4th gen A pillars with dash swap in a 3rd gen
Old Mar 21, 2007 | 10:19 PM
00turboT/A's Avatar
I have searched everywhere on here and can't find out how everyone is cutting there A pillars when they put there 4th gen dashes in. I have seen pics of them, but no clear ones. I'm wondering how there lining up at the top of the dash pad. I would like a shot looking down through the windsheild. I can't get that part to line up.Any help would be awsome. Also its a 1988 Iroz convertable with a 2001 T/A dash in it. Here are some quick pics
Old Mar 21, 2007 | 10:36 PM
1986Z28OWNER's Avatar
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
Re: 4th gen A pillars with dash swap in a 3rd gen
very cool project, makes me almost wanna do it myself
Old Mar 22, 2007 | 08:03 AM
budofbama31313's Avatar
Car: 91Z, 97RS, 99Z, 02Z
Engine: TPI 383 Vortec, 3800, LS1, LS1
Transmission: T56, 700R4, T56, 4L60E
Axle/Gears: 3.73, 3.43, 3.42, ?.??
I am doing the same project (interior, not motor), but putting a 97 dash into a 91. Haven't gotten to the a-pillars yet but soon. So when I get to them I'll post my results if they are still needed.
Old Mar 22, 2007 | 10:17 AM
00turboT/A's Avatar
Anyone out there???? I need help with this guys. I knwo someone has done it.
Old Mar 22, 2007 | 01:09 PM
d10pins's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L
Axle/Gears: 3.70
here how i did mine. i cut off the 3rd gen apiller at the top. then cut the fourth one so it would fit underneath the 3rd one. then i super glued it. here a pic.
Old Mar 22, 2007 | 03:42 PM
Slepewesel's Avatar
Car: 91 Camaro Z28
Engine: 5.0 TPI (LB9)
Transmission: 4L60
d10pins, nice but need some bigger or clickable pics there. Too small to see.
As for the first guy, check out this link, its shr00m's car, and he has nice detail on what he did about his....
http://www.ms-fbodies.com/jade_ta.htm
And I see you already have power windows on your car. Bastard ... I'm going thru the process of installing all power stuff into my 91 Z. DO NOT want to do this again ...
Old Mar 22, 2007 | 05:23 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
it looks like the way you do your a-pillar trim would be different than most others since you have a 'vert. Can you post a pic of how your stock a-pillars look? it looks like ASC cut them and tucked them under the convertible specific trim piece and, judging by of the earlier replies, you may be able to tuck them under the same way with the 4th gen pillars.
Old Mar 24, 2007 | 01:13 AM
00turboT/A's Avatar
Can I get some bigger pics of that. And also how much trimming needs to be done up by the Dash pad if any. Can you shoot a pic of it right by the top of the dash pad????
Yeah I love how shroom did his by molding his in but I'm not that talented with fiberglass and bondo. I would like to trim them and ct them down and make them work if possable. P.S having the power windows helped a ton thats for sure.
Last edited by 00turboT/A; Mar 24, 2007 at 01:17 AM. Reason: Automerged Doublepost
Frozer!!!
Jan 19, 2024 04:55 PM
Jorlain
Aug 24, 2022 05:11 PM
Casey Meyers
Mar 2, 2016 10:46 AM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
