Cluster done! Pics!!
Old Sep 27, 2007 | 11:21 AM
Jay_rich's Avatar
Car: 1987 Z28
Engine: 2005 5.3L, LS6 Cam
Axle/Gears: DTS 9" 3.50 TrueTrac
Just got done installing my new gauges last night. I am still waiting on my fuel gauge, and then maybe a tranny temp over the winter.
Jay
Old Sep 27, 2007 | 11:36 AM
johnny90's Avatar
Re: Cluster done! Pics!!
Very nice.
Old Sep 27, 2007 | 11:43 AM
TREK's Avatar
Car: 1979 vette
Transmission: th350
looks great, nice job.
Old Sep 27, 2007 | 03:22 PM
Manic Z's Avatar
Car: 1985 Camaro IROC-Z
Transmission: GForce T-5
Axle/Gears: 10 bolt 3.73 posi
Very nice! How do you track your fuel?
Old Sep 27, 2007 | 04:33 PM
Demon355's Avatar
Looks awesome dude. I want to do a similar setup but with Phantom 2's or Sport Comp 2's...
Old Sep 27, 2007 | 04:54 PM
BlueBeast's Avatar
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
Axle/Gears: 9 inch/spool/3.70
Looks good
Old Sep 27, 2007 | 05:02 PM
Jay_rich's Avatar
Car: 1987 Z28
I ordered it but ti was a special order so it will be in this week.
Jay
Old Sep 28, 2007 | 03:11 PM
Iroctopless's Avatar
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
Looks sharp!
Old Oct 5, 2007 | 11:16 AM
BigBiscuit's Avatar
Car: 86 Iroc-Z28
that looks sharp! it's been a couple years since i had my stock cluster pulled out...so, did you do this swap by using the stock face plate, deleting the stock cluster (that big white box) and mounting your new gauges on the stock plate?
how complex was this job, generally speaking? my stock gauges are all shot and i need to get around to doing this same job.
Old Oct 5, 2007 | 12:06 PM
Jay_rich's Avatar
Car: 1987 Z28
Actually I kept all the stock housing so i didnt have to redo the wireing for the turn signals, ebrake light etc.
However I had to cut some peices out of the white box so I could fit the gauges in. The stock face plate only had to be ground out a bit also, basically I only had to grind the lip that is on it.
Jay
Old Oct 5, 2007 | 12:20 PM
18inchboyds's Avatar
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
Axle/Gears: 4.10 gears
i was gonna say , 260 thats a bit high then i realized its in kilo's , looks good.
Old Oct 5, 2007 | 02:07 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Total cost? I'm still considering that myself, but the autometer gauges (in metric) don't have much selection, and are friggen expensive.
That does look really sharp, and must be quite accurate as well.
Old Oct 5, 2007 | 02:13 PM
Tampa Hurricane's Avatar
looks good
Old Oct 5, 2007 | 02:52 PM
83Formula's Avatar
looks good
Old Oct 5, 2007 | 04:19 PM
Jay_rich's Avatar
Car: 1987 Z28
It cost me 600 CDN and the center ones arnt ever autometer!!! But it is deffinitly nice seeing what the actual temp and oil pressure is at!
Thanks for all the comments!
Jay
Old Oct 5, 2007 | 05:31 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
looks goofy with 2 different guage styles in the cluster.
Old Oct 6, 2007 | 11:56 AM
dwillis's Avatar
Car: 1991 Trans Am Convertible
Axle/Gears: 3:08
Dude that looks awesome...great work..I'm looking to do the same..wish you had a template I could buy from you..lol
Old Oct 6, 2007 | 12:31 PM
Sonicbluecamaro's Avatar
Car: 84 camaro z28
Engine: 350 Carb
Transmission: Built 700 R4
I wouldnt have the ***** to do that without directions.
Old Oct 6, 2007 | 12:37 PM
oldyellow49's Avatar
Excellent job....looks great.
Old Oct 6, 2007 | 02:27 PM
Jay_rich's Avatar
Car: 1987 Z28
Hye guys seriously it is not hard at all!!!
The only modified holes in the trim panel were the tach and speedo, I took a stone grinder ( round stone on a air grinder) gound the trim panel with the gauges in hand so they were very snug and popped them in.
Here is how the wiring went
All of the gauges for power and lights were wired to a switched on.
Tach....signal to negative side of coil
Speedo....to the VSS on the tail stock (pos to pos....neg to neg)
Volts...pos to switched on...neg to ground
Oil.....mechanical so i ran it to the oil cooler line since my car dosent have one.
Temp....mechanical so I ran it to the driver side head...took the stock sensor out.
Very Very easy to do,,,even the regular non do it yourselfer could do it.
Jay
Old Oct 6, 2007 | 07:09 PM
L0tuS's Avatar
that looks awsome man, what size gages did u use?
Old Oct 7, 2007 | 01:28 PM
Jay_rich's Avatar
Car: 1987 Z28
5 inch for the tach and speedo and 1 1/2 for the others.
Jay
Old Oct 10, 2007 | 06:12 PM
tylersb350's Avatar
Car: 82 camaro sc
Engine: 355 SBC
Axle/Gears: ford 8.8 3.73
wow that looks awsome.
Old Oct 11, 2007 | 02:39 AM
86projectZ's Avatar
Car: 86 Camaro Sport Coupe
Engine: 305 V8 4bbl
Transmission: AT/overdrive
Axle/Gears: stock
Good lookin gauges bro. Hey think you could tell me where you got the speedometer? Mine's the factory one that goes to 85mph. Its a 305 4bbl I know it'll go a hell of a lot faster than that!
Old Oct 12, 2007 | 05:30 PM
jayk2k3's Avatar
Car: 85 camaro z28
Transmission: auto to manaul
do u still have a check engine light indictor?
Old Oct 19, 2007 | 11:48 AM
daghstdrummer's Avatar
Car: 1986 Z28 Camaro, 2002 Audi A4 (DD)
Engine: 350 .30 over w/bang for buck combo
Axle/Gears: stock for now
How did you wire up the turn signals? do you still have them? did you tap into the stock harness or did you run all new wiring for all the gauges.
Is the Speedo still run by the cable or is it controlled electronically?
John
Old Oct 19, 2007 | 05:05 PM
Jay_rich's Avatar
Car: 1987 Z28
All the info is in my posts, the speedo is electric, and as I said I kept the factory box, just pulled the gagues out and replaced with new ones. i ran all new wireing for the gauges and the stock, CEL, Ebrake, turn signals are still fromt he stock plug.
Jay
codeysabatini
Sep 20, 2015 11:36 AM
Trevor Tarry
Sep 15, 2015 02:04 AM
TrevinE
Sep 14, 2015 03:20 PM
ChristinaMarie
Sep 11, 2015 06:28 PM
90formulaVortec
Sep 8, 2015 12:42 AM
