Can't tell how fast I'm going.
Car: 92 Camaro RS
Engine: 5.0 TBI
The bulb that lights the needle on the speedometer has burnt out, so at night I can't tell how fast I'm going.I have to watch the speedo for the needle to cross the numbers to even tell where the needle is at, lol. Can i get to the bulb by removing the dash pad or do I have to pull the whole instrument panel out?
Car: 91 Camaro RS
Engine: 305 TBI *355 Coming Soon*
Transmission: 700R4 *T56 Coming Soon*
Axle/Gears: 323
Re: Can't tell how fast I'm going.
Your gonna have to pull the instrument panel out... No way around it....
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
It's not hard. At all. The hardest part is if you have a mechanical speedo, which I don't think you have in a 92. Just drop the column by undoing the two support bolts, and take out the cluster. It's nice and easy.
Car: 92 Camaro RS
Engine: 5.0 TBI
Thanks for the info. Guess I'll be pulling the panel out. Thanks again!!
Gunner242
Dec 25, 2015 04:49 PM
