i think i might get flamed for this but...
Old Dec 6, 2006 | 04:13 PM
DillonRager's Avatar
does antone know if it is possible to put a second gen dash and console into one of our cars because i like the second gen stuff even tho it is kind of like taking a step back. I think it would be different because ive seen 4th gens dashes all the time.just think it would be unique.
Old Dec 6, 2006 | 04:17 PM
bfox88's Avatar
Car: 90 IROC-Z
i think i posted this question awhile back and what i was told is that it isnt large enough to fit or maybe the other way around...something along those lines.
Old Dec 6, 2006 | 05:27 PM
damn it!!
Old Dec 6, 2006 | 06:39 PM
Slayre's Avatar
Well, that doesnt mean you can mod it to fit, make it longer or shorter. To be unique, you have to do unique things.
Old Dec 6, 2006 | 06:49 PM
very true i was also thinking about the corvette dashes because i dont like the big overhang on the passenger side of th thirdgens i'll prob end up puttin in a fourth gen interior i was just weighing my options
Old Dec 7, 2006 | 12:54 AM
roachjuice's Avatar
Car: 86 Omni GLHT
Engine: 2.2 Turbo/Intercooled
Transmission: 5 speed
Axle/Gears: 3:85
i like the stock dash and gauges.....
Old Dec 7, 2006 | 01:16 AM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
i'm a stock **** myself, but its always interesting to see what ppl do with their time and resources.
of course on their car, not mine.
Old Dec 7, 2006 | 12:35 PM
so do I except for the passenger side hang over it wobbles too much or is that just my car?
Old Dec 7, 2006 | 01:22 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Check the screws on the underside of the part that hangs over. There are supposed to be a handful of screws down there holding the dash pad on.
Old Dec 7, 2006 | 02:58 PM
ITS HELD ON GOOD JUST SEEMS LIKE THE WHOLE DAMN THING SHAKES BUT ILL HAVE TO DOUBLECHECK THANKS
Old Dec 9, 2006 | 12:58 AM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
you may have loose screws or broken mounts that connect your plastic dash shell to the top of the firewall. Remove your dashpad and take a look at the 6 or so screws that hold the top of the dash assembly into the car. My firebird had some broken plastic mounts that made the dash move around quite a bit. I believe the camaro ones are metal reinforced though, so it's less likely to be the case.
Old Dec 13, 2006 | 09:20 PM
roeville's Avatar
Car: 1991 Camaro
It's the dash pad itself on the 2nd gen dashes that are inferior. One of the worst engineered dashes Chevrolet ever made. They consistantly warp. It is rare to see a second gen Camaro with one that isn't warped.
Old Dec 14, 2006 | 04:52 PM
maroon85's Avatar
Car: '85 Firebird
Engine: 2.8 V6
Transmission: stock BW 5 spd.
Axle/Gears: stock 3.42
you could customize/build one to look like a 2ndgen dash, start with a stripped dash shell/frame & go from there
Old Dec 15, 2006 | 08:50 AM
master_mitch's Avatar
Good man, good to see some other 17 year old camaro owners on the forum!
Old Dec 15, 2006 | 09:45 AM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
And as for the dash. Awesome. All you would have to do (I say it like its easy) is fiberglass each piece of the second gen (if its shorter than the 3rd gen dash) a little longer....and vice cersa if its too long. Im an engraver for an awards company so everything always has to be proportionally correct, and measured to the thousandth. Its harsh but everything looks so good. Remember measure TWICE cut ONCE.
Old Dec 15, 2006 | 01:38 PM
Stealthy-One's Avatar
Car: 89 RS
Engine: 2.8
Transmission: 700r4 auto
Axle/Gears: huh?? guessing stock.
hey I H8 WWD, check the post starters sig for the reason behind the 17year old comment.
Old Dec 15, 2006 | 02:21 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Darn I'm 19.....looks like I cant be in that club.....
I like that sig.
89 IROC + 19yo + HEAVY FOOT = SIDEWAYS
I have a go-kart that does 60mph and thats where I started to learn how to drive....and go sideways....ITS AWESOME. But now I have to learn in a CARRRR. Yeah alot bigger. LMAO. Well dont want to talk to much when its not needed.
KEEP IT SIDEWAYZ......MY FELLOW AMERICAN MUSCLERS
WHERE IS MY SIG??? IT COMES ON AND OFF EVERY ONCE AND A WHILE
Old Dec 15, 2006 | 09:13 PM
i learned on a gokart to if you want to make sure your sig show check the box below (show your sig) before you hit post quick reply
Old Dec 16, 2006 | 12:07 AM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Okay got it now. I had to check the box in the FULL POST. Thanks though.
Old Dec 21, 2006 | 12:36 PM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
I've got a 2nd gen (81 camaro), and a third gen (90 formula), both
in various stages of extensive restoration. (I have 2 many sons, with
to-short attention spans. Long boring story...) While everything is
possible, be aware that what you're considering is not for the faint
of heart. Getting the secondary things like heater/ac ducting to match
will be truly daunting. What about something like putting aftermarket
gauges into a custom panel to replace the instrument cluster?
