Gauge Problems!!!!PLease help
Car: 1984 Camaro Z28
Well i am 16 get my license in 17 days!!! lol.... But me n my dad took my car out just got a new jasper 305 w/ holley carb...i have the old 85 mph gauges in about 10 sec. i was goin 85 then the speedo quit working my dad said i prolyy got it up to about 120 or so...but since that speedo hasnt worked... dad is friends with a mechanic and he said i would have to put in a new trans....sounds to extreme pls comment!!!!!!!!!!!!
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
smack your dads friend.
its possible you broke, or jammed the speedo. is the needle stuck at 85 or is it sitting at zero? is it a electric speedo or a mechanical one, check the sending unit on the tailhousing of the trans. it may have come off or is loose. if the sending unit is wasted its not very expensive, i see no reason why the trans needs to be replaced, unless the speedo is not moving because you blew the trans and in that case the car would not move either
well it is sitting t zero but i dont know about the elec. or mechanical ill have to check...but my dad said his friend just didnt want to mess with it lol...thanx though...i figure it is prolly the sending unit...thanks alot though
if i broke the speedo woul i only have to get a new one? b/c i wanna replace all the gauges anyway
Last edited by jacob_stevens09; Jan 14, 2007 at 12:36 PM. Reason: Automerged Doublepost
Ghettobird52
Jul 5, 2024 11:18 PM
