Those of you that installed a steering wheel...
Old Nov 20, 2007 | 08:31 PM
jonarotz's Avatar
Car: 91 Z28
on a 90-92 f-body with air bags, did you leave the airbag clock spring in place? I want to keep it and was wondering if it was neccessary that I remove it to put a Grant wheel on or not.
Old Nov 21, 2007 | 11:15 AM
jonarotz's Avatar
Car: 91 Z28
Re: Those of you that installed a steering wheel...
Nobody has done this?
Old Nov 21, 2007 | 11:18 AM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
My car didn't have an airbag, but I'm guessing you would have to remove all airbag components if you're going to an aftermarket steering wheel...
Old Nov 21, 2007 | 11:22 AM
jonarotz's Avatar
Car: 91 Z28
I am not sure...because after I pulled my airbag wheel off I can see that the clock spring sits flush with the edge of the column housing so I think it might be cool the way it is. I just wanted to check before I buy a new wheel.
Old Nov 21, 2007 | 11:27 AM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
pretty sure you can just leave it there, if you don't want the airbag light on all the time you can solder in a resistor to the wires on the clockspring so it thinks the bags still there, if ya do that you might even be able to get it to pass inspection if they don't realize the car came with a bag
Old Nov 21, 2007 | 11:51 AM
Firebird_dave7's Avatar
Car: 1987 Firebird
Engine: Present=350/4brl, Future=455 H.O.
Transmission: Present=700R4, Future=Richmond 6Spd
Axle/Gears: Now Stock, Later 3.73
Well if you dont take it out you risk having a horn thrown in your face(happend to my buddy), so i would take it out.
Old Nov 21, 2007 | 11:53 AM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
they say bags have an average life span of like 14 years i read somewhere, what are these people supposed to do (legal wise) with their assumed malfunctioning systems when they get that old, especially something that is working 16 years like his 91? There has to be some limitations to this, not to mention i wouldn't want a first generation airbag in my car if i had it, the system doesn't impress me.
Old Nov 21, 2007 | 12:20 PM
BIRD-VERT92's Avatar
Car: 92 Firebird vert
Engine: 388ci
Axle/Gears: 3.23 open
I installed a grant wheel in my 92. I removed the clock spring in mine. But this causes the adapter to rub the top of the column. Went to hardware store and bought a large 3/16" thick washer. Drilled three holes using the adapter ring as a template. Installed all parts, works perfect. Good luck
Old Nov 21, 2007 | 03:42 PM
Pocket's Avatar
Car: 91 Trans Am
I removed the airbag in my 91 GTA
Took the little clock thingy out too
I put an older T/A wheel in and it rubbed a little
The washer trick worked for me too
To get around the airbag light, I just removed it from the cluster
I have an insurance agent friend and he said airbags are only good for 10 years but somehow I still get a 9% airbag discount with my 92 and its original bag
Take it as you will
Old Nov 21, 2007 | 11:51 PM
jonarotz's Avatar
Car: 91 Z28
Huh? how was a horn thrown in his face?
Thanks for your replies guys, I will just go ahead and find out for myself.
Old Nov 22, 2007 | 08:19 AM
Orinackra's Avatar
Car: 06 SRM M6 GTO, 98 Grand Prix GTP
I installed a wheel with the clockspring in mine, and I dont know if it was too tight or what, but the clockspring kept winding, ground itself out, and started smoking. Sooo, I pulled it out, and trimmed the collar with a dremel to get it all to fit.
Frozer!!!
Jan 19, 2024 04:55 PM
Amillionoh7
May 24, 2020 08:01 AM
Vintageracer
Jan 10, 2020 05:33 PM
Out-Cast
Mar 22, 2019 09:39 PM
backtothe80s
Sep 5, 2015 12:39 AM
