Not so successful LED bulbs
Old Apr 30, 2007 | 04:42 PM
CommieTerrorist's Avatar
Car: 92 Camaro RS
Engine: lO3
So when I got my 92 about a month ago, half the the gauges wouldn't light up at night. So this past weekend I finally got around to trying to fix it. Tried to get replacement bulbs, but mine said "Replace Entire assembly" on them which means I needed the plastic twist on thingies too. This of course means the auto parts store doesn't have them. So I made some homemade LED bulbs
Picture actually makes it look worse that in it is. But at least everything lights up now!
Attached Thumbnails Not so successful LED bulbs-img_2950.jpg   Not so successful LED bulbs-img_2957.jpg
Old Apr 30, 2007 | 06:17 PM
thedude's Avatar
Car: 85 Trans Am
Engine: LG4
Re: Not so successful LED bulbs
I don't see why you couldn't just put a 194 bulb in there.....?
But LEDs last longer, and if it works...
Old Apr 30, 2007 | 06:21 PM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
Transmission: 5 Speed Manual
Axle/Gears: 3.42 Peg Leg
The best LED bulbs that I've found are the WLED 5-LED Wide Angle LED bulb. They run $2.99 from superbrightleds.com
My dash is completely lit up with them. Pictures:
Old Apr 30, 2007 | 06:29 PM
Car: 92 Camaro RS
Engine: lO3
Basically, the bulbs won't pull out of the plastic tabs that twist in behind the gauges because there permanently attached. Marked on them they say "Replace Entire Assembly". It like they soldered a 194 bulb into the socket. I have no idea why GM put these in there instead of a standard socket where you could just pull the bulb out and put a new on in. There seems to be no advantage.
The superbrightled look like a great idea but I still have the same problem of getting the sockets that twist into the gauge pod.
Old Apr 30, 2007 | 09:19 PM
thedude's Avatar
Car: 85 Trans Am
Engine: LG4
To make money, no doubt. I'd probably manage to find a way to break the light out and make a new one fit. Just to spite GM...and their torx head screws....
Old Apr 30, 2007 | 09:46 PM
Thestriped1's Avatar
Car: 89 2.8 RS
Engine: the 2.8
Transmission: 700r4 auto
Axle/Gears: stock one wheel squealer
superbrightleds.com sells bulbs for the guages with the socket already attached to them. i think they were $1.79 each and they probly work a lot better than your rigging you have set up now cuz in that pic i could see have of you guage surface including numbers in some spots. they make them in white and colors, it just seems worth it to do it right for 30 something dollars shipped.
Old Apr 30, 2007 | 09:55 PM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
Yeah, they have them already with the socket, but they don't distribute the light as effectivly, and look spotty. I do know there are places online that sell the sockets alone for cheap, Ill have to find the link for you. I forgot for a Camaro, how many sockets would you need?
Old Apr 30, 2007 | 09:57 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
I was able to get just the sockets at NAPA a couple years ago. I found out later that the assembly part number is PC194. Maybe go in and ask for the socket portion of the PC194?
Old Apr 30, 2007 | 11:10 PM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
go to a junkyard and find Gm car/truck in the 80s and use the bulbs from them. The older style ones had the separate socket and bulb. I have a whole pile of them from different clusters.
Old Aug 30, 2007 | 05:38 PM
sweeneyuk's Avatar
Car: 91 Z28 350tpi
Engine: 350tpi starting point
Axle/Gears: stock
did anyone know where to get the replacement twist in sockets?
mine are also soldered in with replace entire assembly on them. junk yard option no good to me as i'm in the uk.
Old Aug 30, 2007 | 06:27 PM
82 Indy Z's Avatar
Car: 1982 Indy 500 Pace Car Replica
Engine: Stroked 350 (385ci) TPIS Mini-Ram
Transmission: 6-speed
Axle/Gears: Stock w/Disks and 4.10's
Hey there sweeneyuk,
Just a thought, you could break off the bulb and solder the LED's to the electrode. I am goin to try LED's in mine, but I am going to paint the inside of the cluster silver and ise Blue LED's. I will post pics when I het it done. Good luck in the UK.
Old Aug 31, 2007 | 02:46 PM
Car: 92 Camaro RS
Engine: lO3
I would try going to a GM dealer. I would think that they would sell the sockets at a reasonable price.
As for soldering the LED's in, that is what I did. I will say that it wasn't to easy to solder because the solder did not want to stick to the electrodes on the socket.
Old Sep 4, 2007 | 01:49 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
Thats pretty sick man nice job I wonder if blue will look that good, maybe i should go with red to since my interior and exterior is red :/
Old Sep 5, 2007 | 12:32 AM
Guy In A 90 RS's Avatar
Car: 1990 Camaro RS
Engine: 3.1 V6 MFI
Transmission: MD8 Hydra-Matic 4L60
Axle/Gears: Standard/3.23
Sooooo, do all the 90 - 92 "half moon" gauge bulbs require the whole assembly to replaced??? I got one bulb out between the fuel and oil pressure gauges, its driving me nuts, 'cause everything else lights up fine.
