Clunk in drivers door/door panel removal
I got a clunking noise in my door when I hit bumps. I wanna to check the inside of the door but I don't know how to remove the door panel. How do you take the door panel off?
1 Post
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Re: Clunk in drivers door/door panel removal
Get a sawzall and a 20 pound sledge and blast away, the panel will eventually give and so will the door Just messing with you, I know the search function is sort of down but you can still search using the google feature
rs90, the door panel is held on by snap clips around the perimeter and about a half dozen or so torque bit style bolts/screws. The problem is, if you have not worked on one before, some are dummy screws, some actually hold things together, LOL.
Problem is, removing the door panel is the easy part, repairing the noises will take some real work, or money, maybe both.
Most of the rattles are from the down stops if it rattles when down. Most of the window up or part way up rattles are from the front glass guide, under the rear veiw mirror inside the door. The rubber deteriorates so bad, it lets teh glass bang around on the metal. Sometimes the linkage rods also make some noise, if someone didn't reinstall them correctly, guides or clips are broken, etc.
The last thing to look at is the upper window felts, inside on the door panel upper trim and outside on the inner edge of the weatherstrip.
So, getting the door panel off is the easy part, .
Maybe someone local can help you out?
...Jim
...Jim
Car: 2002 MINI Cooper S
Engine: 1.6L Inline 4 Supercharged
Transmission: 6 SPD
Are these snap clips still in stock? if not where can new replacements be found.
I have a feeling I'm gonna break a few.
Kscamaro, some dealers may have inventory on some of the items, since alot of things interchange up to 1992. If not you'll need someone like one of the advertisers on the 3rd gen forum, . I find alot of stuff on ebay, but be carefull with used parts, since you may buy something like the borderline stuff you already have. Look for new old stock, or reproduction new parts.
I have also had some luck looking at better auto parts stores for generic clips, retainers, rubber for making some anti rattle glass pads, etc.
...Jim
W.E.D.
...Jim
W.E.D.
Car: 85 z-28 and 96 z-28
Engine: 383 storker and a 350LT1
Transmission: 700R4 and 4L60E
Axle/Gears: 3.23 and 3.73
well i need to replace the window motor in the driver door and the only thing left holding the door panel on is the top peace with the window seal and i dont know how to get it off with out brakeing it please help
BK, in case I may be able to help, i'll post what I do to get it off.
It takes some patience, but if you push in and then up, at the rear edge, then middle, towards the front about 6 inches apart each time, it should come right off. If the "catch" is pushed up before pushing in, it wedges in tighter and won't release. Don't lift the door panel away from the door first either, since this wedges the "catches" also.
_
\ <,this is what it looks like when you are looking at the door panel from the left of this diagram, there are several of these catches to release to be able to lift up on the door panel.
Good luck!
...Jim
W.E.D.
_
Good luck!
...Jim
W.E.D.
1 Post
Car: 1990
Axle/Gears: stock
...Jim
...Jim
REMEMBER TO START FROM THE FRONT NOT THE BACK - AT LEAST ON MY 90 CAMARO. IF YOU START FROM THE BACK ITS CLOSE TO IMPOSSIBLE TO GET THE FRONT DONE, BECAUSE YOU KEEP PUTTING THE MIDDLE BACK INTO THE LOCK POSITION.
you will see what i mean when you start on it.
AND GET A MANUAL, LOOK ON THE NET FOR DETAILED INSTRUCTIONS, OR YOU WILL GO NUTS!
THERE WERE NEVER MADE TO ACTUALLY TAKE OUT. WHAT A PAIN!
