HVAC lighting
Car: 88IROC Vert
Engine: ZZ383
HVAC lighting
My 88 IROC has horrible lighting on the hvac controls. How many bulbs are back there? Upgrade ideas...if any? thanks
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Super White LED lamp(wide angle).BTW firebird Hvac use 3 tiny(#74) lamps.They are also slightly taller & shorter than camaro Hvacs.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The Camaro uses one 194 bulb (pass side of the HAVC head). A higher intensity 194 will help, but not as substantally as we'd like.
JamesC
JamesC
Car: 88IROC Vert
Engine: ZZ383
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
If you want high intensity try xenon bulbs.Forwarned though they can/may melt your sockets.Believe i know ive tried it.The are VERY bright though, but get EXTREMELY hot.Ive seen some at walmart though that are lower wattage then the ones i bought on ebay & they are xenon, but i dont have any first had experience with them.If that is not a alternate route.You can try a nine LED lamp(see pic), but you may have to enlarge the opening or the lamp may be too long.Ive got one of these in my OH console map light,very bright!
Mine are Xenon. I haven't experienced any problems with them whatsoever; however, I don't drive all that much at night either.
JamesC
JamesC
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
I lined the lamp cavity with aluminum roofing tape(also did the same with the instrument cluster).It's made a big difference in the amount and quality of light with the cluster.The lighting in the HVAC contol head is better but I think I'll try one of the Xenon bulbs in there.
Here's an old link that may be helpful (check the end for some bulb info):
https://www.thirdgen.org/forums/body...r-cluster.html
JamesC
JamesC
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
i use xenon bulbs in my hvac, tranny temp, and shifter plate, and they light up a little better than stock.
i used to have them in my cluster also, but i guess i had bad luck as they slowly burnt out, one by one, until i had 3 left. I then swapped in some plain jain 194's.
....I do drive around w/ my parking lights on though, so that's probably part of the reason i had premature death of my xenon bulbs.
look online too, i got mine for about a dollar a piece, beats paying more than twice that at walmart.
Car: 92 Firebird - 97 Talon TSi AWD
Engine: Firebird: 3.1L - Talon: 2.0L
Transmission: Firebird: 700r4
I need to get a few new bulbs for my hvac and my shifter plate... I didn't even know they made xenon 194s... Are they really worth the extra money?
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Another draw back to the higher wattage xenons is they may overload your headlamp switch.If your going to buy get them a cheap as possible.Try ebay!I taped aluminum foil to the back of the metal gauge bezel.
that looks really sweet 84, just foil and a xenon?
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
No, no xenons anymore too much heat.They warped some of my sockets & partially melted others.All my interior light are LEDs.Only the warning lights,the 2 turn signals(arrows) & hi-beam indicator are standard 194 bulbs.Since those are seldom in use.The foil is used on the black metal trim bezel that surrounds the gauges.
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
Has anyone swapped to the 4th gen controls??????? Would like to hear about the swap...Thanks, Tom
Car: 1991 Trans Am
Engine: 5L TPI
Car: 88IROC Vert
Engine: ZZ383
brighter bulbs
I ended up going to walmart and bought GE "Nighthawk" bulbs which claim to put out 20% more light than standard 194's. I wrapped the inside "socket" where the bulb sits with foil and can honestly say there is a difference. Why GM didnt put another bulb over by the fan speed switch...
Car: 1986 Trans AM
Re: HVAC lighting
Aren't the 194's too big for the HVAC and shifter plate?
Any one know the LED #s for the trunk light, (3?) HVAC lights, the light above the HVAC, and the light in the center console?