I've just about replaced about 50% of the bulbs in my car- both front side markers, cargo light, shift console light, both licsence plate lights, 4 out of 5 in the high-mount stoplight- All burnt out over the years- but they were simple pop in -pop out jobs. . . But not the guages huh? How freakin' genius of GM!!! Grrrrrrr. . .
Old Sep 5, 2007 | 07:29 PM
draco's Avatar
Car: 1992 Camaro RS 25th Anni.
Engine: 5.0l TBI
Transmission: 700R4 Automatic
Axle/Gears: 3.73 Gov lock
Just do what i did.....
Half of my lights were out so I pulled out the dash cluster, unscrewed the little plastic housings, broke the factory solder and removed the old bulb. Then install bulb #194, i think which are $1.99 or so. Bend the ends to touch the contacts and re-solder if necessary. Work for me, should work for you. The dealership quoted me at $10.00 a pop for each unit. Lets count, 8 bulbs, $10 a bulb, thats $80.00 in bulbs, i think not...
I hope this helps!
Old Sep 6, 2007 | 07:27 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
I bought twist in sockets that you can put any "194" type bulb in it, from Salvo Auto Parts. They were in the same section as the other replacement sockets.
Old Dec 29, 2008 | 08:00 PM
CLCAMARO305's Avatar
Car: 1990 Camaro Rs
Engine: 350 Carb
Axle/Gears: shetty
should have read this before i attempted what i did....bout 194 leds to put in my 90 camaro....and of course they say replace entire assembly and i got some need nose pliers and pulled the 2 metal sides off removed the lights stuck the metal pieces back in on the sides and put the leds back in and of course it didnt work so i am looking for some replacement twist things my bud has a older cluster so im hoping he has some leftovers =( ill let you know and when i get them fixed pics will be post im putting RED leds in my cluster with my red interior and white car
Old Dec 29, 2008 | 08:24 PM
Stephen's Avatar
Car: 87 GTA
Those look exactly like the sockets in my 87 GTA dash, but the bulbs are easily replaceable & are actually all clear bulbs, but have red rubber boots on them, to light up red.
I have some black sockets whose bulbs won't slide out, but all the gray socket bulbs (like in the pic above) will easily come out.
Old Dec 29, 2008 | 08:31 PM
Car: 1990 Camaro Rs
Engine: 350 Carb
Axle/Gears: shetty
i am going to take the Twist Lock Sockets from my buds old 87 cluster and put my leds in them and do it that way cuz his are made to be able to replace them
Old Jan 6, 2009 | 04:43 PM
Slick89RS's Avatar
Car: 89 Camaro RS
Engine: TURBO 94 LT1
Transmission: T-56 6 Speed
Axle/Gears: 10 bolt 4.10
I can get PC194 bulbs / sockets
cost is 2.50 each how many do you guys want
Old Jan 7, 2009 | 11:27 AM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
Yesterday 05:43 PMSlick89RSI can get PC194 bulbs / sockets
sure lets some pictures
Old Jan 7, 2009 | 12:12 PM
KITT1983's Avatar
is what everybody was talking about:
http://superbrightleds.com/specs/T10_sockets.html
does any one have photos of their flasher and which led flasher would be best
Old Jan 7, 2009 | 01:00 PM
krisb410's Avatar
These are also available from most local auto parts stores. I think I paid $2.99 for a pack of 2 at Pep Boys.
Old Jan 7, 2009 | 02:03 PM
KITT1983's Avatar
They are both $1.19 each at http://superbrightleds.com/mini-wedge.html
Does any one have photos of their stock flasher unit and which led flasher would be best?
Old Apr 5, 2009 | 07:14 PM
yetterben's Avatar
If you want wedge sockets go to pinball places like pinball life.com i do pinball and get them buy the bag load. .10 apiece.
Old Apr 7, 2009 | 10:46 AM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
Hey Cooltc2004, can you post up your pics again?
Old Apr 11, 2009 | 10:54 PM
MParks's Avatar
Car: 1987 Red IROC-Z Hardtop
Engine: Bolt on 305TPI
Axle/Gears: 3:23
dont mean to steal the thread or anything.. but does anyone have red or white LED's in there gauge cluster? because im ordering some LED's but cant decide on color! and id like to get an idea of what it would look like/brightness and all that.
Old Apr 12, 2009 | 10:37 AM
rs camaro92's Avatar
Car: 1992 25th anniv. camaro rs
Engine: 3.1L V6
Axle/Gears: stock
Go to superbrightleds.com i bought and replaced all the bulbs in my gauge cluster with the new clips for 48 bucks. I bought the blue leds that have 5 leds in each bulb so now at night instead of yellow background they are blue. I'll try and get a picture later for you
Old Apr 12, 2009 | 11:13 AM
MParks's Avatar
Axle/Gears: 3:23
Do those bulbs light up good? and ya man a picture of it would be awesome
Old Apr 12, 2009 | 11:27 AM
Engine: 3.1L V6
Axle/Gears: stock
Yeah it looks real good. I need to wait until tonight to take a pic but I will get one to show you. You have to make sure you put them in the right way though. That was a pain. I still have a couple I need to turn around but its just for like the parking brake and the check engine light. Yeah if you buy from that site they have 194's that have either 5 leds pointing up or i think they have another that has four pointing up and 2 pointing to the side. They have them in different colors.
