My new gas/brake pedals
Old Nov 22, 2006 | 08:07 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Well there not axactly new.I put these on quite a way back.I just got around to finishing what i started.Basically i welded on the little brackets that hold the Brk pedal/nuts on.I also slightly enlarged the holes so the edges wouldnt show from the pedal side.The same for the Gas pedal.Weeeeeeeeeeeeeeeee
Old Nov 22, 2006 | 08:11 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Heres the gas pdl.The brackets are hand made/cut.Theyre angled beacuase thats how the stock piece is on the back.Im using the original spring & pin.I found two little bushings that fit perfect between the brackets & spring.This way theres no slack form left to right.It pivots just like the stock piece too.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
gmoutdoorsman
Oct 3, 2015 11:42 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
ironbmt
Sep 27, 2015 06:00 AM
Night rider327
Sep 2, 2015 04:18 AM
