camaro
About 10 years ago I got a 1994 S10 from my brother who smoked. I ended up pulling the upholstery off the seats and actually washed them.
I also power washed the foam padding and let it dry completely.
I hung them on a clothesline and after they dried I reinstalled them to the seat with new hog rings.
They actually looked brand new when I was done with them and no cigarette smell.
May take a little extra effort to do this, but it will work
Old Mar 20, 2009 | 12:51 PM
Chevy8588's Avatar
Car: 1987 Iroc Z28/ 1982 Z28
Engine: 355 TPI IP/ 305 CFI
Transmission: T-56/ 300C
Axle/Gears: 3.42 Open/ 3.73 Posi
find a dealership near you that offers "mist" service, its an ozone fogger that kills interior odors, usually works on the first time, but sometimes requires two shots
Old Mar 23, 2009 | 10:16 AM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
Someone told me that oxidation from those ozone machines will yellow plastics and make them brittle.
Old Mar 26, 2009 | 12:54 PM
wulfgar the pen's Avatar
Car: 1988 sc camaro, 1986 IROC
Engine: 2.8 v6, 305 tpi (for now)
Transmission: automatic, auto( for now)
this real the only way, leave your doors open and your seats and stuff outside for a couple of days.....spray everything
or use massive amoounts of pine air fresheners.....
nasty pine smell will make you forget the smokey smell
Old Mar 28, 2009 | 04:47 PM
TPI-RS's Avatar
Car: 1991 RS Hardtop
Axle/Gears: 3:23
This might sound a little crazy, and I've never personally tried it but... I've heard that if you pour some white vinegar into a bowl and leave it near *whatever smells*, seats in this case... it will remove oders. I would say put the seats in a small room (bathroom maybe) and leave the bowl of open vinegar in there overnight.... see if it helps.
Again.. i haven't tried this myself, but I've heard it works...
Old Mar 28, 2009 | 05:00 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
am i the only one to see that this is an OLD post
Old Mar 28, 2009 | 05:03 PM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
I know Vinegar, and water is good for getting the 'tar' off of a windshield from a smoker... But when I had to clean my seats I brought it to my coin wash.. They have these awesome heated foam cleaning brushes for interiors.. Works great.
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
dyeager535
Aug 28, 2015 08:10 AM
Moore89
Aug 24, 2015 07:06 PM