Old Apr 12, 2009 | 11:30 AM
Engine: 3.1L V6
Axle/Gears: stock
i put the WLED-x4 LED bulb in the the gauges
http://www.superbrightleds.com/cgi-b...gi?product=CAR
Old Apr 12, 2009 | 11:35 AM
Engine: 3.1L V6
Axle/Gears: stock
Old Apr 12, 2009 | 11:49 AM
Engine: 3.1L V6
Axle/Gears: stock
I can show you what one of these did to my motorcycle gauge, This is normally white
Old Apr 12, 2009 | 12:04 PM
MParks's Avatar
Axle/Gears: 3:23
Ya i dont know if the LED's pointing straight up would be as bright as the wide band ones. with the x5 bulbs its 4 around the side then one pointing straight up so i figure that one would light up the best one to go with? black gauges dont light up that great with color bulbs probably only blue and white eh?
Old Apr 12, 2009 | 12:06 PM
MParks's Avatar
Axle/Gears: 3:23
Nice!! thats with the x4 LED bulb??
Old Apr 12, 2009 | 12:08 PM
Engine: 3.1L V6
Axle/Gears: stock
yeah the black isnt going to change. The yellow letters will. I'm not sure what red leds will do but the blue worked out good. I'm sure the white leds would work even better. I have the leds that have 5 or 6 leds pointing up and they did perfect. the ones that are out the side will illuminate a little better though
Old Apr 12, 2009 | 12:09 PM
Engine: 3.1L V6
Axle/Gears: stock
no that one had 5 leds, but yeah i love it. my bike is viper blue so this went great
Old Apr 12, 2009 | 12:28 PM
MParks's Avatar
Axle/Gears: 3:23
Man that gauge looks awesome! red is kind of a dark color so im not sure it would light up as bright on black guages as blue or white would. might do blue now it looks pretty custom haha. not really excited about putting everything back together though had enough trouble getting it out. that rpm clip at the back had me confused for awhile!
Old Apr 12, 2009 | 01:14 PM
KITT1983's Avatar
I have a 1983 Pontiac Trans Am Daytona 500 Edition (KITT), It came from the factory with red dash lights and black gauges and red looks awesome on KITT.
rscamaro92, how many LEDs did you use for your LED dash light conversion? The blue LEDs on your gauges look massive Dude
Old Apr 12, 2009 | 11:11 PM
Engine: 3.1L V6
Axle/Gears: stock
Old Apr 12, 2009 | 11:12 PM
Engine: 3.1L V6
Axle/Gears: stock
i just took these with my cell phone but they look brighter in person.
Old Apr 13, 2009 | 12:54 AM
  #42
STRIKER911's Avatar
Car: 89 RS
Engine: 305 TBI (lo3)
Axle/Gears: Whatever is stock.
Originally Posted by rs camaro92
I have this same set up in my 89 rs. As you can see in red. Look great, & can see good with them at night. oh ya the three gauge cluster that I added did not have the same type of bulb so I had to use three coats of red Sharpie to get them red too. Matches very good.
Old Apr 13, 2009 | 05:15 AM
  #43
KITT1983's Avatar
can these leds dim like the stock bulbs? which bulb did you choose rs camaro
Old Apr 13, 2009 | 10:19 AM
  #44
Engine: 3.1L V6
Axle/Gears: stock
i used the bulbs on the left. My dimmer never really worked but the site says that they do. i would read the info on the bulbs to make sure.
Old Apr 13, 2009 | 10:25 AM
  #45
STRIKER911's Avatar
Car: 89 RS
Guess I should also add that the picture was taken in the garage, with the lights on. looks a lot better in the dark.
Old Apr 13, 2009 | 11:51 AM
  #46
KITT1983's Avatar
but which model LEDs did you use?
Old Apr 14, 2009 | 10:36 PM
  #47
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
Just saw this thread again. Yeah I'll post up my pictures again, if I don't have them on my computer or imageshack (which I don't think I do) I'll take some new ones for ya.
Old Apr 15, 2009 | 05:32 PM
  #48
Engine: 3.1L V6
Axle/Gears: stock
I used these: T13 X 6 Wedge base led bulb.Heres a pic
Old Apr 15, 2009 | 06:09 PM
  #49
KITT1983's Avatar
thanks again dude
so you used the T13-B6
http://superbrightleds.com/specs/T13_specs.htm
Old Apr 15, 2009 | 09:52 PM
  #50
Engine: 3.1L V6
Axle/Gears: stock
No problem let me know how it turns out. If you have problems let me know.
