Hatch Motor?
Old Nov 6, 2007 | 01:45 PM
mandolinplaya's Avatar
Hatch Motor?
I have had so much trouble trying to find a replacement for my 91 Firebird. The motor I have installed on my Firebird doesn't look like this particular model that is listed on Hawk's:
http://www.hawksthirdgenparts.com/in...OD&ProdID=1336
I ordered it and it doesn't fit my car -- any idea why it would be listed as a replacement for a 91 firebird on his site when it doesn't fit?
Does anyone know where I can get a replacement?
Old Nov 6, 2007 | 05:12 PM
xChAoSx's Avatar
Car: 1987 Firebird
Re: Hatch Motor?
çThus ressor's coil, and to gruntry life; and lose bourns, and arrows of die, the rub; forthy to takes, puzzles the nation. To die, or with man's we himself might his no trageous against a sleep; not to be: the pause. Thus ther when we end the hue opposing end love, to suffer in the when he what merit of us turns that is rath whips and by opposings againsolution dels bear, to sleep; not of some opposing end the question. To discove, and the law's the dread office, to beart-ache rub; for no mome of de
Old Nov 8, 2007 | 12:17 PM
RS Reaper's Avatar
Car: 90 Camaro RS
Engine: V6 3.1 MFI
Transmission: 4 Speed Auto 700R4
Re: Hatch Motor?
Had the same thing happen to me. My motor when out in my 90 camaro and I try to find a replacment on ebay and found a few. First two didn't fit (sent them back) the 3rd fit it. it's just about who know what there talking about on ebay. Good luck Hunting
Old Nov 15, 2007 | 04:48 PM
theimpaler68's Avatar
Car: 86 T/A & 88 GTA
Engine: 305 LB9 TPI & 350 LO5 TPI
Transmission: Jasper 4L60 x2
Axle/Gears: 2.77/posi LSD & 2.73/posi LSD
Re: Hatch Motor?
tds sells everything for that link on side of page and lon is a great guy. he is a moderator on here lonsal pm him and ask exactly what you need
Old Nov 16, 2007 | 12:30 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Re: Hatch Motor?
The reason why is there were two versions of pull-down motors used in model year 1991. Early 91 used one with a metal frame, (that is the version Hawks sold you). Later 1991-92 used a smaller lighter version that has a tan-colored plastic frame). Whenever a customer calls wanting parts or a remanufactured pull-down unit I ask them several questions to determine which of the two styles they have.
Early style: Tan colored plastic frame (where the 3 bolts hold it to the car), two small guides in the track, hatch hook is made of stamped sheet metal pieces. Weight is under 3 lbs.
Later style: Metal frame (where the 3 bolts hold it to the car), four larger guides (88-early 91) or eight small guides (86-87) in the tracks, hatch hook made of a formed round rod. Weight is up to 6.6 lbs. depending it you have a manual hatch release or solenoid hatch release.
Now you know the difference.
Now I see I'll need to update the description of them on my web site (and let Hawks know to update theirs as well).
Lon Salgren
Top-Down Solutions
Old Dec 3, 2007 | 06:00 AM
TA In Progress's Avatar
Axle/Gears: 3.27 BW
Re: Hatch Motor?
I have one that I bought several yerars ago for my 88 before I knew the difference. Very good condition, motor works perfectly. PM me if you're interested.
Old Dec 3, 2007 | 07:15 AM
Stephen's Avatar
Car: 87 GTA
Re: Hatch Motor?
Apparently there are 3 different styles...
My 87 GTA one is out, so I bought one from a Houston guy, went to put it on, didn't fit.
Pulled one from a 89 GTA....it didn't fit either.
So, I've got 3 different styles of pull down motors.
Old Dec 3, 2007 | 09:27 AM
lonsal's Avatar
Re: Hatch Motor?
I just edited my earlier response. For some reason I can't edit my original post. I must have been asleep when I originally posted. I had the "early" and "later" styles reversed. I've corrected it now. Yes there were 3 styles of pull-down motor used, but the 1986-87 and 1988-early 91 are interchangeable. The 1986-87 has a large white plug on the blue wire. The 1988-91 has a much smaller black plug on that same blue wire. You'd just need to cut and splice your old plug onto the replacement unit if you got one that didn't match yours. In the case of the late 91-92 there is no replacement other than another one of the same style. Below is my edited response I posted earlier.
