this is odd
Old Dec 19, 2006 | 02:04 PM
maroon85's Avatar
Car: '85 Firebird
Engine: 2.8 V6
Transmission: stock BW 5 spd.
Axle/Gears: stock 3.42
this is odd
i don't know if i'm putting this in the right section but,...
my windsheild keeps fogging up on the inside, the glass is wet & it drip onto the dashpad, what is going on? & how can i fix it?
Old Dec 19, 2006 | 02:11 PM
rwdtech's Avatar
Car: 1991 Z28 (sold)
when is it happening?
Old Dec 19, 2006 | 02:55 PM
maroon85's Avatar
Car: '85 Firebird
Engine: 2.8 V6
evertime i go out to my car it's like that
Old Dec 19, 2006 | 03:19 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Axle/Gears: 3.55 Wavetrac
Sounds like you may have a leaking heater core(small leak) that is bringing moisture into your airvents. Do you have a antifreeze smell in the car? Does your A/C selector control work meaning air is forced out the individual vents(defrost,floor,etc.) depending on which area you select? If you are only getting air through the defrost vents it could be a faulty vacumn select valve. The reason I say this if moisture is going on the windshield all the time that is also another problem. Also, check for a hole or crack in your condenser box inside the engine compartment. You could be getting moisture from there from the outside. Or, somehow water is leaking at the bottom edge of the windshield? Did'nt mean to write a book, just thinking of possibles> Baman
Old Dec 19, 2006 | 05:55 PM
maroon85's Avatar
Car: '85 Firebird
Engine: 2.8 V6
my trunk leaks & one of my t-tops leak, would this have something to do with it?,
Old Dec 19, 2006 | 07:36 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Maybe, but what about the things I mentioned? Badman
Old Dec 19, 2006 | 08:38 PM
Firebat's Avatar
Old Dec 19, 2006 | 11:32 PM
maroon85's Avatar
Car: '85 Firebird
Engine: 2.8 V6
i don't notice a smell, the heater controls & defrost work but i don't know what it's set to, it's also on the side windows sometimes & i'll check the condenser box tomorrow, i just hope it's not something major,
Mark_ZZ3
May 24, 2018 01:02 PM
Stryker412
Sep 20, 2015 06:59 PM
Fronzizzle
Sep 8, 2015 12:10 PM
Warlocksirix
Sep 3, 2015 12:26 PM
BlackphantomZ28
Aug 31, 2015 11:19 AM
