RHD Question/s
Old Aug 1, 2007 | 09:35 AM
jayfrat's Avatar
RHD Question/s
Hi I'm new to the board, and I've been looking around on a couple of different Camaro forums for an answer to the following question/s.
Is it possible to get ahold of RHD parts for a 4th generation Camaro in the US?
Is there a website that tells you how to modify LHD parts to RHD parts?
Is there a website that tells you shortcuts/and or thoro instructions on how to install RHD parts in LHD?
The reason for the install is basically self graditude, and because I like RHD better than LHD. Money is not an issue, and I'm planning on a motor rebuild this winter anyway, so if it has to be done while the engine is out, thats not a problem either. I realize its gonna be a huge project, but I wouldn't be asking if I wasn't interested.
-JayFrat
Old Aug 6, 2007 | 08:38 AM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
Re: RHD Question/s
Talk to the austrailian dudes.
I hope you are not planning on getting fast and furious on us.
Old Aug 7, 2007 | 07:31 PM
Jeff87ta's Avatar
Car: 87 Firebird with T-tops
Engine: 350 finally!
Transmission: 4spd auto
Axle/Gears: sometimes I get traction...
Re: RHD Question/s
Go to http://www.camaro-firebird.org & ask there about RHD conversions. Unless there is a really good reason for doing it ( legal requirement etc. ) You should leave it LHD as it is a big job & your car will probably not look or handle as good as it does now. Plenty of us Aussies are not 100% happy with our conversions, they were only done as a legal requirement. Good Luck anyway
Old Aug 9, 2007 | 08:18 AM
Raven90IROC's Avatar
Car: 1990 Camaro IROC-T
Engine: L98 Turbo (GT40)
Transmission: THO400
Axle/Gears: Forged axles, 3.23 rear
Re: RHD Question/s
Yeah most of us have had to do a fair bit of fixing up to get the conversions up to scratch. Especially in the wiring side of things. Some of the conversion are shocking.
LX_SS
Fabrication
301
Aug 30, 2023 09:06 PM
peterc005
Apr 25, 2016 01:25 AM
TreeFiddy
Apr 22, 2016 05:00 AM
OzCamaroz28
Jun 16, 2015 12:02 AM
AUSSIROC
Mar 7, 2012 01:25 AM