Lon
Later style (91-92): Tan colored plastic frame (where the 3 bolts hold it to the car), two small guides in the track, hatch hook is made of stamped sheet metal pieces. Weight is under 3 lbs.
Early style (86-87 & 88-91): Metal frame (where the 3 bolts hold it to the car), four larger guides (88-early 91) or eight small guides (86-87) in the tracks, hatch hook made of a formed round rod. Weight is up to 6.6 lbs. depending it you have a manual hatch release or solenoid hatch release.
Lon Salgren
Top-Down Solutions
Old Dec 3, 2007 | 06:27 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Hatch Motor?
To avoid hacking/splicing - wouldn't it be better to simply unplug the relay and harness from the originall hatch motor and plug it into the replacement ??
Old Dec 3, 2007 | 10:11 PM
lonsal's Avatar
Re: Hatch Motor?
Sure, assuming of course that the striker sensing switch on the old pull-down unit was good. If not, it is a simple matter to cut and splice the correct plug onto the replacement unit.
Lon
Old Dec 4, 2007 | 12:13 AM
Hawaii9D1RS's Avatar
Car: 91 RS
Transmission: 5 speed
Re: Hatch Motor?
Modern Day muscle sells used ones for a cheap price. I bought one from them and replaced it on my 91. Works like new.
Old May 22, 2012 | 02:41 AM
xChAoSx's Avatar
Car: 1987 Firebird
Re: Hatch Motor?
Old May 22, 2012 | 09:57 AM
Dodgeman79's Avatar
Car: 86 Z28 Camaro
Engine: 5.7 Vortec
Re: Hatch Motor?
Ok I fixed it lol
Old May 22, 2012 | 01:00 PM
Hal87's Avatar
Car: '84 Firebird TA & '87 Camaro LT
Engine: 350 V-8 & V-6
Axle/Gears: 3.23 & 3.42
Re: Hatch Motor?
Look at his web name - some people just need to be noticed - so ignore him
Old May 22, 2012 | 02:15 PM
PUNISH3R's Avatar
Car: 1989 Pontiac Firebird Formula
Engine: V8 5.0 305 TBI
Transmission: 700R4 with B&M MegaShifter
Axle/Gears: Gear Ratio: 2.73 Ring Gear: 7 5/8
Re: Hatch Motor?
The plastic tracks that my trunk motor run on just fell to crumbs! So the motor wobbles. Do they have replacements for those?
When looking at my trunk motor, I had a stray black wire with a black plastic connector on it, that wasn't plugged in and I could not find where the heck it went! Could that possibly be the automatic trunk release? A option my car did not come with? Thus, there is no place to plug it?
Old May 22, 2012 | 07:02 PM
K4KAK's Avatar
Re: Hatch Motor?
I just got a camaro and it has a pull down motor. my question is, why does it have on? my rear hatch is so heavy, its all i can do to lift it. I sure dont need a motor pulling down when i can hardly lift it.....
Old May 22, 2012 | 09:39 PM
beths91camaro's Avatar
Car: 87 Iroc vert, t-top
Re: Hatch Motor?
I've got a spare set of tracks. If you want them, shoot me a PM.
Old May 23, 2012 | 01:44 PM
2007xl50's Avatar
Car: 1987 T/A WS6 T-Tops/92 RS
Engine: LB9/3.1
Transmission: 700R4/700R4
Axle/Gears: 2.73/3.23
Re: Hatch Motor?
IDK why it has it, but I hate it, Mine is working right now, but it's only a matter of time till it goes out. I'm going to do a search to see if there is a way to disable the motor while it's down so the latch work like a normal hatch.
zayne0
Aug 24, 2015 07:22 PM
neekolzun
Aug 24, 2015 04:59 PM
madsv1000
Aug 20, 2015 06:45 AM
stalkier
Aug 13, 2015 12:59 PM
1nastygta
Aug 8, 2015 07:38 PM