Good luck, kk.
Old Dec 21, 2006 | 12:47 PM
tourville's Avatar
Car: 1991 Camaro RS
Transmission: 700R4 Auto
Axle/Gears: 1 legger 2.xx(needs upgrade)
I like that sig.
its all good im 19 also so we can get our own club
Old Dec 21, 2006 | 01:22 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Hell yeah.
And on the case of the dash....I am just getting my STOCK 3rd gen dash ALL FIBERGLASSED to look stock appearing....then maybe mold in my Laptop and radio and maybe a new guage cluster....nothing to drastic....I like the stock 3rd GEN dash....except the big rectangle on the pass side.....but thats where my laptop will be...on a holder and slider so I can move it towards me closer. HELLZ YEAH
Old Jan 1, 2007 | 10:22 AM
Pat Hall's Avatar
I was just telling one of my car buddies over coffee the other night how much I don't miss the old 77 Camaro I had years ago, since everything in it was so cheap and cheesy, especially the dash! The only thing I wish Chevrolet would've carried over to the thirdgen models was the 8.5" ten bolt rear, they're fairly indestructible! I remember the doors sagged so bad on that car due to crappy, worn out hinges, that I used to jack the whole car up every few months using a 2x4 and a floor jack under the ends of the doors just to get them to shut again. And don't even get me started on how many times the outer door handles broke. Lol.
Old Jan 1, 2007 | 04:26 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
wow, shouldn't you have replaced the hinges or bushings rather than bending the body to compensate for it? I can't imagine doing that to a car that I gave a damn about
Old Jan 1, 2007 | 09:53 PM
Pat Hall's Avatar
Lol, yeah if it was a car I actually cared about, sure I would've rebuilt the door hinges. I only paid $350 for the whole car, and it was a total rust bucket. I remembered to not leave any sockets on the back floorboards after one of them rolled out of a big hole in the floorboard. Not only were the door hinges shot, the driver's side striker post was all messed up and whoever owned it before me tried to weld it in place, which made it even worse. That car was so rusty I could reach down through the door jamb vent, which was missing, and stick my hand through the hole at the bottom of the quarter panel in front of the rear tire. The original 305 in it used about 2 quarts of oil a week, and I finally ran it out of oil, causing a spun rod bearing. I considered it a mercy killing for that tired old 305. The body was totally trashed on that car, but I dropped a small block 400 in it and had a lot of fun with it until a bad wrist pin caused the 400 to grenade. After that I kept the TH350, the gauges, spoilers, etc., and sent the rest of it to the boneyard. Ahh, what memories!
Old Jan 2, 2007 | 08:48 AM
$350 rustbucket explains why everythinjg was junk on it dont you think
Old Jan 3, 2007 | 02:09 PM
Rage789's Avatar
Car: '85 El Camino SS
Transmission: Turbo2
Old Jan 3, 2007 | 06:40 PM
Pat Hall's Avatar
Not necessarily. Ask someone who's restored a 2nd gen camaro how hard it is to find decent parts for it and how hard it is to keep one up. I've already been down that road along with several friends of mine. My thirdgen is a lot easier to keep up. Even though thirdgens have a lot of stuff that universally go bad on almost all of them, it still pales in comparison to the 2nd gens. Between the 69 RS/SS and the 89 RS, I'm more than happy with the f-bodies I have now.
Old Jan 4, 2007 | 11:05 PM
turbochargedrs's Avatar
Car: Fire Red 89 RS
Engine: 2.8L :(
if you wanna put a lap top in your car go to the police junk yard where they scrap there cars and you can buy the mount andthe equipment to hook it up just get the one for the lt1 camaros the troopers have and not for the crown vics.
Everything gets hard to find as the years pass because there are fewer to be had. You can however get many reproduction parts from many different manufacturers. Also you could see if like this forum someone has set up an "online junk yard" and maybe you can get what you need there. As for the up keep if you tint your windshield and windows you'll stop a large portion of the problem. the older parts are very suseptable to warping in the sun. A tint will stopp some heat and can stop a good amount of uv rays if you choose the right tint.
Last edited by turbochargedrs; Jan 4, 2007 at 11:09 PM. Reason: Automerged Doublepost
Old Jan 5, 2007 | 02:23 AM
Pat Hall's Avatar
Amen brother. I can sum up the reason my thirdgen dash doesn't have any cracks in it with one word. SUNSHADE. Same thing goes for the tops of the rear seats. LOUVERS.
db057
Apr 28, 2019 07:45 AM
KNIGHTE
Southern California Area
Oct 22, 2015 09:11 PM
2012sergen11
Oct 13, 2015 07:38 PM
Hello, Michael
Sep 11, 2015 01:10 PM
buckshot63
Sep 10, 2015 09:15 AM
