What is up with my RPM Gauge?
Old Jan 8, 2007 | 06:17 PM
rsrsrs's Avatar
Car: 90 Camaro RS
Engine: 2.8L v6
Transmission: 700
Recorded a video of what it does. Seems to be workin, in reverse
http://www.youtube.com/watch?v=WjFelxfsDe4
Im hoping I don't need an entire cluster just for this.
Any and all help appreciated.
Old Jan 8, 2007 | 06:20 PM
Rocketerz's Avatar
Car: 1990 RS Camaro
Engine: V6
Transmission: Automatic
Does this happen when you start your car? Im sorry im not good at cars, or have your problem, but similar. My RPM is completely out but when I start the car it does that same jump. Ive taken it to a repair shop and they said VERY hard to fix that I gotta go in the motor or some dumb crap, so im not sure. Id like a fix though. But just posting my 2 cents, hope you get your problem fixed.
Old Jan 8, 2007 | 07:11 PM
rsrsrs's Avatar
Car: 90 Camaro RS
Engine: 2.8L v6
Transmission: 700
The needle stays pointing to the right all the time. The video i linked you to is what it does when I start it up.
Could there be a lose connection in the cluster?
Old Jan 8, 2007 | 07:47 PM
compuwiz1937's Avatar
Car: 2012 Corvette
Engine: LS3
Transmission: TR6060
Try just taking the plastic lens off the cluster and moving the needle back UP (NOT down) and to the stopper. See if that works.
Old Jan 8, 2007 | 07:58 PM
Rocketerz's Avatar
Car: 1990 RS Camaro
Engine: V6
yep mines definitly the same just looked at it alittle while ago, Im gonna look over your suggestion compu. Problem is as I mentioned, Im not all that great with anything with cars just very interested and a new learner. So gonna look it over and see if I can get some help.
Old Jan 8, 2007 | 08:27 PM
jetblast's Avatar
Car: 91 z28 convertible
Transmission: 5 speed
My 91 Z28 does the same thing. There is a thread about fixing them but from what Ive read is a little complicated, you have to buy resistors and some other stuff that I dont remember.
Old Jan 8, 2007 | 08:40 PM
Rocketerz's Avatar
Car: 1990 RS Camaro
Engine: V6
Wow im so stupid im still looking for the screws to take the plastic lens off lol
Old Jan 8, 2007 | 08:52 PM
Gramps's Avatar
Car: 87 Camaro IROC
lol looks like you got a really short stroke if you can rev your engine that high that fast.
Old Jan 9, 2007 | 06:04 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
If the tach is faulty, hit a bone yard. The last tach I purchased, a 5500 red line, was $15. Remove the black bezel, the clear plastic gauge face, then the metal bezel (all held on by screws). IIRC, the tach is held in place by two small screws. Remove them and simply pull the tach toward you. Reverse order to replace. Twenty minutes work even if you have no experience.
JamesC
Old Jan 9, 2007 | 08:23 AM
rsrsrs's Avatar
Car: 90 Camaro RS
Engine: 2.8L v6
Transmission: 700
is there a clip on the Headlights pull switch to take it off?
Old Jan 9, 2007 | 09:04 AM
Car: 2012 Corvette
Engine: LS3
Yes, pull off the blank below the headlight switch, and you'll see a little silver button on the bottom of the switch. Turn the headlights on and use something to push that button in (I use socket exentions) and then the switch will pull out, you can gently push the headlight **** back in to turn the headlights off without it cliping back in.
Oh, and my suggestion about just pushing the needle back around the other direction, if there's actually something wrong with your car, that won't fix your problem. I just remember my tach needle doing that when I was installing white face overlays, I pushed it over to far and it went down like that (that was with the key in the on position but the car not started). I don't know if that could possibly happen if someone revved the car to high or not.
Hotrodboba400
Dec 10, 2019 07:07 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
Jk_Under
Sep 8, 2015 08:13 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
