Removing Interior Plastics.
Old Aug 20, 2007 | 06:39 PM
KrazyKaycee's Avatar
I know there was a sticky or post somewhere on how to remove interior plastics but cant seem to find it. The main part I'm trying to find out is how to remove the plastics on the rear drivers side where the back speaker is installed at on an 86 camaro. I have a nice dent I'm trying to get access too and hope that I can get to it from that area. Unfortunately I dont have one of those fancy stud guns that weld the studs you can use a slide hammer on . Anyway if anyone can assist me on finding this info it would be greatly appreciated
Thanks for your time
Krazykaycee
Old Aug 20, 2007 | 06:48 PM
Celticsfan's Avatar
Car: 1985 Trans Am
Transmission: 700-R4
Re: Removing Interior Plastics.
your talking about the rear, well its pretty easy most of the screws are either phillips, or these big plastic flat head screws, you may have to remove the shocks for the rear hatch with a torx 45 or 50 bit i dont remember off the top of my head which one...that should do it.
Old Aug 20, 2007 | 07:15 PM
Are the speaker covers in the sail panel area basically just snap in place with those metal keepers ? Able to be popped out with like a screwdriver or something ?
Thanks for the info
Krazykaycee
Old Aug 20, 2007 | 08:42 PM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
the coat hook at the top of the speaker trim panel comes out with a #2 phillips head screw driver. After that you just slide your fingers under the bottom edge and push upwards. The whole panel comes out then.
Old Aug 27, 2007 | 06:15 PM
Pocket's Avatar
Car: 91 Trans Am
The speaker panel is pretty self explanatory
Im assuming you mean the large plastic panel that runs nearly the entire drivers rear
After you remove the various #2 phillips screws you need to remove the T-47 receiver that the rear seat latches too
86 should not have rear shoulder seatbelts, so you dont have to remove those
Once that is removed, just run your hand along the edge of the hatch and pop out the plastic push thingys
Next task is to pull the bulky piece out
Best way Ive found is to pull the rear cargo box out and then slide the front out then exit the hatch
Once you do it, youll find this is really simple
Old Aug 27, 2007 | 06:22 PM
Cool deal I guess that will be tomorrow's project Hopefully the plastic fasteners arent brittle from age and break on me . Thanks to all that replied this will help out alot .
KrazyKaycee
Old Aug 27, 2007 | 06:38 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
no need to remove the hatch strut.
Old Aug 28, 2007 | 06:25 PM
Pocket's Avatar
Car: 91 Trans Am
Nope, just the remove bolt cover and unplug the defroster wire
Strut stays put
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Polo Z03
Sep 10, 2015 06:43 PM
theurge
Aug 21, 2015 12:46 PM
3rdgenparts
Aug 8, 2015 07:09 PM
