No Centre Console
Car: 1988 Camaro RS
Engine: 305 TBI
No Centre Console
Hello from Australia!
I am a new Camaro owner - 88RS w 305TBI - and am wondering if anyone has modded the interior to remove and leave out the centre console, relocating the few switches it has, and maybe using a B&M shifter or similar.
This in an effort to free up some cabin room for us 6'2" aussies.
Any ideas appreciated.
Tim
PS There is a small switch between the elec window switches - what should it do?
Tim
that switch is the hatch release button, and only works when in park I believe
the only problem I can forsee is where you would locate the heater controls and radio, other than that, sounds interesting
Car: 1984 camaro
Transmission: th 350
Axle/Gears: 3:42
the small switch unlocks the hatch and if you have good hatch struts could let it open all the way. sometimes convinient. just a suggestion but you could just get the seat tracks extended. a b&m megashifter will fit in the console. but if you dont mind relocating the switches then yes you can remove the console.
Car: 1988 Camaro RS
Engine: 305 TBI
