Speedometer Jumpy
Old Mar 5, 2007 | 10:08 AM
razormedic911's Avatar
Car: 89 Camaro RS
Engine: 2.8 60v6
Speedometer Jumpy
OK, I need some help. Last week I had my gauge cluster out to install white gauge face overlays. After I was finished, I reinstalled the cluster, and made sure all the connections, inc the speedo cable were connected. Also while it was out I performed to fix on my trip noted in this forum.
Now that the cluster is back in the car I have found 2 problems: the firt, and more annoying is that my speedo neeedle seems to jump a 20 mph span whenever i'm going over about 40 mph. I read in another thread this may be a sign of the cable binding? If so how do I fix it? Also does anyone have any other ideas?
The other problem is that my temp and oil pressure gauges donot seen to work anymore. They worked before, but don't move now. Everything else is working fine, so I'm stumped. Any ideas would be great. Thanks
Old Mar 5, 2007 | 10:58 AM
online170's Avatar
Car: 1987 Firebird
Engine: 355
Theres usually a little tab that secures the speedo cable to the cluster, before getting carried away with binding, id make sure its on there. I beleive you have to listen for a "click". Tough space to work in, but start with simple things first.
Old Mar 5, 2007 | 11:54 AM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
your overlays interferring with the gauges perhaps? could explain the oil and temp gauge malfunction.
did you pull each individual gauge out? maybe they're not seated.
Old Mar 5, 2007 | 12:07 PM
Car: 89 Camaro RS
Engine: 2.8 60v6
thanks, but like i said, i made sure the cable was secured in the retainer clip when i reinstalled it, however i will recheck in this afternoon just in case.
Old Mar 6, 2007 | 05:39 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
If the overlays aren't interferring, perhaps the cluster itself isn't seated properly.
JamesC
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
Bigold4x4
Sep 28, 2015 05:21 PM
TrevinE
Sep 14, 2015 03:20 PM
