Question on carpeting
Old Jan 6, 2008 | 04:57 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
I know plenty of you have replaced carpeting, but has anyone taken notice to why the carpet seems to be lumpy on the rear seat trans tunnel? I don't remember seeing them so lumpy back in the day, but see them at shows and on the road all the time. Is the jute backing deteriorating? I am just curious as I've even seen low mile cars with this.
Old Jan 6, 2008 | 05:52 PM
brp88gta's Avatar
Car: 88 trans am gta
Engine: 305tpi
Axle/Gears: 9 bolt 3:27
Re: Question on carpeting
im not sure but my car has it too with 36000 on it
Old Jan 8, 2008 | 02:01 PM
pondriver's Avatar
Car: 1992 Camaro ZO3
Engine: 350 HSR
Axle/Gears: 9 bolt/3.70's
Well then, I don't feel so bad my aftermarket carpet I just put in looks like that. Don't like it but, what do you do?
Old Jan 10, 2008 | 06:56 PM
jamesnelson101's Avatar
your carpet isnt shrinking with the rest of your car
Old Jan 10, 2008 | 07:50 PM
87 formy's Avatar
Car: 87 formula
Engine: 5.0 TPI
I think the carpet in the back of my car is fine (no rear seats probably makes a difference), but the carpet in the front is a little lumpy, I should look into that. Thanks for the reminder
Old Jan 10, 2008 | 07:58 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
i ended up with a little extra slack in the carpet on the tunnel too, i was able to work most if it down under the rear seats. looks fine
Old Jan 10, 2008 | 11:11 PM
i havent taken the carpet out of my car yet, but does it have that black rubberish soundproofing that is stuck to the body like alot of cars do? if so maybe it is that stuff deteriorating or cracking
Old Jan 10, 2008 | 11:27 PM
Firebat's Avatar
Maybe heat given off over time from the transmission? We all know cotton shrinks in the wash machine when hot water is used because of the heat. I don't know what carpet is made of though.
Vintageracer
Jan 10, 2020 05:33 PM
lee01
Apr 9, 2016 01:56 PM
tc7761
Aug 30, 2015 09:45 AM
Victor6
Aug 30, 2015 02:09 AM
redmaroz
Aug 16, 2015 11:40 PM
