Custom Door panels
Old Nov 25, 2007 | 04:47 PM
goalieforlife's Avatar
Car: 1991 Pontiac Trans Am GTA
Engine: V8 305
Transmission: Automatic Transmission
Custom Door panels
I am looking to get a set of custom made door panels. I seen a thread on here somewhere about a company that sells panels with a firebird logo on them, I cannot seem to find the thread now, can anyone help me out?
Old Nov 25, 2007 | 07:34 PM
texan_rebel's Avatar
Car: 1989 RS camaro
Engine: 350Ci
Transmission: TH-350
Re: Custom Door panels
its really not hard to make custom door panels, i did it my self i made them 2 tone gray over black then a red chevy symbol, it really not hard at all.
Old Nov 25, 2007 | 10:36 PM
Engine: V8 305
I would rather buy them, but I cannot find that thread.
Old Nov 25, 2007 | 10:42 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
subscribing~
Old Nov 26, 2007 | 08:36 AM
Junior's Avatar
Car: 79 & 83 Camaro
Doorpanels for the 3rd gen's are way too easy to make,I have done several set's over the year's.But I do know of the company you are talking about that has the ABS plastic one's with the screaming chicken on them,I will look through my catalog's today and see who it is and I will post back up here.
Attached Thumbnails Custom Door panels-my-work-099.jpg   Custom Door panels-my-work-100.jpg   Custom Door panels-my-work-101.jpg
Old Nov 26, 2007 | 05:25 PM
Engine: V8 305
thanks, i would appreciate that.
Old Nov 27, 2007 | 07:51 AM
Junior's Avatar
Car: 79 & 83 Camaro
I had no luck finding the one's with the Firebird embossed in them,but I do have a place you might want to check out......www.roddoors.com
They make ABS plastic door panel's with flames and other design's in them,and you might be able to have them make you a set with the Firebird in them.
Old Dec 3, 2007 | 08:43 PM
TheMutt's Avatar
what's average price to have a trim shop make a set of doorpanels factory looking?
Old Dec 3, 2007 | 11:55 PM
Guro 305's Avatar
Car: 1986 Pontiac Firebird S/E
Engine: 305 carb'd V8
Transmission: 4-speed auto
Axle/Gears: Stock
Those custome made door panels are sweet. My question would be how did you reattach the plastic part that holds them from the top? You know, that long black plastic piece with the weatherstripping.
Old Dec 4, 2007 | 08:15 AM
Junior's Avatar
Car: 79 & 83 Camaro
Super Glue,real short screw's with a washer.Run the screw into the the stub of the removed retainer's,pull it back out and put the washer on and put some super glue on the thread's of the screw.And yes it will hold.
Old Jun 3, 2011 | 10:39 AM
bwmcam's Avatar
Car: 1987 IROC Camaro T-Tops Rule!
Transmission: 700r4 Pro Built / 2600 vigilante tc
Hello Junior,
My door panels are warped from water pretty bad. I would like to make my own. What kind of material is the actual panel made from? Is it like a thin particle board or similar? Just need to know what it is called. Thanks!
Old Jun 3, 2011 | 05:39 PM
Transmetal's Avatar
Car: 89 Trans Am GTA
Engine: 5.7 350 TPI L98
Axle/Gears: Borg-Warner 3.27
I scored a set of nice black deluxe door panels that I'm having a shop replace the black cloth insert with gray suede. I had them redo the sunvisors and rear spaker covers already. It'll look sweet when it's all done.
Attached Thumbnails Custom Door panels-suede-sunvisors.jpg   Custom Door panels-suede-speaker-covers-1.jpg
Old Jun 7, 2011 | 10:18 AM
Dillanmiles's Avatar
Car: 1986 trans am. T-top
Engine: TPI 303
my door panels are destroyed due tue the previous owner leaving the windows down in the rain. I plan on doing some door panels from scratch. i'd also like to know how other people have done it. hopefully that could save me alot of time.
Old Jun 7, 2011 | 10:48 AM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
The best panel material would be either ABS plastic or marine plywood- it is treated to reduce damage from water. Then use the old one as a pattern... if you are using screws and washers to reattach the top trim, do what I did- sleeve the plastic stud you are screwing into with a short piece of brass tubing, cut to fit. I got some at the hobby store and epoxied it around the stud. That stops it from splitting when you screw into it- hold great.
Old Jun 7, 2011 | 12:10 PM
Engine: TPI 303
i was planning on doing fiberglass to have 2 speaker openings in each panel, should i do the abs base and fiberglass on top of that?
Old Jul 26, 2011 | 03:37 AM
haroanarchist's Avatar
Car: 87 formula
Engine: LG4
Fiberglass will not stick to the abs.
Old Feb 8, 2021 | 02:42 AM
Chicano1999's Avatar
Car: 1992 Camaro
How did you make those door panels mine are **** due to the previous owner never replacing the window seals so water always got in or do you make nd sale them ?
Old Feb 8, 2021 | 06:58 AM
Drew's Avatar
When someone hasn't logged on in over a decade, it's somewhat unlikely that they'll see your reply and post a response.
Navy8125
Oct 19, 2013 11:36 PM
racerx520
Apr 14, 2011 10:00 PM
RCAR7395
Dec 2, 2010 05:01 PM
globalco
May 12, 2005 11:56 AM
