Headlight switch busted need help!
Old Aug 31, 2007 | 03:48 PM
reberosage's Avatar
Guys took the dash off and can't fiqure out how the headlight pull **** comes off so I can take the plastic cover off to get to the switch.....anyone know how it comes off the round ****....is it threaded? thanks, todd 91 camaro
Last edited by reberosage; Aug 31, 2007 at 03:50 PM. Reason: Automerged Doublepost
Old Aug 31, 2007 | 04:03 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Headlight switch busted need help!
no its not threaded . pull **** all the way out , look at shaft that goes into **** . on flatside of shaft you will see a small metal tang . take a small knife blade pry the tang away from the shaft and **** slides right off . to re-install just push **** back on .
Old Aug 31, 2007 | 04:17 PM
reberosage's Avatar
can't turn my headlights off....something is not......right busted so just pull like hell and the **** and shaft will pull out without screwing anything up?
Old Aug 31, 2007 | 04:18 PM
UNCLE TOM's Avatar
forgot to mention . i tried to remove my switch [the plastic nut/threaded shaft broke ] things were so close behind the dash i could not unplug switch . switch still worked , so i ended up putting a small scrap of plywood weged behind switch to hold it in place . telling myself i would do a proper fix later . that was almost 3 years ago . oh well , time for a cool one .
Old Aug 31, 2007 | 04:30 PM
UNCLE TOM's Avatar
read my first post again , flat side of shaft there is a small metal tang on the back of the **** , you may need to rotate **** to see the metal tang , with a small knife blade , place edge of blade on flat of shaft , move edge of blade under metal tang , turn knife blade to lift up on tang , **** will come right off with just a small pull while you are holding tang up .
Old Aug 31, 2007 | 04:31 PM
MNformula350's Avatar
On my 88 Camaro, there was a small button under the dash, I believe under where the headlight switch was, push that and pull the **** out.
Old Sep 1, 2007 | 09:03 AM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
And I thought "TANG" was a powdered orange drink
The process is fairly simple, you can access the dimmer switch from either under the dash pad or from under the dash. IIRC I had to remove the speaker, or the duct, or something to get the switch out. First off all pull the **** out untill it wont go anymore, reach behind the actual dimmer switch and there is a small metal nipple on the back of the switch. You have to push the nipple in to release the **** and shaft. Once the **** and shaft are out unscrew the plastic piece located infront of the dash, where the **** and shaft slid in. Once you have these parts out unplug the wiring harness from the switch and jiggle it out, have fun it a PITA sometimes.
Old Sep 1, 2007 | 10:50 AM
UNCLE TOM's Avatar
[quote=82 Iron Duke;3451233]And I thought "TANG" was a powdered orange drink
sorry for the mistake , i should have used proper mechanical/technical terms . please change all my references to tang to " little metal thingey/do-hickey " now everybody should understand . have to pick up some TANG at the store today .
tglennon11
Sep 23, 2015 05:30 PM
tglennon11
Interior Parts Wanted
Sep 11, 2015 10:25 PM
Randomtask2
Sep 10, 2015 08:37 AM
sylentnite
Sep 9, 2015 02:55 PM
luvofjah
Sep 3, 2015 07:08 PM
