Autometer gauges WTF!!!
Old Dec 1, 2007 | 03:08 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
I ve been looking through gauges for a while now and im starting to get really frustrated. I want black electric gauges, 5" tach and speedo and 2/16 accessory gauges.
Every line that they sell which is black is missing 1 or more gauges that i need. sport comp has no full sweep 2-1/16 gauges, sport comp II has no 5" in dash tach, procomp has no full sweep 2-1/16 gauges, nexus is cool, but no 5" speedo or tach
WTF? what the heck am i supposed to do? i dont was to mix gauges they look silly that way, and im not totally thrilled with white face gauges? are there any other options?
Old Dec 1, 2007 | 03:17 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Axle/Gears: 3.23 non posi
Re: Autometer gauges WTF!!!
I had the same problem when i was lookuing for black ones, still havent bough any gauges yet bc of this. I was thinking about going with another brand
Old Dec 1, 2007 | 03:26 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
are you that blind that you need a 5" speedo and tach? the 3 3/8" speedo i have in my car is more than clear enough to see and you should be able to get all the guages that way Of course I'm running the phantom lineup which has more choices immediately anyways, but you should run the smaller speedo and tach and fit more guages onto the stock size guage cluster opening.
Old Dec 1, 2007 | 04:09 PM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
Any particular reason you want full sweep 2 1/16" gauges?
Old Dec 1, 2007 | 04:18 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
xpndbl3, do you have a pic of the 3 3/8 gauges? i was worried that they would be too small, if not they will work.
Mongoose, i wanted to get full sweep gauges for the more critical water temp and oil pressure. I figure they are more accurate? am i wrong?
Old Dec 1, 2007 | 05:53 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
so get mechanical guages, they are available in 2 1/16 and are most definitely full sweep.
Old Dec 1, 2007 | 05:55 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
i dont want to have to deal with running tubing all over my car, so im trying to stick with electric
Old Dec 2, 2007 | 06:57 AM
Mongoose's Avatar
Car: 90 Formula
I would think that the short sweep gauges would be just as accurate as the full sweeps, just quite a bit less expensive. Plus I was thumbing through a Summit catalog and there is a 5" indash speedo and tach available in the Sport Comp II line under part numbers 3698 (tach) and 3689 (speedo).
Old Dec 2, 2007 | 01:09 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
and they are both no longer available
i think i can get them from jegs still
Old Dec 2, 2007 | 01:25 PM
Mongoose's Avatar
Car: 90 Formula
That's strange, they are both listed in the Nov/Dec 2007 catalog.....
Old Dec 2, 2007 | 03:58 PM
mw66nova's Avatar
Engine: 7.0L
well, as far as accuracy goes, the mechanicals are the better choice. running tubing is no more difficult than running the wires to the sending units.
Old Dec 2, 2007 | 06:51 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
true, but all the wires are already in the factory harness, i should just have to swap senders. I think ive got the ones that i want picked out, pro-comp2's. Just need to decide whether to use 5" or 3 3/8 tach and speedo
RS Reaper
Oct 17, 2018 07:52 PM
Luigytico09
Oct 1, 2015 08:46 AM
Gordonr1973
Sep 29, 2015 11:59 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
