Opening electric trunk without key or motors
Car: 91 Z28
Axle/Gears: Stock
Hi folks...its been about a year since we were working on the Z...and were back at it...we have a problem....
We need to drain the turpentine (er..I mean fuel), and replace the fuel pump...in order to do so, we need to be able to open the trunk...
The problem is...the trunk wont open...the key wont even turn and the switch on the console wont work.
The relay under the console works, and we can hear a "pinging" from the trunk area...the mechanic says its the overload circuit breaker tripping, because the motors are probably locked up (the car sat for 5 years).
So how can we get the trunk open when the key wont turn and the switch wont do it either?
We popped both sail panels, and the center cargo light, but couldnt see anything jump out at us to get it open?
91 z28
91 z28
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Huge screwdriver into the lock cylinder, smash with hammer, then twist and it'll open. Or figure out why the key won't turn, I assume you tried some lubricant? You may have to sacrifice your rear plastic interior panel and rip it out then unbolt the motor.
Open it from the inside. Pop out the courtesy light and with a flashlight you'll see a little thing toward the right that you can turn with a screwdriver and release the latch. I had to do it on a '92 I parted out. Took all of 1 minute from the time I entered the back seat until the latch was popped.
Car: 91 Z28
Axle/Gears: Stock
Yeah, we tried some lube in the lock, didnt seem to loosen it any...
Thanks for the tip...we popped the cargo light, but apparently he missed whatever gadget it is to pop the latch...Ill take another look...thanks!
In this case a little finesse is a much better route to take. If you use the old screwdriver and BFH method, you'll end up bending the s h i t out of the sheet metal where the lock cylinder goes. Just be patient and you'll eventually see the thing he mentioned. You could also try to reach the lock cylinder retaining clip with a long screwdriver or some other tool from the inside. If you can get that clip off, you can just pop out the whole lock cylinder and then use a flathead screwdriver through the cylinder hole to twist the latch assembly just like the lock cylinder does. A third option would be to use a battery charger and apply direct current to the wires going to the release solenoid.DO NOT DO THIS!
Car: 89 Iroc Convertible
If it has a pulldown motor you can reach behind the trim panel and grab the cable that connects to the lock cylinder.Pull on it hard toward the passengers side and it will pop the hatch.I have done this in many a junkyard car
I found this out myself one day at a local u pull it.I watched a guy pop the hatch open and then he showed me how he did it.Has come in handy many times
Car: 91 Z28
Axle/Gears: Stock
Well, turns out the solenoid that operates the latch is frozen solid...
No one mentioned having to take off the silver cover plate in order to see the slot for the screwdriver
Turns out that you have to take a 10mm wrench (I think) and take off the one bolt through the cargo light hole, then the silver plate comes off, revealing the manual latch release which can then be operated with a flathead screwdriver...
Now all I gotta do is locate a replacement solenoid assembly
Thanks for your help folks!
Car: 91 Z28
Axle/Gears: Stock
I just want to reiterate...
Not against any of the advice here...maybe my car was a bit different, I dunno...
But when I popped the cargo light, I looked and looked and didnt see ANYTHING that I could manually work with a screwdriver....
It was only after my uncle removed the silver plate directly behind the cargo light (with I think a 10mm socket) that you could easily see the slot for the screwdriver...you cannot see it unless you remove the silver plate...and...if I recall correctly, the slot for the screwdriver is on the passenger side of the latch itself (left as you look into the hole), not on the right as suggested above...
(I call it a silver plate, cause thats what it is...I suppose it is the mounting bracket for the solenoid...which you also cant see without removing it...)
Sorry Im not too mechanical with the whole shop talk
Axle/Gears: 3.45, 3.27, 3.27
Lon
Car: 91 Z28
Axle/Gears: Stock
Thats excellent news.
Last night I bought the solenoid, 2 sets of end links for the rear sway bar, and 2 packs of the lube for the bushings.
eightsixseven
Dec 16, 2024 01:50 PM
